Question about Whirlpool WFW8300SW
Whirlpool (WFW8300SW). new CCU, now No water
Whirlpool (WFW8300SW). Just changed CCU because of previous error codes. Now NO water, No error codes & do not hear solenoids opening. What now?
  • Whirlpool Master
  • 8,220 Answers
Posted on Jul 09, 2010
Duet sport wfw8300sw03
try unplugging and plugging back in. a reboot of sorts.
i am not a repair man, but I own one too. good luck.
Jan 28, 2018 | Whirlpool WFW8300SW
Duet sport wfw8300sw04
The communication between the Central Control Unit (CCU) and
the Motor Control Unit (MCU) cannot be sent correctly.
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
- Check connections of the CCU board within the housing.
- Make sure all grounding switches are engaged.
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic Test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing
the MCU connectors.
Nov 04, 2013 | Whirlpool WFW8300SW
I have a whirlpool duet sport that is displaying F28 code. I have replaced the ccu unit now what do I do. It fills but will not wash, drains but will not spin HELP PLEASE!
For the F28 error code:
First, check the wiring harness connections to the MCU, the Motor, and the CCU. Make sure all the connections are tight and there are no ground wires off. Then check the connections of the CCU board within the housing.
If the wiring connections are fine then It would be a good idea to order both, as both components have been problematic for the error code F28.
Here is the CCU to order.
Here is the MCU to order.
Nov 03, 2012 | Whirlpool WFW8300SW
Error F28
The F28 code is a comm failure between the MCU and the CCU. First, check the wiring harnes connections to the MCU, the Motor, and the CCU. Make sure all the connections are tight and there are no ground wires off. Then check the connections of the CCU board within the housing.
Yes, I read a couple past members that diagnosed it as the MCU being the cause more than the CCU.
So you can order the MCU and/or the CCU, then I'd install the MCU first to see if that fixes it.
Oct 14, 2012 | Whirlpool WFW8300SW
Whirlpool f28 error code and door lock light
Here is a link to the CCU.
Here is a link to the MCU.
Oct 13, 2012 | Whirlpool WFW8300SW
On my washer machine appear code F-01, what that mean?
Under the front panel on the bottom of the machine is the error code manual. Mine says a CCU replacement for the F-01 error code.
Nov 22, 2010 | Whirlpool WFW8300SW
The door locks when the start button is pressed, but the cycle will not start. Diagnostics shows F26 door lock assembly. Whirlpool WFW8300SW. I have replaced the CCU and it still locks but nothing happens...
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Feb 18, 2010 | Whirlpool WFW8300SW
Whirlpool Duet Sport f-01 even after replacing CCU
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Jan 01, 2010 | Whirlpool WFW8300SW
Whirlpool Duet WFW8300SW00 - No Power to Control Panel
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Sep 29, 2009 | Whirlpool WFW8300SW
F21 error on a whirlpool frontloading WFW8300
error code f-21 is a simple fix on the front of your washer there is a lower panel that can be removed
with three screws. after removing panel you will see a white plastic piece/plug that you can unscrew
(be prepared for water spillage) remove that plug this is called the coin trap clean out this trap and put back together. this should solve your problem
Jun 21, 2008 | Whirlpool WFW8300SW
Whirlpool WFW8300SW Logo
322 people viewed this question
Dan Webster
Dan Webster
Sal De
