Question about Uniden PRO520XL 40-Channels Base CB Radio
I need the correct VCO voltage to adjust the Uniden PRO 520XL
They usually designate the voltage to be adjusted on channel 40 with the radio in transmit mode. I can't find this anywhere. Right now I have it adjusted to 5.00 V DC on channel 40 tranmit.
  • 29 Answers
That may be a little high I think 2-3 volt is a lot closer.
Posted on Aug 24, 2010
Kenwood TK-3402 blinking red only on the programmed channels
The radio's microprocessor and synthesizer are told to show those indications when one of two conditions is met: either the frequency input is outside the operational range of the radio, or the VCO ("voltage controlled oscillator") is above or below its "lock range". The adjustments are physically small, quite fragile, and a very slight rotation in either direction can make a large change in the VCO. It's worth springing for a factory service manual so you can tell for sure where the meter the VCO is metered and how to set it to the correct range. And whilst I can't remember off the top of my head (I don't have that manual myself), many radios have separate Tx and RX VCOs, with separate voltage metering points and voltages to shoot for.
IHope that helps.
73,
Barney KL7HNY
Dec 21, 2016 | Kenwood Radio Communications
Midland 75-822 frozen on channel 19.
radio is out of lock .Replace the I C and it should unlock or you could try to do it your self but you would still have to replace the I C .
Oct 12, 2016 | Midland Radio Midland 75-822 Handheld...
I can transmit & receive all channels but when i try to transmit on 40 i get a loud pitch on speaker
Sounds like the VCO is out of range on the high end of the frequency range which causes the synthesizer to go out of lock on channel 40. If you tweak the VCO coil slightly it might lock again. Make sure it still works on channel 1 after you have tweaked the VCO coil.
Oct 02, 2014 | Uniden Radio Communications
How to adjust the antennae to get signal uniden 538w
doesn't matter what kind of radio the procedure is the same.First you need an SWR meter.now hook it up properly and take a reading on channel 40 ,write it down then channel 1 , write it down.now channel 19 and write it down . If the number on 40 is higher than on 1 your antenna is long and it has to be adjusted take the allen wrench provided with the antenna and loosen the tip.Bring the tip down about 1/4 inch at a time checking both channel 40 and 1 as you do this . onnce you get a good match then you are ready to go.
Aug 29, 2014 | Uniden Radio Communications
How to adjust frequency on a uniden Grant XL
Take this to a shop that does it for a living, they have the correct equipment needed to align this rig
Mar 08, 2014 | Uniden GRANTLT 40-Channels Base CB Radio
How to turn the power down uniden pro 520 xl
For this radio you adjust power through coils in the back of the radio. Using a watt meter and a plastic screw driver push coils L201 and L202 together and the power output will decrease. If D203 (modulation limiter) has been removed you can replace that as well. This should get you fixed up. Good luck.
Jan 10, 2011 | Uniden PRO520XL 40-Channels Base CB Radio
Correct adjustment of the antenna / or correct height of the antennae for maximum coverage
Hi, my name is John. Welcome to FixYa. Try extending it out as far as it will go, then work from there, don't know what stations you want, about half-way. Enjoy. Thanks for choosing FixYa......John
Oct 31, 2010 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Help setting up bc145xl scanning radio
you have to adjust the squelch. When it scans it will stop when ever the squelch breaks. Start with the squelch turned up a little less then half way, then scan.
Mar 02, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
Uniden PRO520XL 40-Channels Base CB Radio Logo
112 people viewed this question
Top Uniden Radio Communications Experts
Jason
Steve
eradiostore
eradiostore
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
