Question about Sony Computers & Internet
When I go to microsoft configuration exe
When I go to "msconfig" error message returns to make changes to system you must sign in as the administrator? I never had to doo that before, it started about couple odf month ago,what can I doo thanks
    Brigadier General:
  • 3,917 Answers
Hi
Please check the bellow links and follow the article…
http://www.pchell.com/support/msconfig_access_denied_error.shtml
http://www.raymond.cc/blog/archives/2008/01/11/how-to-fix-windows-cannot-find-msconfig-error-at-run-command/
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jul 09, 2010
Updater has stopped working ... error message pop up
turn it off in startup .
clik your start run
type msconfig
look in top right for startups
unchek
SoftwareUpdater.exe apply close restart system
Aug 03, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Main OS does not mount
Boot in safe mode
Start msconfig.exe and configure windows to start with a clean boot.
a. Log on to the computer by using an account that has administrator rights.
b. Click Start, type msconfig.exe in the Start Search box, and then press ENTER to start the System Configuration Utility.
If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
c. On the General tab, click Selective Startup, and then click to clear the Load startup items check box. (The Use Original Boot.ini check box is unavailable.)
d. On the Services tab, click to select the Hide all Microsoft services check box, and then click Disable all.
Note Following this step lets Microsoft services continue to run. These services include Networking, Plug and Play, Event Logging, Error Reporting, and other services. If you disable these services, you may permanently delete all restore points. Do not do this if you want to use the System Restore utility together with existing restore points.
e. Click OK, and then click Restart.
Boot the machine in normal mode.
Nov 11, 2011 | Compaq Hewlett Packard Presario SR5110NX ...
After installing oracle 8i after booting the desktop it shows strtdb80.exe error how to remove this error
Press the windows key and the R key on your keyboard at the same time,
(The windows key is the flag key usually between the ctrl and alt keys)
In the Run Menu type msconfig and click ok
In msconfig, select the startup tab
Find the program strtdb80.exe in the list and uncheck it
click apply, Then ok
Upon the next boot you will get a different message saying system configuration was changed, To prevent this from re-showing click the don't bother me again option in the bottom left of the info box and click ok.
Aug 28, 2011 | Computers & Internet
Everytime I turn on my computer, I get this error message: Error loading C:\PROGRA~2\MYWEBS~1\bar'1.bin\F#SCRCTR What does it mean and how can I fix it? My operating system is Microsoft Vista.
Please click on Start, Click on Run and type the following in the open box and click OK
msconfig
Vista: In the Start Search field, type msconfig , and press Enter . The System Configuration window opens.
Or
Press and hold Windows logo key on keyboard and press R. It will open Run Window. Type the following in the open box and click OK
MSconfig
Please click on Startup tab
Remove the check mark from entries related to Mywebsearch OR M3PLUGIN.DLL
Then click on Apply, Close and Please click on Exit without restart.
When the system restarts, you will see a message about System Configuration Utility. Click in the box for "Do not Show this message" and then click on OK.
More on this solution here.
May 05, 2011 | HP Computers & Internet
Runtime error
Method 1: Clean Boot with Only MoSearch loadTOCNode(2, 'resolution'); The Mosearch.exe (Microsoft Office Search Service) and Mosdmn.exe (Microsoft Office 10 Search Filter Daemon) Startup items may be conflicting with some other program (or programs) running in the background. Therefore, clean boot your computer with only MoSearch selected on the Startup menu to determine whether this program is the source of the conflict. To do this, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig.exe, and then click OK.
  3. On the General tab, click Selective startup.
  4. On the Startup tab, click to clear all check boxes except for MoSearch.
    NOTE: In Microsoft Windows Millennium Edition (Me), leave the *StateMgr check box selected as well.
  5. Click OK, and then click Yes when you are prompted to restart the computer.
  6. If the error message can be reproduced, repeat the preceding steps. In step 3, also click to clear the Process System.ini file and Process Win.ini file check boxes.
If the error message cannot be reproduced, this indicates that MoSearch is conflicting with some other program or programs running in the background. Follow these steps to locate the conflicting program:
  3. On the Startup tab, click to select one of the check boxes.
  4. Click OK, and then click Yes when you are prompted to restart the computer.
  5. If the preceding steps reproduce the error message, the last item added to the Startup menu is causing the conflict. If the error message is not reproduced, repeat these steps until all Startup menu check boxes are selected.
  6. If all the Startup menu check boxes are selected and the error message is still not reproduced, start Msconfig again, and then click to select the Process System.ini file and Process Win.ini file check boxes.
If these steps don't help you find and eliminate the conflict, proceed to the following method. uparrow.gifBack to the top Method 2: Uninstall the "Support for Fast Searching" Feature loadTOCNode(2, 'resolution'); To uninstall the "Support for fast searching" feature from all Office XP products that are installed on your computer, follow these steps.
Note This applies only to computers that are running Microsoft Windows 98 or Microsoft Windows Millennium Edition.
  1. Quit all Office programs.
  2. Click Start, point to Settings, and then click Control Panel.
  3. Double-click Add/Remove Programs.NOTE: Because there are several versions of Microsoft Windows, the following steps may be different on your computer. If they are, see your product documentation to complete these steps.
  4. On the Install/Uninstall tab, click Microsoft Office XP product, where Office XP product is the name of the specific Office product in question. If you are using a stand-alone version of one of the Office programs, click the appropriate product in the list.
  5. Click Add/Remove.
  6. In the Maintenance Mode Options dialog box, click Add or Remove Features, and then click Next.
  7. Click the plus sign (+) next to Office Tools, point to the icon next to Support for fast searching, and then click Not Available.
  8. Click Update.
  9. Repeat steps 2 through 8 for all other Office XP products installed on your computer.
  10. Restart your computer.
Apr 18, 2010 | Microsoft Windows Vista Home Premium with...
Photoshop Elements 7 is not working on my vaio with vista 64 bit
Starting Adobe Photoshop Elements, the Editor returns the error message "Unable to continue because of hardware or system error. Sorry, but this error is unrecoverable," and the Organizer returns the error message "Interface not found."
Solution: Enable the Event log service.
1. Choose Start > Settings > Control Panel.
2. Double-click Administrative Tools, then Services.
3. Right-click Event Log and select Start.
Note: The Event Log can only be disabled in the Microsoft System Configuration utility (msconfig) under the Services tab, but should never be turned off.
Background information
The error messages "hardware or system error..." or "interface not found" when you start either the Editor or Organizer indicate a system level problem. These messages display if Event Log is disabled. The Event Log is a Microsoft service that should never be disabled.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Sep 23, 2009 | Adobe Photoshop 6.0 for PC
On startup getting c:\..\shooter.exe not found error
goto start>run>type msconfig .. then goto startup tab and there uncheck shooter.exe..
then let me know ...
Sep 05, 2009 | Microsoft Windows XP Professional With...
When I turn my computer on, I get a runtime error.
If this doesn't fix it, let me know and I'll post another, more advanced repair.
Good luck, and please let me know how you do.
~ Spoem
Mar 24, 2009 | HP Computers & Internet
WHEN I TURN MY COMPUTER ON I GET AN ERROR MESSAGE - HOW CAN I STO
msconfig
Or
MSconfig
When the system restarts, you will see a message about System Configuration Utility. Click in the box for “Do not Show this message” and then click on OK.
It may work!
REGARDS
RAHUL
Feb 22, 2009 | Microsoft Windows Vista Ultimate Edition
When I click Microsoft LifeCam VX-1000 to run but window message error appear said "LIFEcAM.EXE HAS STOPPED WORKING" and the program will close. Thanks for your help.
hi,
if your running windows xp on your pc please try this
Clean boot procedure on Windows XP loadTOCNode(3, 'resolution'); To perform a clean boot procedure on Windows XP, follow these steps:
Warning You may temporarily lose functionality of some services when you follow these steps. When you restore the settings, the services are restored. However, when you restore the functionality, the original error message or behavior may return. Step 1: Start the System Configuration Utility loadTOCNode(4, 'resolution'); To start the System Configuration Utility in Windows XP, click Start, type msconfig in the Start box, and then press ENTER. Step 2: Turn off programs and services loadTOCNode(4, 'resolution'); To do this, follow these steps:
  1. On the General tab, click Selective Startup, and then click OK.
  2. Under Selective Startup, click to clear the following check boxes:
    • Process SYSTEM.INI File
    • Process WIN.INI File
    • Load Startup Items
  3. Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All.
  4. Click OK, and then click Restart.
Dec 16, 2008 | Microsoft LifeCam VX-1000 WIN-Blk Webcam
Computers & Internet Logo
20 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
