Question about Sony KDS-R50XBR1 50" HDTV
After turning on power it takes about 30 seconds for the picture to come on. It stays on for about 30 sec and then goes black and the green power light blinks for about 30 seconds and then the picture comes back on for 30 sec and goes out again. It does this over and over? Did the power reset and tried another bulb and it does the same thing. John Giblo 518-677-7793 JGIBLO@NYCAP.RR.COM
  • jgiblo Jul 09, 2010
    The green power light flashes not the red light that gives error codes.
  • 10,594 Answers
I'm Sony tech and can help you out.
Symptom shows that lamp is weak in result and causing problem.
As you said, lamp has been replaced but problem still not solved.
Let me know about replaced lamp, is it Sony original or any low price lamp?
If it is low cost lamp then buy Sony original to fix the issue and if lamp is Sony original than problem seems with ballast supply board that provide high voltage to lamp. Ballast supply board need to be checked/ replaced to solve the problem.
Let me know if you have additional question.
Thanks.
Posted on Jul 09, 2010
  • 4 more comments
    Can I replace ballast supply board? Part #? approx cost? How to?
    Thanks
    John Giblo
  • Shahid Electronics
    Shahid Electronics Jul 09, 2010
    I need two information about tv.
    Is it Sony KDS-R50XBR1 or any other model.
    Replacement lamp is Sony original or not.
    These info will help me to provide you solution.
    TV is sony KDS-R50XBR1 bulb is a sony.
    Thanks
    John
    Below image shows ballast supply board location in tv.
    Part number is as follows:
    146893612.... POWER SUPPLY BLOCK
    and available in Sony Parts Store $128
    Thanks.
  • jgiblo Jul 11, 2010
    Thanks for the info.
    I did not get a photo?, and the sony site did not have a photo for the part # you gave me. The price was correct.
    If you were going to replace one of the 2 parts first, which one would you replace first?
    Thanks
    John Giblo
    jgiblo@nycap.rr.com
    800-327-6528
    Shahid Electronics Jul 11, 2010
    Bulb has already been replaced with Sony original bulb and last option is ballast supply board.
    Sony parts site does not have part images, just part number works there.
  • 10,515 Answers
There is a very good chance that the lamp is causing the problem. You might want to replace the lamp to keep from having to call for service.If the problem continues the blink codes are provided to the service technician as a starting point to look for the problem.In this case, it is certainly a hardware failure. There could be many reasons for the same such as Faulty video out, CRT drive is faulty or G2 is improperly adjusted.This needs to be taken care by a technician.
However,if you have experience in repairing electronics, could read schematics, know how to use soldering iron and multimeter and would be able to keep all precautions, revert and i would be able to provide you some pointers.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Picture goes on for 30 sec. then off for 45 sec.,power/standby lite then blinks.can this be fixed or thrown out.SONY KDF-E50A10
Search Results
    KDF-E50A10 Sony TV - turns off and on - on its own - Sony's ...
    https://community.sony.com/t5/...Picture.../KDF...Sony...off.../442042
    Sep 12, 2014 - Our TV turns off and on without warning on its own. The standby lights starts to blink and the picture and sound go out, then 30 seconds to a ...
    Sony KDF-E60A20 problems - High Def Forum - Your High Definition ...
    www.highdefforum.com > ... > Rear-Projection TVs
    Jan 19, 2009 - 14 posts - ‎11 authors
    I recently got a 60 inch Sony KDF-E60A20 from a friend for around. ... runs for about 1 minutes then goes black(no picture no sounds), then the picture and sound come right back on for another minutes then off for 30 seconds.
Jan 18, 2016 | Televison & Video
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
shaun
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Pictures goes black while power light blinks green
I have a 40 but i was having the same problem. It turned out to be my lamp. I got a brand new lamp from Projector Lamp Services (relampit.com) and my tv works fine now. Im pretty sure that the 40 and the 60 take the same lamp. You might want to give them a call.
Jan 05, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Liquid Video monitor goes black after 30 seconds
Capacitors on the power board inside the lcd monitor have blown they can be replaced with new ones and the monitor should return to normal operation.
service center or if you feel capable you can do it your self with a soldering iron and the correct caps that have blown you need voltage and micro faradays usually 25 v at 470 mfd (u)however monitors use different kinds and voltages can be different it will be marked on the side of the damaged capacitors.
l8r
Nov 11, 2008 | Computers & Internet
Loses Picture, Goes Black... Sound stays on
Sounds like power supply. Probably time for a new tv. You have already got almost 20 years service.
Dec 05, 2017 | RCA F36685 36" TV
36 inch RCA tv loses picture and sound, but power stays on
Cable Looses signal power after 20m ... Install signal amplifier
https://youtu.be/AkiKf4G4UE0
May 04, 2017 | RCA 36V430T 36" TV
KDFE55A20 Sony
Check the connections that plug into the Block assembly. sounds like a connection issue.
Jun 15, 2008 | Televison & Video
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony KDS-R50XBR1 50" HDTV Logo
138 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
