Question about Panasonic PT-51HX41 51" Rear Projection Television
Is like a wave at the bottom of the screen and in
The tv has like a wave at the bottom of the screen and in the right uper corner. You see the letters double and is hard to read.
  • Panasonic Master
  • 8,617 Answers
Convergence failure. You can get the convergence repair kit for your model at www.tvrepairworld.com which contains the parts and the CD with repair instructions.
Posted on Jul 10, 2010
The tv will turn on then it will go blank ?
are you hooked up to cable? it you are then the problem most likely is in your cable box.
May 11, 2014 | Sansui HDLCD1908 19 in. LCD TV
How big is this tv
measure the screen only
from corner to corner
E.g. top right corner of screen to bottom left corner of screen
Sep 28, 2012 | Curtis-Mathis CM27101S TV
It wont play games or dvds it just goes to the home screen. the clock in the uper right hand corner just keeps spinning.
Try these http://www.youtube.com/watch?v=Gp5FoFKEltg&feature=related http://www.youtube.com/watch?v=_r1AebrHVEk
Mar 14, 2010 | Sony PlayStation® 3 (60 GB) Console
Screen has dell logo and uper right hand corner says f-2 set up or f-12 boot menu will not move from that screen.what do i do?
replace your ram and try again... if that doesn't work then replace your hard drive... if still dead then your main board is shot... take it to pc service depot...
Dec 23, 2009 | Computers & Internet
Bottom of screen flickers, and eventually the screen 'freezes'
they have problem lines in tv screen harizontall lines how i can fixed in HDTV prima 29inch.2008 model .give me ANSWER .
Jan 17, 2009 | Prima CV2011 TV
Problem with letter stick on screen
Hold 2 volume controls down together until the P goes
Sep 01, 2008 | Thomson 24WK25U 24" TV
Wavy and ghosting
  1. words at top left corner have same word under it in red also on bottom of screen have seen were changing ic;s part# stk392-110 will solve problem if so what are ic;s
Apr 27, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Wave at bottom of screen with green and pink shadows
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Feb 17, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Arching color wave on bottom left corner & also on top left corner(color changes)
Convergence amps are failing which is very common. Several hundred dollars for a repair.
Dec 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
