Question about Inverter Pure Sine Wave 1500w Inverter
Inverter not switching on
I have a sucome inverter with me not switching on when power supply goes off
R.D.TRIVEDI
Sr. Engineer BEL
ministry of defence
Govt of india
  • 382 Answers
Trivedi ji namaskar
please make sure your inverter is on auto mode and then contect immidetly to your service provider for maintenance inverter becuse its microcontroller systems is not working.
hope question,s answer
thank you.
Posted on Jul 09, 2010
Screen went black sound ok
Normally if it's the inverter you will get some light/ picture/ osd on the TV when it switches on from cold for about half a second, then the baclklight goes off and you just get sound. It's easy for an engineer as it's all on it's own small circuit board. I Think the inverter is a bit like the starter units on flourescent bulbs, as your TV probably has 4-8 bulbs in..
this is all I could find for you.
Nov 08, 2016 | Televison & Video
Does anyone know who win power are. I am unable to locate them on the internet
Yet another knockoff computer parts manufacturer. They make more of the cheapest stuff in the world. Chang chung people's production ministry of chinesium. Kind of like GPX or HTC. Just buy a new one, a repair is more of a hobby project unless you are a power supply engineer already.
AT and ATX PC computer supplies schematics
Feb 02, 2015 | Computers & Internet
Samsung TV goes Black but keeps sound
you will need to check weather the 24vdc supply for the inverter board is good no drop voltage. if no supply check the power supply board. then you should check if their is a inv_on signal at the power inverter board around 3v-4.4vdc . if goes out during power on tried to disconnect the supply going to the inverter board to ensure if their is a shorted parts in the inverter board. if the inverter_on signal also goes out even with out inverter board connected that was mean you have problem in the processor board.
Nov 01, 2012 | Samsung LN Televison & Video
I have an Insignia LCD 32", is it common to only get 3 volts dc on one pin only on the power supply board (6HA0112014)? I tried a board from River Valley Electronics and got the same thing. What are...
That may be the stanby 3vdc for the main board, the main board will send out PS-ON signal when the power switch is activated which will turn on the rest of the power supply sections such as the 24vdc for the backlights inverter board and 12vd for main board, 5v for the logic circuits, etc. If the Inverter board has short cicruit, then it will cause the power supply to go into shutdown mode. You can disconnect the cable from the power supply to goes to the inverter board to see if you get the 24v, 12v to turn on.
May 18, 2011 | Televison & Video
When switched on screen is live for about 1 second then goes black
My flat screen monitor does not light up. Could it be a burned bulb>
Oct 18, 2010 | Acer V193w LCD Monitor
I have a Marantz SR-5600 surround Receiver. It has been shutting off the volume at various intervals recently. When I attempt to turn it back on a display reads " Check POW5
The POW5 fault indication means that the 5Volt power supply grid is not OK. The unit needs to be repaired by a professional repair engineer. No user servicable parts inside.
Jul 19, 2010 | Marantz SR-5600 Receiver
Tv went bang and now power goes onand off but no picture or sound
Hi I am Vortash , Most likely that your Power supply unit has shorted out possibly the bridge rectifier or possibly the SMPS drive ic's ( opto ) without looking at it directly this is almost impossible to say what it could be , even a shorted cap could blow the mains fuse and make a large bang when it goes so your best bet is to take it to an engineer .
Or take the number of the unit and seee what the manufacturers or a Radioshack type supplier will charge for a replacement , they are easy to fit and the plugs will be obvious just make sure you take a note of how they come out .. But be warned maybe something blew the power supply like a bad inverter or interface card ? so you might have problems and blow the new board , unless you can be sure it is so much better and cheaper to get an engineer to give you an estimate first . regards Vortash
Mar 30, 2010 | LG RZ-37LZ55 37 in. HD-Ready LCD...
Samsung LN-S4051D goes on and off by itself. Repeatedly.
1 Bad inverter circuit (used for back lighting the LCD panel)
2 Bad secondary power supply too the inverter circuits
Especially if its a switch mode power supply connected to twin phase inverters. This problem almost always happens under that particular engineering scheme. Switch mode power supply's are horrible at sustaining high voltage CCFL back lights.
Your tv needs professional servicing!
e-mail me if you need more info or advice....
Jan 28, 2009 | Samsung LN-S4051D 40 in. LCD Television
Hyundai HLT-3210 POWER SUPPLY FAULT LOW OUTPUT FROM SUPPLY PCB
Hello! My name is Ivica,and I am from Croatia.I have same LCD which have problem with motherboard.Try to disconect power supply from inverters and then measure all volt line.Maybe failure is on inverters board!Write me if you solve the problem,and maybe you know where can I find new motherboard for my LCD.Thanks.
Jan 18, 2009 | Hyundai ImageQuest HQL320WR 32 in....
Is true sine wave better than modified sine wave.
I'm not sure what the application is but I will offer the following. As a retired electronics engineer i can say for sure that a true sine wave does not have any harmonics in it. A modified sine wave will have some harmonics and other what I would call " trash content" depending on how it is modified.
Loringh
Nov 16, 2008 | Xantrex Technology RS400 Sine Wave...
Inverter Pure Sine Wave 1500w Inverter Logo
144 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
