LG 32LC7D Television Logo
Posted on Jul 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My power went out and when it was turned back on my screen was pimarily white with colored vertical lines and no sound
Bud Martin
Level 3:
  • Master 11,361 Answers
  • Posted on Jul 09, 2010
Bud Martin
Master
Level 3:
Answers
11361
Questions
Helped
3368280
Points
33650
Unplug it for about an hour to see if it will reset itself, if not, you will needto check the DC output voltages of the power supply and the condition of the DC filter caps. It sounds like part of the problem is in the T-CON board, logic board.
If you are going to DIY and have proper tools, knowledge of electronics and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
1helpful
What causes my LG 55LS4600 55" tv to have sound but no picture.
It is a common problem for the LG model. The problem
is defective LED back lights ASSY. You have to open the display panel & replace the burned LED strips.
MAY HAVE BEEN HIT BY LIGHTNING. BLACK SCREEN AND 2 COLORED LINES
Replace the deflection board. Sounds like the vertical deflection was knocked out thats why you still have sound. You can get replacement deflection boards from www.tvrepairworld.com
The picture went out. Still have sound.
CAUTION: To prevent damage to the CRT phosphors, immediately turn down the brightness so the line is just barely visible. If the user controls do not have enough range, you will have to locate and adjust the master brightness or screen/G2 pots.
A single horizontal line means that you have lost vertical deflection. High voltage is most likely fine since there is something on the screen.
This could be due to:
Dirty service switch contacts. There is often a small switch located inside on the main board or perhaps accessible from the back. This is used during setup to set the color background levels. (On some sets, this is located on the CRT neck board and may be a jumper plug or other means of selecting service mode - not an actual switch.)
When moved to the 'service' position, it kills vertical deflection and video to the CRT. If the switch somehow changed position or got dirty or corroded contacts, you will have this symptom. Flip the switch back and forth a couple of times. If there is some change, then replace, clean, resolder, or even bypass it as appropriate.
Bad connection to deflection yoke or other parts in vertical output circuit. Bad connections are common in TVs and monitors. Check around the pins of large components like transformers, power transistors and resistors, or connectors for hairline cracks in the solder. Reseat internal connectors. Check particularly around the connector to the deflection yoke on the CRT.
Bad vertical deflection IC or transistor. You will probably need the service manual for this and the following. However, if the vertical deflection is done with an IC, the ECG Semiconductor Master Substitution guide may have its pinout which may be enough to test it with a scope.
Other bad parts in vertical deflection circuit though there are not that many parts that would kill the deflection entirely.
Loss of power to vertical deflection circuits. Check for blown fusable resistors/fuses and bad connections.
Loss of vertical oscillator or vertical drive signals.
The most likely possibilities are in the deflection output stage or bad connections to the yoke.
Good luck..
22helpful
5answers
Different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
Samsung monitor has white background with vertical color lines
if you have got access to another monitor try that it may be the computer or try another computer on the monitor hope this helps regards Jim
Black Screen with vertical lines down the side?
· http://esupport.sony.com/perl/news-item.pl?news_id=24
· Which models are affected with the "flicker" problem?
A1: There are 12 models in total: KDP57XBR2, KDP65XBR2, KP46WT500, KP51HW40, KP51WS500, KP57HW40, KP57WS500, KP57WV600, KP57WV700, KP65WS500, KP65WV600 and KP65WV700.
3answers
Vertical Color Lines with Sound
well I recently took my tv to a tv repair shop and they told me i had to replace the Y board and a Driver board. All in all it set me back $550.00
No picture/vertical lines on screen
it's called retrace lines ,your screens are set to high or focus block assy which has the screen adjustments on it also is faulty
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
