Question about Kitchen Ranges
I have a Kenmore Sewing Machine model #385.16231 the needle wont pick up the bobbin thread! Is it out of time? If so how do I fix it?
Rahul Sudhan
  • 30 Answers
SOURCE: How do I fix a
Here's how you set the timing od the Machine alright:
1. Take the side plate off, take the needle plate off.
2. Take the presser foot off, and put a new needle in the machine. 3. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
4. Then, turn the handwheel toward you until the top line is where the bottom line was.
At this point, the tip of the hook should be directly in the scarf of the needle.
This should set the timing of the machine perfect....
Posted on Jan 05, 2009
SOURCE: sewing machine won't pick up bobbin thread
open the bobbin case and see if the hook is turning, if it is it is just a timing problem with the hook and needle, if it isn't tuning you may have a broken gear or timing belt.....It eill need to be looked at or adj by someone who repairs them....Daniel
Posted on Jan 07, 2009
  • 26 Answers
SOURCE: needle wont pick up bobbin thread
timing issue, need to have serviced.
Posted on Aug 22, 2009
Mongo32
  • 111 Answers
SOURCE: singer sewing machine, needle will not pick up bobbin thread?
needle in backwards?
Posted on Aug 23, 2009
  • 96 Answers
SOURCE: needle will not pick up bobbin thread when sewing
double check the upper and lower tensions they often need to be changed to suit types of fabric and threads
Posted on Dec 13, 2009
My upper thread wont pick up the bobbin thread suddenly. How do I fix that problem?
Install a brand new needle. A bent/dull/damaged needle sometimes will not pick up bobbin thread.
Check that the needle is installed facing the correct direction.
Also check that the bobbin is wound smoothly, the bobbin is turning the correct direction in the bobbin case, and the bobbin tension is threaded correctly.
If it still will not pick up the bobbin thread, there is most likely a timing issue, ie the needle is arriving at the wrong time to intercept the bobbin thread. Search the internet for sewing machine timing discussions or take it for service.
Nov 03, 2016 | Sewing Machines
I need help with a white sewing machine model 765 I can't get it to sew it doesn't pick up the bobbin thread
First thing to try is a brand new needle. A bent/damaged needle may not be able to pick up the bobbin thread.
Otherwise, it is possible it has a timing issue, ie the needle is arriving at the bobbin at the wrong time in order to connect with the bobbin thread. Search the internet web sites and videos. There is a lot of information on how to fix sewing machine timing. Or take it for service.
Jul 11, 2016 | White Sewing Sewing Machines
Why isn't my needle picking up my bobbin thread and when it does it jams up as soon as I start sewing
1st: what type of sewing machine? brand?
2nd: it's not picking up the bobbin thread and jamming up because it's out of time.
the machine probably skipped a tooth on one or more of the gears and the gears need to be either replaced or re-timed.
either of which can be very difficult for the average person. your best bet is take the machine to a repair shop or buy a new machine.
this picture is for timing a standard Kenmore type machine. also works for some Singer machines.
Jul 27, 2015 | Sewing Machines
Sewing Machine
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not damaged or warped
make sure the bobbin is not over full & that it is inserted
correctly into the bobbin case
make sure the bobbin is turned the right way in the bobbin case
if none of these suggestions help,, it's also possible that the
machine could be out of time & would have to be checked at a
repair shop
Sep 07, 2012 | Sewing Machines
The bobbin thread appears up through the hole by the foot, but the needle doesn't seem to be picking it up and advancing the thread properly, so when I sew, the bobbin thread isn't engaging. I have a JC...
Check the timing of the needle to the hook. Here is a guide to generic principles of Timing
http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Best Wishes Martyn
Bargain Box in Australia
Sep 07, 2009 | Sewing Machines
NEEDLE WONT PICK UP BOBBIN THREAD
Yes out of time, I Can fix if you want to ship to me. e mail keithat11@aol.com
Jun 17, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
My Janome needle thread will not pick up the bobbin thread! I have checked threading and needle and bobbin case...nothing works!
Your Machine is out of time, you probably broke a needle or sewed over a pin. take the machine to your locsl deler to be re timed. about 90.00
Jun 13, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Problem with my machine
If you're not picking up a bobbin thread, it's either a timing issue, or the hook/needle clearance. Usually, with the hook/needle clearance the skipping stitch problem will be intermittent. If it's a timing issue, it may not pick up the bobbin at all.
Sep 08, 2008 | Kenmore 15516 Mechanical Sewing Machine
Machine wont pick up bobbin thread
needle won't pick up thread I think the timing is off, how do I retime it?
Aug 25, 2007 | Kenmore Drop-In Bobbin 16231 Mechanical...
Kitchen Ranges Logo
141 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
