Question about XO Vision Car Audio & Video
Installation of a XO vision GX6103
Hey i bought these head rest monitors and was wondering which wires to hook up to what. i am gussing red is switched with the ACC, yellow is probably constant and black is ground but what about blue?
  • ericmg_87 Apr 13, 2009
    i dont know what wires to hook up
Can you send me the instructions
Posted on Oct 16, 2008
The blue wire is often times called a remote. It tells the item to turn on when the stereo turns on. In this case you can hook it up to ACC and get the same result, or hook it to a switch and that way you can turn it on or off from a different location.
Posted on Sep 29, 2008
The blue conect to the remote
Posted on Sep 24, 2008
Need a wiring diagram on suzuki raiderj 110. Please. Tnx.
Maybe you can use these codes taken from:
http://www.motorcyclephilippines.com/forums/showthread.php?120554-Motorcycle-Electrical-Wiring-Diagram-Thread
This is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
ORANGE - from Ignition +ACC
BLACK/swhite - Ground
WHITE/sblue - to Ignition Coil
BLUE/syellow - to ENGINE Stator side
ENGINE - Stator Single Phase
WHITE/sred - To RECTIFIER
YELLOW/swhite - To RECTIFIER
BLUE/syellow - from CDI sensor
ENGINE - Transmission Gearbox
GREEN/sblue - 1st Gear
YELLOW/sblue - 2nd Gear
WHITE/syellow - 3rd Gear
RED/swhite - 4th Gear
BLUE - Neutral
ENGINE - Rear Side
PINK - Odometer Speed Sensor
ORANGE/sred -
ELECTRIC Start RELAY
YELLOW/sgreen - form Starter Switch
BREAK - Foot pedal
ORANGE - From ignition + ACC
WHITE/sblack - to Break light
BREAK - Hand Lever
ORANGE - from IGNITION + ACC
WHITE/sblack - To BREAK Light
FUEL Sensor
Yellow/sblack - to Console
REAR - Lights
WHITE/sblack - form BREAK foot/hand
GRAY - From Night Switch
BLACK - from Left Turnsignal
LIMEGREEN - from Right TurnSignal
Signal Flasher Relay
ORANGE - from Ignition + ACC
LIGHTBLUE - Signal SW
RECTIFIER
WHITE/sred - From STATOR
YELLOW/swhite - From STATOR
RED/sorange - BATT+/HEAD LIGHT
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
GREEN - from HORN Switch
ORANGE - Ignition + ACC
NIGHT Switch
RED/sorange - From Rectifier
GRAY - To REAR LIGHT/HEADLIGHTThis is a Wiring Harness Guide for Suzuki Smash, Raider J, ShogunR/Pro Motorcycles. It may also be applicable to Hayate, Step, Mola and Raider 150.
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
CDI
BLUE - Neutral
ENGINE - Rear Side
ORANGE/sred -
BREAK - Foot pedal
BREAK - Hand Lever
FUEL Sensor
REAR - Lights
RECTIFIER
IGNITION Key
RED - from FUSE
ORANGE - to ACC
HORN Switch
Green - to Horn
HORN
NIGHT Switch
Dec 27, 2015 | 2006 Suzuki Stratosphere
How do i get the xo vision gx2146 to play threw my stereo speakers
Pull up the menu screen and scroll through until you come to FM transmitter. Select FM transmitter and scroll through to select a radio station(88.1, 89.1, etc). Select the station. Now, tune your vehicle stereo to said station. Enjoy.
Jul 23, 2012 | XO Vision GX2146 Car Monitor
Where do you connect the memory wire on a jvc kd g110 car stero.....what color is the memory wire ?? what does hook red wire to acc fuse mean??? what wire does the red wire on the radio connect to on...
The yellow wire is most likely the memory wire as it needs to be connected to a constant 12 volt source.
"Hook red wire to to acc fuse" means you need to hook into the fuse block under an Accessory Fuse. (ie: something that can't be turned on unless the car is running or the key is in the "Accessory" position)
The red wire is explained above. It does not connect to the harness.
Just remember that the yellow wire needs to be hooked to a constant 12 volts and the red needs to be hooked to a circuit that is only active when the car is running or switched to the "ACC" position.
Mar 02, 2011 | JVC KD-G110 CD Player
JVC KW-AVX710 not save. after switch off the car .when start it again all settings become to default
If your unit is not maintaining it's memory, it may be associated with the lack of a constant 12 volt power source. Test the units yellow wire, it should rest at 12 volts with the key in all positions; off, acc, on/run, start. This yellow wire should be connected to the vehicle's battery wire. Also, test the red wire. This wire should be connected to a switched 12 volt power source. It should read 12 volts with the key in accessory and on/run only. If you used a vehicle specific wiring harness to complete the installation, the wires may be switched in the harness. It's not a common issue but, I have seen it happen.
Dec 04, 2010 | JVC KW-AVX710 Car Monitor
I bought a used pioneer car stereo/cd player for my boat,battery wire marked, acc marked ( what does that wire up too?? ) & remote wire?? wat does it hook too ??
battery(yellow) goes to power that is ALWAYS on.(straight to + on batt) red or acc goes to accessory position of ignition key. (if no acc then wire to ign on(unless you want to listen to it with boat off then wire to batt + also but deck will be always on. REM is remote switch wire(gets power when h/u is on) and is used to turn on the amplifier if you have one or to make electric aerial go up. if you don't have either then don't worry bout it. leave it off but tape up the end.
Jun 18, 2010 | Car Audio & Video
Xo vision gx2022..need the plug that turns video wire into rca's
radio shack online or crutchfield.com may have what you need
Dec 27, 2009 | XO Vision GX2022 Car Monitor
Which pin does the ACC red wire connect to?
hi,
red to ignition of the car
yellow to positive terminal of battery
black to neg. terminal of batt.
the rest of wires to speakers (4)
Jan 21, 2009 | Pioneer DEH-P2900MP CD Receiver...
Car Audio & Video Logo
549 people viewed this question
Top XO Vision Car Audio & Video Experts
Jose Velazquez
Jose Velazquez
mega_mind
Are you a XO Vision Car Audio and Video Expert? Answer questions, earn points and help others
