Question about Kenmore Elite HE4 Electric Dryer
Sounds like it has a flat tire - Kenmore Elite HE4 Electric Dryer
  • Kenmore Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryersounds like it has a flat tire - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Jul 11, 2010
Noise from rear -sounds like flat tire
Sounds like you have feathering on your rear tires. This is caused by bad shocks or faulty tires. Have your shocks tested first.
Aug 06, 2014 | 2005 Ford Freestyle
While driving my car is making a noise like i have a flat tire but all the tires are fine
check the wheel bearings and drive shafts also does it do it on the same bit of road as the difference on road surfaces can make the tyres sound strange also get the pads on the breaks checked as well hope this helps ivan
Oct 01, 2012 | 2010 Mazda 3 2.0
How to remove the rear tire (flat)
If you can't get to the valve stem (from either side, it sounds like you have bigger problems than just getting the tire off. It sounds like you will need to break down the tire to reseat the tube in the proper placement.
Some mowers have studs and nuts like a car, and others use a cotter key and washer to hold it on (which is probably what you have since you had to ask how to remove the tire). The cotter key and washer is under a cap that just pulls off. You can use a small screw driver to work it out.
Jun 11, 2012 | Garden
Sounds like a clunking noise, like the sound you hear when you have a flat tire, Tire isnt flat. turning right on the wheel lessons the sound but stays the same turning left. noise seems to be getting...
its a wheel bearing. .will need to be inspected to determine the correct one. Also tires could also do this if the steel seperated internally. Rotate the suspected tire to see if it follows the tire.
Apr 03, 2010 | 1990 Toyota Pickup
While driving sounds like i have flat tires all
My fist guess would be faulty wheel bearings. Take it in and Mechanic should be able to diagnose.
Oct 02, 2009 | 1998 Ford Explorer
I had a flat for a couple of months, when we put the new tire on I was driving on the freeway and it sounded like it was flat again. It wasn't but it sounded the same as a flat tire coming from the front...
The car, I assume, was not driven for the couple of months that the tire was flat, I would suspect that the other tire(s) may have developed a flat spot on it. or the possibility of another bad tire with a broken belt in it. you may have some vibration associated w/ this as well. You may want to take the vehicle to a reputable shop and have it checked out.
Aug 21, 2009 | 2002 Volkswagen Golf
Whooshing sound coming from front tire
Sounds like a few things. Flat spot on the tire. Something caught in the tread. Jack up the vehicle and turn the wheel by hand and see if you can recreate the sound, if you can you will find the problem.
May 16, 2009 | 2003 GMC Envoy
Kenmore Elite HE4 Electric Dryer Logo
95 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
