Question about Fuji Cameras
My Fuji A860 camera will not operate. Just makes a clicking noise when I press the on/off button! Have tried new batteries to no avail.
    Brigadier General:
  • 11,967 Answers
Could be a lens problem. Try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 09, 2010
I have a similar problem. Ni-MH rechargeables all: Cheapo Tronic batteries reading ~1.35V worked, Duracell reading ~1.40V didn't! I hold in the Telephoto button when turning on, and the Duracells work. Is voltage initially too high on the Duracells, and the load of the motor causes enough V drop to allow it to start?
Posted on Sep 14, 2013
I haven't heard back yet. Alol I needed to do to correct err message was replace AA batteries. Please send my operators manual.
Please CLICK HERE TO DOWNLOAD the operators manual for Fuji FinePix S1 Pro Digital Camera .
You must have Adobe Acrobat Reader installed to view PDF files. The reader is a free plug-in available at the Adobe web site.
Oct 11, 2011 | Fuji FinePix S1 Pro Digital Camera
Help! Won't turn on
Fuji suggests; "If the digital camera will not turn on, run through the "Checklist" given below. If this does not solve the problem, take the camera, the batteries, and the AC Power Adapter to an authorized FUJIFILM service center for testing and repairs. [Checklist] 1. The direction of your battery might be wrong. Confirm it and put it again. 2. Load new or fully charged batteries. 3. The battery terminals may be dirty in a way that cannot be seen (fingerprints, etc.). Wipe the terminals clean with a soft cloth. 4. Press the Power button again firmly." Cleaning the battery contacts sounds worth a try. Fuji also say; "Please use only alkaline batteries or Ni-MH rechargeable batteries with Fujifilm digital cameras Please note that instruction manuals provided with Fujifilm digital cameras recommend that only alkaline batteries or Ni-MH rechargeable batteries are used with those digital cameras which require AA or AAA type batteries. If other types of batteries are used together with an AC adaptor, this may result in the rare occurrence of the battery overheating. Please do not use batteries other than those recommended in our instruction manuals." Check that the type of battery is correct Did you buy the camera new? is it still under warranty? Here is the link to the support page for the s7000 including manuals, repair centre details etc; http://www.fujifilmusa.com/JSP/fuji/epartners/ServiceSupportBrowse.jsp?prodcat=616757&sscucatid=664272&sscucatid=664271 or direct to the manual; http://www.fujifilmusa.com/JSP/fuji/epartners/bin/S7000Manual.pdf Apart from contacting Fuji for service, the only suggestion I could find in the manual was that the battery cover may not be closing fully. Worth checking. Hope this helps :)
Jul 01, 2007 | Fuji FinePix S7000 Digital Camera
My Fuji s5800 camera has a 'zoom error'
try pressing the unzoom button and holding it for a couple of seconds until it fixes itself. and if it makes a noise, till it stops!
Apr 10, 2010 | Fuji Finepix S5800 Digital Camera
When we press the on/off button, the camera make a
Make sure the battery or batteries are either fully charged or are new. If it still will not work, then the camera needs repair, and it may be better to sell it then for parts or repair, as is on a site such as Ebay.
Mar 03, 2010 | Fuji FinePix A850 Digital Camera
When we press the on/off button nothing happens. I have new batteries in it, I also have the cable plugged in. Nothing happens
I had the same issue...turned out to be the batteries not making contact... change the battery manufacturer to a known maker. The off brand stuff has dimension problems.
Feb 13, 2010 | Fuji FinePix A850 Digital Camera
FujiFilm A850 Clicking Noise... A900 Shutter Turns Itself Off?
It could be the cold affecting them but I suspect it's a battery problem.
If you use normal alkaline AA's then the camera will drain them fast. Try using the lithium type which has a higher Amh for use in high drain electronic gadgets like cameras.
The cold weather will affect things like cameras, especially when you bring them in from the cold after long periods. Condensation will form inside the camera and cause short circuits or component failure unless you allow the camera to aclimatise to room tempreture gradually before using it.
Condensation can also have an effect on the shutter inside the lens. It cannot evaporate well inside the lens unit because it is sealed and so leaves a residue on the shutter leafs that can cause the shutter to either stick or not work fully and you get either wavey lines on the pictures that you take or they come out over exposed or too bright.
Leave the camera for 24 hours at room tempreture and buy ( if you haven't already got) some lithium batteries and then try the camera
Dec 14, 2009 | Cameras
Camera won't turn on. It just makes clicking noise.
After i replace standard alkalines with rechargeable NiMH batteries Sony 2700 Ni-MH or Varta 2700 Ni-MH it's was working!
My camera it's working now!
Jul 18, 2009 | Fuji FinePix A850 Digital Camera
My shutter will not open. The power button presses in and nothing happens. I have since got a new battery that was the problem, shutter still will not open. Camera is not operative, please...
Can you get any signs of life? playback pictures etc? Try pressing the playback button instead of the power button. If camera display works then press the picture button and see if the camera will switch over and the lens extends. Also check if the tab on the battery door is not broken. This operates a micro switch to cut off power
Jun 19, 2009 | Fuji J150w Digital Camera
Fuji FinePix F470 Digital
Try another battery, it's possible current battery no longer viable or needs a deep discharge recharging.
Dec 27, 2007 | Fuji FinePix F470 Digital Camera
Cameras Logo
564 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
