Question about Garden
I have a Textron (zero turn) mower, Model #942213. I was driving to my mowing site, and it suddenly quit. It was as though I had the mower on and tried to get off the mower. Everything died. Now, there is absolutely no power anywhere, except in the battery. Turning the key gets me no response at all. HELP!
jdlipscomb41
  • 157 Answers
SOURCE: Cub Cadet zero turn mower quits mowing, s
when the fuse blows check for hot wires it seems to have a short somewhere hardist thing to find. look for naked spots on wires or pinched wires .
Posted on Oct 26, 2009
  • 279 Answers
SOURCE: I have a Troy Bilt mower w/ a Honda engine GCV160.
Pull the spark plug and see if there is oil in the cylinder. When you turn a 4 cycle engine over or on it's side, the oil can leak into the cylinder. There may be so much oil in there that the piston won't move. When you have the plug out, clean it before you re-install. Good luck...Lee
Posted on Nov 01, 2009
SOURCE: Swisher Mower dying when cutting
I've had a 60" Swisher finish cut (13.5 hp) for about 7 years and have found that the valves have to be adjusted on a VERY regular basis. When they get out of adjustment you can hear the starter trying to spin the motor but can't. I'm almost positive this is your problem. Go to You Tube to see how to adjust the valves to .004. It's simple. Stan Wilhite
Posted on Apr 18, 2010
01fordeb
  • 1033 Answers
SOURCE: I was riding the tractor mowing shut it off to get
The starter solenoid sounds to be bad. Follow the + cable from the starter and it will lead to the solenoid. This is usually about $10. The battery produces power to the solenoid which then produces power to kick the starter over. The clicking is the contacts in the solenoid you are hearing.
Posted on May 17, 2010
miket756
  • 2702 Answers
SOURCE: I have purchased a Toro zero turn mower and can't
no,,just turn the key to start her up!,,,if the engine is free to turn i gess it has a stuck starter relay or a jamed starter, or a dirty power/earth lead or joint some were
but check that this battery you charged up is any good first if the battery has been left standing in a discharged state it wont be any good any more,,try a set of "jump leads" from a good car battery!
Posted on Jul 27, 2010
Why won't my rider move and keep running?
Something is jammed in the drive and when you put the mower in gear the motor stalls. U need to locate the source of the problem - once you do that all will be copacetic.
Jul 21, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
Need diagram for mower belt deck for Craftsman ZTS 7500 42'
need a mowing deck diagram for 2008 42 inch 21 horsepower zero turn
Aug 08, 2012 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Ferris ztr model is4500z pto quit while mowing and wont re engage
check for power and ground going to the clutch and see if you have a bad clutch or bad wiring or switches
Jul 31, 2012 | Husqvarna Zero Turn Mower Z5426
I have a cub cadet rzt 50 with a kawasaki 22hp engine it cranks and runs fine for a while and then sounds like its running out of gas, I shut the pto off and it eventually quits running, I pull the choke...
PDF]OPERATORLS MANUAL - Cub Cadet
https://www.cubcadet.com/.../CubCadetCatalogAssetStore/.../own...Cub CadetRZT Series Tractor - Model RZT50VT. Form No. 769-04647 ... Please read this entiremanual prior to operating the equipment. It instructs you how to safely and ...
Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline ...
cubcadet.custhelp.com/.../basic-troubleshooting---zero-turn-riding-mowe...
Scripting must be enabled to use this site. Support Center. Cub Cadet Website ... Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline Powered). Answer ID 10646 ' Published 01/22/2014 11:27 AM ' Updated 01/22/2015 02:50 AM
May 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I have bobcat textron zero turn mower. When I engage the pto to engage the blades I can mow only a couple of passes and then the blades shut off. I checked all connections and looked for shorts in the...
hi,
jump the PTO directly to batt and see if runs flat out. if no problem running PTO then PTO relay may be bad. they are usually a tiny black box somewhere next to the fuse. follow the wires off the PTO to the relay. if you can get the tiny cover off the relay you might be able to sand that contact and hold the relay contact to see if thats was it.
jm
Apr 14, 2011 | Garden
Cub Cadet zero turn mower quits mowing, service center says clutch is fine but can't find anything wrong. Put 30 amp fuses in and they will blow after about 30 minutes of mowing. Any suggestions
Oct 21, 2009 | Garden
Garden Logo
182 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
