Question about Bosch 9.1 cu. ft. / 258 liter Upright Freezer GSU29424GB
Will drop in temp for no apparent reason
Our bosch upright freezer model GS__U 11year old will normally sit at minus 18c ,for no apparent it will fall to about 16 c ,this might happen about once a week.
If we then open the door and close it very firmly, ie with a little bang it seems to solve the problem,but if someone other than ourselves uses it who does not know to close it VERY FIRMLY,then the temp will drop,what could be the problem??.
4 Suggested Answers
  • 2006 Answers
SOURCE: Hello, I have a siemens
Your defrost timer is probably staying on too long, or the defrost thermostat is not sensing that the temperature was that high. It does tell you that the defrost heater is operational, just that it is staying on too long.
Posted on Jul 07, 2011
domotek
  • 591 Answers
SOURCE: I have a Bosch Exxcel
I would first try a complete defrost, by removing all food, unplug the freezer and let the door open for two days, (you can take the opportunity to clean the inside ha ha!) this is to make sure there are no ice build up around the sensors, than re connect the power and let it freeze up again, (on hot humid days the automatic defrosting cycle has difficulties to perform), don't forget to empty the water pan under the freezer (if equipped) and to put many towels around the bottom as well, it could leak some water on the floor... if the problem persists, than have it checked by a professional technician...
Cheers!
SOURCE: the alarm button is flashing
how?
Posted on Jun 23, 2013
Hello, I have a siemens upright refridgerator/freezer no KG32U123gb with a fully working refridgerator, however the freezer has recently started to defrost on a regular basis, the temperature rising from...
Jul 07, 2011 | Siemens Freezers
What is the temperature for the numeric settings? Thank you!
do not rely on the "settings" for the freezer,they are a guide ONLY.use a proper thermometer to get it to minus 18C.
Oct 04, 2010 | Frigidaire 12 cu. ft. / 340 liter Upright...
Just bought Belling Chest Freezer Model BCM31 as old one was thick with ice, but new one is frosting up very quickly as well above food line. Is this normal? Setting is right in the middle.
open the lid and using a spirit level check that the unit is flat and that its not "twisted" then using an a4 piece of paper check that the lid sits flat all round with no air leaks (the most common cause of chest freezers frosting up)if you have one, a freezer thermometer is a good investment, as you can set the unit to run at -18C,the optimum temp,,,
Sep 06, 2010 | Belling Freezers
Unit runs continually with gurgling sounds
defrost fully once a year or more if you notice it frosting up.it should run at minus 18c to 20 c for best results. 0f is fine.gurgling noise is normal (liquid turning to gas before compressor turns it back to liquid).make sure door seals all round and the kids close the door asap after use......also if you portion up food prior to freezing and vacpack it it will last longer.and be easier to store/rotate.
Feb 17, 2010 | Frigidaire 15 cu. ft. / 425 liter Chest...
Sears Ken Elite upright freezer model no 25329082991 temp alarm
alarm should go off when freezer reaches minus 18c or lower.
Feb 05, 2010 | Freezers
The alarm button is flashing
-18c is about 0 F. it shold be cold enough to freeze you know what.
you might want to turn the tempture up a little.
Apr 01, 2009 | Bosch 9.1 cu. ft. / 258 liter Upright...
Bosch 9.1 cu. ft. / 258 liter Upright Freezer GSU29424GB Logo
102 people viewed this question
Top Bosch Freezers Experts
Victor Nwachukwu
Victor Nwachukwu
ray gallant
AJMAL KHAN
Are you a Bosch Freezer Expert? Answer questions, earn points and help others
