Question about RCA Televison & Video
RCA Scenium D52W135D TV/DVD combo stuck in DVD mode
My TV/DVD combo unit's DVD player is not working properly. When the TV is switched to DVD mode, it just displays a black screen and I cannot toggle it back to TV mode. I'm fine with the DVD player not working and I found the post that describes how to disable the DVD player, so I intend to do that to prevent this problem. I just need to know how to get it back into TV mode. This happened two other times and after unplugging the TV for some time, it cleared the memory and powered on in TV mode. I left it unplugged for about 84 hrs but it didn't reset.
So my questions are how can I get it out of DVD mode? And will disabling the internal dvd player prevent this from happening again?
  • RCA Master
  • 11,800 Answers
Make sure that no disk is inside the player then press Menu on the tv - if you press it more than 10 seconds it cancels whatever function the player is thinking it must do and brings the Menu forward, you should be able to get out of it from there.
If even this doesn't work then the processor from the dvd player has failed and it sends jumbled signals that are blocking the tv processor - your only hope is to physically remove the connection between the player and the mainboard of the tv.
Posted on Jul 12, 2010
  • 1 more comment
  • livelsberger Jul 12, 2010
    I held the menu button down on the face of the tv for more than 10 seconds. Nothing happened. Do you have any more suggestions? If we can get it out of dvd mode would disabling the internal dvd player via the menu prevent this from happening?
    Thanks
  • Azrael SRL Jul 12, 2010
    Unfortunately there is no other way of exiting the dvd mode apart removing the connection between the dvd unit and the tv since you cannot access the Menu. Actually you should remove it completely, that would be better.
    And yes, removing the dvd will remove the cause for your problems, the faulty dvd processor. Disabling the dvd from the menu later will be helpful but not truly necessary - if you would access it by accident the tv will lock just like now but a simple restart will cure that (not like now).
    Ok Thanks. One last question. Is disconnecting the dvd player something I can do or do I need to hire a tv tech? I called one before about it, but by the time he came out the TV reset from being unplugged and he just took my money. Didn't even try to play a dvd much less fix it.
    Thanks
How do I disable the built in dvd player
That set is a beauty if it is equipped with the built in DVD player--they were all poor quality---only possible but not easy thing is it can be got at by removing entire front grill beneath the front screen and has only a few plugs to actually remove the unit.
I presume you have tried to change inputs with the remote etc.
Jun 12, 2012 | RCA D52W135D 52 in. TV/DVD Combo
Rca model# d52w135d screen won't turn on
Are you saying that the screen goes black after the DVD player stops working?
Jan 10, 2008 | RCA D52W135D 52 in. TV/DVD Combo
My GE universal remote for RCA Scenium tv doesn't work the DVD part
If this is a combo unit (TV with DVD built in) you need the original remote---Universals almost always are missing key features the original remote had as most companies have someone else make the unit and put their name on it.
Mar 21, 2012 | RCA Scenium D40W20 40" Rear Projection...
It goes off and u can get it back on ,,you have to keep turn it off and on before it will ever come on and stay.. lots of bad reviews on this brand RCA model D52W20 SHOULD BE A RECALL ON THIS BRAND TO...
RCA Scenium HDTV (Model #: D52W135D)(Chasis # ATC221) WILL NOT TURN ON!! When plugged in after a while of being unplugged the front power light will flash green lights first once...then 9 more times. I can hear the static in the back but nothing will turn on. It really sucks becuase we were just watch yesterday, turned it off after a while of it being on(I don't know if that matters) then the next day in the morning I tried to turn it on and it wouldn't turn on... :Z PLEASE HELP!!
Feb 16, 2011 | RCA D52W135D 52 in. TV/DVD Combo
Got and RCA Scenium CRT HDTV (D52W135D) which seems to have a convergence problem, green shadow over picture. DVD picture is very dim also
This tv have 2 problems than,the tv projection lamp life is over,that why the picture is dim,must be to replaced with a new picture lamp.The tv convergence board the 2 STK convergence ICS and some or all the resistors are dead.Replaced all these parts to solved the convergence problems.
Jun 24, 2010 | RCA D52W135D 52 in. TV/DVD Combo
Set is 7 years old - it turns off intermintently
Ours used to do that - and then we moved it to another state with us. Since the move it doesn't shut itself off anymore. I suspect that the problem was dirt and dust inside which got knocked loose in the move and the shutdown was due to thermal limits being exceeded. You may want to try vacuuming or blowing out the dust inside if you feel comfortable opening up the unit.
Feb 15, 2010 | RCA D52W135D 52 in. TV/DVD Combo
I have a RCA Scenium D52W135D, that wont come on. every great once in a while it will. When you plug it in it starts to warm up then shuts back down. Keeps repeating. It flashes a code at you through the...
have scenium d52w135d combo burnt power resistor in deflection board,do i need to replace the the whole board? or just the resistor,and where can i find this resistor?
Nov 03, 2009 | RCA D52W135D 52 in. TV/DVD Combo
Have sound no pic. on 52 inch.
if you have some thin lines on the top of the picture probably you have a problem on the power supply for the convergence
Sep 29, 2008 | RCA Scenium D40W20 40" Rear Projection...
Dvd troble
some dvd players dont play all dvd. i think the dvd player dont support the format of your dvd movie try a different dvd movie.This msg show up in every dvd you try to play????
Dec 14, 2007 | RCA D52W135D 52 in. TV/DVD Combo
Televison & Video Logo
383 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
