Question about Garmin GPS
My street pilot goes off and takes a long time to come back a few hpurs
  • grijalvam Jul 09, 2010
    it is a st pilot 2720 $1000.00 4 yrs old used only 3 times It keeps losing picture
    where can I find the battery for Garmin street pilot 2729
  • 6,826 Answers
Maybe it's not charged enough:
Question:
How does temperature affect the power and charge of my device?
--> Answer: All of our units that have a rechargeable battery contain something inside the battery called a thermistor. If the thermistor inside the battery registers a temperature at or below 0°C or at or above 45°C1 (32 °F and 113 °F respectively)1 the charging mechanism within the unit will shut off. When the unit is operating outside of this temperature range the unit will operate solely off of the external power source and will not charge the battery.
When the unit is within the 32 °F and 113 °F temperature range, the external power source will power the unit and charge the battery. The unit's charger will always provide 100% to the unit and send any extra power to charge the battery.
As a preventative measure do not leave your device in direct sunlight. By keeping the device out of direct sunlight the unit is more likely to charge when getting into a hot vehicle.
The best thing to do if your device is not powering on in the vehicle, or your battery is only lasting 30 minutes is to charge the unit overnight by using either an AC adapter or USB Cable attached to a computer. Charging from a USB cable connected to a computer will charge the unit at 30-50% of the rate of which it would charge if plugged into a 12-volt vehicle power cable.
1. Temperatures within the vehicle generally tend to be warmer than the temperature outside of the vehicle.
//changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 10/26/2009
Posted on Jul 09, 2010
  • 1 more comment
    Where is the battery
  • Duane Wong
    Duane Wong Jul 09, 2010
    I checked ebay for it and only found chargers for it, no battery listed for it.
    I checked a vendor Batteryship.com off of Ebay, and they did not have your 4 year old model number listed as such.
    I checked Garmin.com and they say that 'Repair Services Are No Longer Available' for the Street Pilot unit. And certain models of the Street Pilot are repairable, but your number was not listed.
    Sorry about that.
  • Duane Wong
    Also, I noticed that it costs $99 for service for a StreetPilot 2720, which yours is a 2729.
    Their warranty is 90 days on service, if you could get it for your navigator.
    President:
  • 1,070 Answers
Welcome to FixYa
Sir/Madom,
Reset your Street pilot -Try Turning it OFF and ON again OR Remove Battery for 15 minutes and Reinsert it-Disconnect from External Power if Necessary..
Also make Update Software and Map Data
Go to this link for Update and more Here
Hope this can help you...Thanks for Contacting FixYa...
  • 4 more comments
  • shafi
    shafi Jul 09, 2010
    For manuals and all about your Product Click Here
    where is the battery
  • shafi
    shafi Jul 09, 2010
    • Here is Guide for you click here
    You can RESET by Following Direction-You will be Solved...
    TO RESET :-Turnoff Unit-Turn it on-During Start up Press and Hold Find Key on Front of 2720..Keeep Pressing Untill Message "do you really want to erase all user data?" appears.Touch YES to Clear all Data
  • shafi
    shafi Jul 09, 2010
    Also See this Video here [ instructions]
  • 382 Answers
Cold solder joint inside expands and contracts turning the device on and off. Could also be a firmware problem, first try updating your device. If that doesn't work then you have to be rather skilled at soldering small electronics.
Unless it is a very expensive GPS that is out of warranty, I would probably replace it.
So I went to replace the stereo on my 2002 Buick rendezvous and so I sniped a few wires off the stereos, then behind the dash there was a buzzing sound, and then I went to start the car but no luck. I...
No code reset will not allow restart. procedure takes half an hpur with out tech2 scanner. you have to put key in turn it to crank and then leave it in on position for ten minutes turn the key of and repeat two more times.
Nov 15, 2013 | Cars & Trucks
When you first light the pilot works fine after cooker heats up it may cycle a few times and the pilot goes out and then when you try to relight it will only stay lit while the pilot button is being...
Hi there. Try cleaning the thermopile, it must be free of soot or any other form of dirt, the pilot flame should be of good quality, as well as the gas pressure.
Regards.
Aug 02, 2011 | Imperial IFST25 Deep Fryer
Our garmin street pilot c330 tells us the battery is dead when it's plugged in and then goes blank. Can this type of battery be replaced?
yes the battery needs to be replaced, even when the GPS has external power the battery must be good for it to work,
May 15, 2010 | Garmin StreetPilot C330 GPS Receiver
Garmin street pilot c330 goes on and then goes off
Try to charge the unit for 4 hrs by using a wall adapter and then try power on it again and if still the same after you full charge the unit try to contact the manufacturer check if there is a latest firmware update for the unit.
Jun 09, 2009 | Garmin StreetPilot C330 GPS Receiver
After several munutes of on the screen goes to
I have a Garmin Street Pilot c330 which when plugged in and power button pushed, the screen lights up for a few seconds and shuts down. It was giving a low battery warning before shutting down. Where is teh battery in teh unity? and should I replace the fuse?
Apr 22, 2009 | Magellan Maestro 4040 GPS Receiver
Incorrect arrival time
There are a few things to check. On the main screen or selecting MENU, press on TIME.
Make sure the TIME ZONE is correct for your location.
Mar 09, 2009 | Garmin StreetPilot C330 GPS Receiver
You have to pry off the silver-colored faceplate from the unit and you will find a reset button on the right side of the screen. Push this and everything will back to normal.
Oct 24, 2008 | Garmin StreetPilot c340 GPS Receiver
Street Pilot problem
Having the same problem. Worked great for a year, and then couldn't connect once, and now never connects. I can never find any satellite and as such is pretty worthless.
Mar 21, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS Logo
35 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
