I have an msi Notebook Model A4000. I inserted a 2gb sd card into the card reader at which point a message appeared on the screen saying the computer was installing a new driver software or whatever. After that installation was complete the computer began beeping and hasn't stopped since. It beeps about every second - bedum bedum bedum - and sometimes pauses for a second or two before sounding a more emphatic bedum and then continuing with the normal beeps. Is this normal? I definitely don't want to lose the pictures saved on the card.
  • 61 Answers
This is not normal. Try turning off the PC remove the sd and start it again. If no beeping put the sd card in the reader again. If you still have problems post back.
Posted on Jul 09, 2010
SD Card Reader won't read SD Card
Pls check if the Card is inserted the right way fully into the socket , if the card reader has been enabled , the driver for the card reader has been installed , if the card is working by connecting it on another computer .
Jun 21, 2015 | MSI (TM) A6200462US Laptop Computer With...
How to calibrate Vtech Storio?
https://vtech.box.com/s/68ee102d30c31a7c5a4d
If your Storio displays a blank blue screen upon start up, please perform the below procedure to restore the Storio back to factory standard - please note this procedure requires the use of a blank SD memory card and some form of SD card reader (either a port on the PC or a USB SD reader)
•Please firstly download the SD Card Recovery Creator
•Insert your SD card into the SD reader port on your PC or via a USB SD card reader - this should appear as a removable disk under your computer menu
•Double click the Vtech Icon located in your downloads folder to run the program - Click Continue
•Click 'Make Recover Program Card' then click 'Next'
•From the drop down menu, select the removable disk drive allocated to the SD card (drive E shown for demonstration purposes, the actual drive allocated to your SD card may differ)
•The application will now format the SD card with the Storio factory default operating system
•When the following screen appears, remove the SD card and then re insert it into the SD port or reader to complete the format
•Once the format is complete the following confirmation will appear - please click OK and follow steps 1-5 to finish restoring your Storio to factory standard.
•Please note, once the process is complete, you will need to re run the program to 'revert' the SD card back to a usable state
Feb 15, 2012 | Vtech V.Reader Interactive Reading System
SD card reader will not start, Windows XP says the drivers are up to date. When an SD card is inserted (65MB or 2GB) the sound is heard that the computer recognizes a card is in. But the card does not...
just a thought to try
click on the reader then click on the properties tab
check for compatibility and click the box and highlight your os and click on apply then ok
you may also have to click 256 box as well in that compatibility tab
Mar 16, 2017 | Toshiba Tecra M2-S730 Notebook
My SD card reader on my Sony Vaio will not read the card...it seems to know its in the slot, but won't read any data and says 'insert the SD card' if I go to computer and try to read it. Any thoughts?
Take a can of air and blow some into the slot to make sure dust or dirt isn't getting the way of that reader trying to read the sd cards.
If you still get the same message try another SD card in that reader or try to see if another computer will read your SD card, if another computer will read the SD card and the slot still won't recognize the sd cards properly, then you know at that point the reader is bad. If the reader is bad, thats integrated into the motherboard so the motherboard would need to be replaced.
Nov 30, 2009 | Acer Aspire 5610-4648 Notebook
Can i insert this type of memory card into the slot into the computer directly? it says on my laptop that sd, xd and M (symbol for pro duo? )can be inserted. But when i try to insert it, it doesn't appear...
it is advisable to buy a AIO (All in one) card reader, you can use this to many different type of memory card, the built in slot for memory card in your laptop sometimes only suite to a single type or model (ex. SD slot..MMC Slot etc.)
in your case your memory card is not fit to it, don't force it you might damaged your card
Nov 01, 2009 | Sony 2GB Memory Stick PRO Duo Memory Card
When i put my r4 into my ds its just says cant find menu?
hi it sounds like a software problem. follow the following instructions. Please can you try and reformat the 2gb micro sd card in your pc and copy firmware from the CD back onto the 2gb micro sd card following the instructions below. be warned that formating will remove even the games from the card so make sure you have a backup of the games saved to your computer. any saved games will also be erased.
To format the 2gb micro sd card
1. Insert sd card into usb stick and into usb port.
2. Close autoplay screen if it appears.
3. Right click on removeable drive. (Eg D, E, F or J etc) that appeared on screen in computer window.
4. Left click on format in menu and when format window appears, tick quick format box and select ok. This will erase all content on the sd card and remove any corrupt firmware.
To reload firmware
1. Insert cd into pc cd/dvd drive.
2. Open cd drive on screen and copy and paste the files and folders from the system/english 1.18 folder on the cd to the removeable drive that the usb and micro sd card are in. The folders that you will copy are "_system_" and "moonshl" and the files will be "menu.dat" and "mshl.nds".
3. Once copied, check removeable drive to ensure files and folders have copied over.
4. Remove usb stick from pc and insert sd card back into R4. R4 menu should appear on DS screen.
this normaly sorts this out. paul
Jul 07, 2009 | Nintendo DS Lite Console
Kingston 4gb sd card won't read
I had a problem with lenovo's reader like this, because i put in the nokia 6600 card, correct format and all, but apparently too old and not yet ment to be read by a computer ...
sd could still be hc ... the system of names is still not set up right. if you got a small black attachment for the card that makes it longer, put it on and try inserting the card again.
check if all the drivers are like they should be.
if you've got a friend with a card reader, make sure the card is ok. and if you've got a friend with a card, make sure the reader is like it's supposed to be
post a feedback, ok
Feb 23, 2009 | Dell Inspiron E1505 Notebook
HP Pavilion ZD8000 Digital Media Reader Issue
Try updating you drivers for your digital media reader. Also check your dcos to see if the DMR will read a 2GB card
Jan 11, 2009 | HP Pavilion zd8000 Notebook
MSI Wind Netbook sd card reader failure
For both an MSI Wind running Windows and Mac OSX 10.5.(4,5,6) do the following. Shut down the MSI Wind. Remove the power cord, any USB peripherals, and any SD cards in the slot. Remove the Battery Hold down the power key (with the battery removed for 2-5 seconds)  Release the Power Key Insert the Battery Insert the the Power Supply plug ((do not insert any USB or SD card yet)) Power on the Wind Now, insert the SD card-it should now show up on the desktop (in OSX). That should do it. Now insert any USB dongles/cables etc...
You have reset the PMU and bus start up. Any more Wind Questions?
Jay Rosen-WindManOSX
Dec 02, 2008 | Computers & Internet
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
