Question about Scotts Company Scotts Pro Edgeguard Broadcast Push Spreader
HOW DO YOU CALIBRATE THE AMOUNT OF FERTILIZER DISPENSED
  • 63 Answers
It can be done visualy on the size of the granuals falling out per steps taken but a rough setting for most fretilizers is 6
Posted on Jul 24, 2010
They told me to use a 4 setting on Scott's fertilizer spreader, what would it be on a Vulcan spreader?
Do you start low and work your way up until the desired amount of product is being delivered?
Oct 14, 2016 | Garden
What setting do I use on a turf king drop spreader to cover 8,140 sq ft?
http://plantscience.psu.edu/research/centers/turf/extension/factsheets/calibrating-spreader
You have given the area you want to spread, but you also need the rate per square foot of the fertilizer. The link above tells you how to calibrate and check the rate of application.
Or you could ask Turf King direct.
http://www.turfking-lawn-care.ca/index.php?option=com_content&view=article&id=107&Itemid=328
Apr 09, 2016 | Garden
How to use roundup ultra
mix with water and an amount of urea fertilizer
Jul 08, 2011 | Roundup "" Weed & Grass Killer
Examples of independent and dependent variable
hi.
for a full definition, try wikipedia.
an independent variable can be freely changed.
a dependent variable will BE changed as the independent variable is changed
basically there are 2 main examples. mathematical, and experimental.
with experiments,(science, chemistry etc.) one example would be changing the amount of fertilizer fed to a plant to see how it affects growth. there are 2 variables here. amount of fertilizer used and growth of the plant.
the amount of the fertilizer can be freely changed. (independent variable)
the amount of growth DEPENDS on the amount of fertilizer (dependent variable)
with maths, you can use something like 2x+5=y.
x can freely changed. it is the independent variable. y will change depending on the value of x.
hope this helps
Jul 04, 2011 | Cycling
How do I calibrate Scotts Accugreen 2000 for pounds of Fertilizer per Sqft. What do setting equal?
To adjust calibration, do the following:
1) Adjust the micrometer setting to 6.
2) Turn the spreader over.
3) Squeeze the trigger against the handle.
4) The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper.
5) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
Note: If the hopper is missing a calibration line - with the setting at 6 they should be able to pass a 9/64" drill bit through the opening just to the right of center. (First opening to the right of the spring.)
Nov 08, 2009 | Scotts Company Scotts& Accugreeen 2000...
No solution dispensed
the most likely cause is your resevoir assembly that the solution tank sits on. fill the tank with water and insert into place. then remove tank. you will see a puddle of solution in the black valve, pull the trigger and this small amount should be dispensed. if it does not then I would have it evaluated for repair or replacement.
Oct 09, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
How do I calibrate my acugreen 1000 drop spreader?
The spreader comes already calibrated. The opening of the gate is determined by the setting that you input from the handle. This will correspond to the recommended settings provided on the fertilizer bag.
Best regards, --W/D--
Aug 09, 2009 | RTO Accugreen 1000 Drop Spreader
Model 300 runs out of fertilizer
Since I didn't have a manul, I downloaded one from Scott's and used that to calibrate the spreader which was out of calibration.
Apr 08, 2009 | Scotts Company Scotts& Accugreeen 2000...
Scotts Company Scotts Pro Edgeguard Broadcast Push Spreader Logo
490 people viewed this question
Top Scotts Company Garden Experts
john h
Nick Olsen
jhnolson
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
