Question about Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD monitor lost "Red" signal of RGB display
I've owned a Gateway FPD2275W LCD Monitor since mid-2007. Yesterday, I noticed that I lost the 'Red' portion of the RGB display (only Blues Greens and of course yellows are now displayed). Is there a replacement part or parts that I can order from Gateway to replace the RGB display generator module?
  • 382 Answers
Not really, first check your connections, normally when you loose red a pin broke off the VGA connector.
If the panel died then its probably not worth while. The red panel is however, under the most stress.
Posted on Jul 09, 2010
I have a gateway FDP2275W desktop monitor. the monitor will power up and display the Gateway logo in the middle of the screen, then goes black. The monitor is still getting a signal from the computer as...
This is a common problem with many LCD monitors. The
printed circuit board that provides a stable voltage for the monitor to operate
from starts to fail. The PCB can be replaced, when/if they are available, or repaired
in most cases at a much lower cost. for more information on this email me at
Sprint6@zoominternet.net
Dec 26, 2010 | Gateway FPD2275W LCD Monitor
The screen doesn't turn on
This monitor was recalled a couple of years ago as being faulty. Gateway will not touch it if it's out of warranty.
There is alot of information about the recall here: http://gatewaymonitors.blogspot.com/2007/09/gateway-monitor-recall.html
Sep 11, 2010 | Gateway FPD2275W LCD Monitor
My FPD2275W LCD Monitor will only lit up solid white light. I have turned it off, unplugged it and everything else I can think of. It didn't how any signs of a problem yesterday, just all the sudden today...
Solid white meas the T-CON board is not getting the signals or 5vdc feeding it from the logic board or it has blown fuse.
Check all the caps in the power supply and on the logic board first, be warning, this case is real hard to open and MUST BE REAL CAREFULE WHEN SEPARATING THE FRONT BEZEL FOR THE BACK CASE!
http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD2275W/
Aug 17, 2010 | Gateway FPD2275W LCD Monitor
FPD2275W LCD Monitor power on blinks the display words- gos black
I don't think you will be able to match that IC without an ID number
Jan 20, 2009 | Gateway FPD2275W LCD Monitor
CTX
Neichi could this monitor be set to receive dvi signals and not rgb even if he has the rgb hooked into the monitor? so in menu select rgb input?
Mitch, monitors don't conflict with windows generally usually they(windows os) will install a basic generic driver to run the monitor, and you should do this when changing monitors before you hook up the new one, your description really lacks any concrete description where are the "black and blue errors" what do they look like last I have had problems with modems interfering with video so I would remove the modem and see if the problem goes away.
Apr 27, 2008 | Gateway FPD2275W LCD Monitor
Monitor brightness is high.
please get it checked by qualified professional
Apr 01, 2008 | Gateway FPD2275W LCD Monitor
No owners manual
http://support.gateway.com/s/Manuals/Monitors/8512088.pdf
Nov 07, 2007 | Gateway FPD2275W LCD Monitor
Gateway FPD2275W LCD Monitor Logo
188 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
