Question about Thetford Norcold Compact Refrigerator 1.7 Cu.Ft. - NORDC0040
My norcold model 6162 rv fridge will not fire up on propane. It worked twoays ago today not. I have power and propane both are full 120 ac works. Seems like gas valve and ignighter might be at fault. The electronic module makes a clicking sound when switched on/off.
5 Suggested Answers
  • 62 Answers
SOURCE: i have a norcold refrigerator in my rv. it works
Check if you are getting voltage to the heating element should be 120 volts
Posted on Jul 22, 2009
  • 905 Answers
SOURCE: I have a Norcold 2 way fridge. The propane will
It is possible that the switch is giving you fits. Easiest way to check is to find where the DC voltage goes to the circuit board. Put a meter across the connections and read the DC voltage.
A poor ground can also cause this as well, and is quite common. Remove the DC connections, and make sure that they are bright and shiny. Also make sure that the connections are tight, both in the wire, as well as any crimp connectors. Check for corrosion on crimp connectors in the sleeves, if possible.
Your 10second problem can also be attributed to another cause as well. The thermocouple electrode assembly is very sensitive to placement in the flame, as well as spacing of each "prong".
If you have a multimeter, also check the "AC" voltage as found on the DC supply. You should not have more than a few hundred millivolts of ripple (noise?) present. Very much more can cause erratic operation as well.
Posted on Aug 29, 2009
SOURCE: RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
  • 15 Answers
SOURCE: I HAVE A NORCOLD 6162 RV FRIG AND THE FREEZER
u need to open the thermister up its located on the back on the fin also check to make sure u are getting full 12 volts to the fridge check the voltage at the fuse
Posted on Jan 29, 2010
I have a Norcold 2 door fridge. It works fine on propane or electric but I hear a VERY loud bang and see flames shoot out. It is a propane leak some place but checked fittings and lines -no leaks.
is this new? never been used before or old. ? please read this
Norcold, Inc. Product Recalls - Call 1-800-767-9101 Monday - Friday 8:00 am to 8:00 pm EST
The Norcold, Inc. refrigerators listed below have been recalled.
It is important to implement this safety enhancement to prevent an unsafe elevation in the temperature of the cooling unit should the unit fail in operation. This enhancement seeks to minimize the risk of injury or ***** due to fire.
Norcold Inc. has decided to recall certain 1200, 1201, 1210 and 1211 model gas/electric refrigerators with serial numbers from 315525 to 13088811, non-consecutively. The refrigerator's model and serial number are located inside the fresh food compartment. These refrigerators may have cooling units with a cooling unit serial number between 700000 to 13085759. This is a new recall campaign to include all 1200, 1201, 1210 and 1211 models.
Even if your refrigerator was repaired as part of a previous recall, it is necessary to have it repaired again to minimize the risk of injury or ***** due to fire.
If you have one of these refrigerator models, use the following procedure:
  1. Identify and write down the refrigerator model. If it is a Norcold 1200, 1201, 1210 and 1211 model, go to step 2.
  2. Identify and write down the refrigerator serial number. If the serial number falls in the range of 315525 and 13088811, go to step 3.
  3. Identify and write down the cooling unit serial number. If the serial number falls in the range of 700000 and 13085759, go to step 4.
  4. Call your dealer immediately.
The installation of the High Temperature Sensor will be at no cost to you.
Owners of recalled refrigerators should NOT operate their refrigerator until it can be professionally repaired by your dealer or a Norcold authorized service center.
If you have one of the recalled refrigerators and you:
Currently reside in the RV, you should immediately:
  1. Set the refrigerator controls to "OFF".
  2. Unplug the refrigerator through the service vent on the outside of the vehicle.
  3. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Do not currently reside in the RV, you should immediately:
  3. Disconnect from shore power.
  4. Contact your dealer, a Norcold authorized service center or Norcold's Recall Center at 1-800-767-9101 as soon as possible to get assistance.
Failure to follow these instructions can result in a fire causing injury or *****. To locate an authorized service center,
http://webcache.googleusercontent.com/search?q=cache:tnsP3IdSqhgJ:www.thetford.com/customer-support/recall-information/+&cd=10&hl=en&ct=clnk&gl=uk
if you have this model STOP using it!!!
Jun 19, 2017 | Refrigerators
5 amp fuse keeps blowing on ac input into cir. brd. on norcold model 6162
shorted heater element unplug and see if it still does it if still shorted board
Jun 17, 2014 | Dometic RM2652 Refrigerator
Norcold 682 is 0 in freezer and 50 in fridge cranked all the way up over 48 hrs now where do i look now
How about checking the R12 charge? Or you can run the fridge on propane and see if it gets colder. Which might mean your compressor is going bad.
Apr 15, 2010 | Thetford Norcold RV Cooler/Freezer
I HAVE A NORCOLD 6162 RV FRIG AND THE FREEZER FREEZES FINE AND THE COOLER COMPARTMENT WILL GET COOL BUT NOT COLD AND THE ADJUSTMENT SWITCH IS ALL THE WAY UP. THE SAME ON GAS OR ELECTRIC. CAN YOU HELP ME....
Oct 16, 2009 | Thetford Norcold RV Cooler/Freezer
Norcold Model 682 problem
no these units run on 12 volt aswell check your fuses or and be sure u are getting atleast 10.5 volts to that fuse
Sep 27, 2009 | Thetford Norcold RV Cooler/Freezer
My rm2552 fridge wont run off of 120 volt power but runs fine on propane any ideas?
I have a dometic rv refrigerator its gas/electric it worked 6 months ago. But can't get it to work now.
Sep 02, 2009 | Dometic RM2652 Refrigerator
Refrigerator doen't work on electric
check the fuse on the back of the board on the fridge itself
Sep 01, 2009 | Thetford Norcold RV Cooler/Freezer
Freezer works ok but the fridge doesn't
are you running gas to oper the frig in the rv or electricty if only using the heating element for the frig RV STYLE ONLY maybe starting to make and break causing intermittent cooling or not enough cooling in frig but at all thing concerned try to increase you temp setting higher if you have that option
Aug 19, 2009 | Refrigerators
My Norcold Fridge will not operate on AC
Check you 110 volt breaker in the converter panel to see if it is tripped
Apr 03, 2009 | Thetford Norcold RV Cooler/Freezer
Thetford Norcold Compact Refrigerator 1.7 Cu.Ft. - NORDC0040 Logo
448 people viewed this question
Top Thetford Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
john h
Are you a Thetford Refrigerator Expert? Answer questions, earn points and help others
