Question about GE Spacemaker JVM1640SJ Microwave Oven
Fan and light keep running and panel is blank
After using microwave the fan and light kept running and I could not get it to turn off. panel is blank. no functions would operate. ended up turning off circuit breaker.
    Genius:
  • 1,970 Answers
Mcdevito75 here, Sounds as though the control board could be faulty, check with any appliance repair center in your area.
Posted on Jul 09, 2010
Why is the microwave running without being turned on?
These above range microwaves "hoods" automatically turn on a cooling fan even when the microwave is not in use. If you read the manuals you will see warnings about the fans automatically starting. Even when the microwave is not in use opening the door likely interrupts the power to the automatic cooling fan.
Jul 29, 2014 | Whirlpool GH7155XHS Microwave Oven
My microwave wont heat up but runs normal
The make & model number would be helpful. There are alot of veriables that might cause this to occur. How long was the MW in use (the unit might have been to hot and the safety engaged) keeping the fan on to cool it down. There could be an issue with with one of the door interlock switches. Depending on the engineering, the control board could have had a hickup via a over current & shut down to protect itself. During the cut out was the cavity light on when the door was open. was the display blank. If you unplugged the unit waited a minute & then plugged it back in, did it operate again. It is not a good idea to open the control panel up, if your do not understand how to do basic electrical troubleshooting.
Mar 27, 2012 | Frigidaire Microwave Ovens
My Sharp Micro Convection Model R1870 fan behind the touch panel keeps running for 50 seconds after the microwave turns off,. this is not the vent fan. it also runs for 50 seconds when you turn the...
If the fan seems to run even after the microwave had completed the cycle, then it is possible that the drive to the fan is having a time delay. Also it has to be made sure that the magnetron has been cut OFF power or else it is not a good situation. You will have to remove the control panel and check on the board, check the drive to the fan, since the processor cuts off the fan and magnetron at the same time the fan circuit must be traced. Look to the circuit after identifying the fan wiring and back check using a multimter if you are able to trace. If not take help as this can be harmful in case the microwave works till the fan cuts off. A faulty capacitor on the board can create this time delay.
Oct 11, 2011 | Sharp R-1870 Convection/Microwave Oven
Our Microwave keeps running and won't stop. It is
The fan you hear is probably the magnetron cooling fan and that, and the light, are probably both controlled by the electronics board that controls everything else. You might inquire online at Maytag or the Sears parts department to determine the cost of a replacement board but I suspect it will either not be available at all or cost 3/4 of a new microwave.
Jan 23, 2010 | Maytag MMV4205 Microwave Oven
After use, fan keeps running and control panel not working
Hi, this is a major chip fault. this chip is located on the control board and, it is responsible for initiating the cooking cycle correctly. you will need to replace the control board asap. it has failed.
Jun 19, 2009 | Kenmore Microwave Ovens
Microwave high intensity light turning bright orange
You have a shorted grille relay on your control board. I can repair this for $69.95, which includes insured return shipping.
For details and more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | KitchenAid KHHS179LSS Convection /...
Oven shuts down after a few seconds into cycle time for cooking
The magnatron (heating element) is located in the cavity behind the control. If it's leaking microwaves onto the electronics, this will occur. This means the Mag should be replaced and a radiation test run on unit.
Mar 15, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Vent fan runs intermittently, starts on and off regularily
I don't have the manual but there should be a temperature setting for the fan to come on.
Jun 23, 2007 | Bosch HMV9305 Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
151 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
