Question about HP Photosmart C7280 Laser Printer
HP C7280 printer to print without replacing colour ink cartridge
How can I have my HP C7280 printer continue to print without having to replace a colour ink cartridge that I have no use for?
    President:
  • 2,666 Answers
You can't
Posted on Jul 09, 2010
I have a new black ink cartridge but my printer wont print because the color ink is empty is there a way to get it to print without refilling the colored ink since i only need black???
When printing in BLACK, a small amount of the COLOUR ink also is used.
This "trick" prevents the COLOUR ink-jets from clogging, due to not being used.
So, you need to have a "good" COLOUR ink-cartridge.
Mar 18, 2011 | Epson Stylus Multifunction Inkjet Printer/...
My magenta ink is not showing up on the diagnostic test. Print is coming out with alot of green and blue colors. I have a C7280 Hp all in one printer. Mickey
Use the HP Printing Assistant software to run a "nozzle check" -- to ensure that each of the 3 ink-jets is not CLOGGED, and therefore is not jetting ink onto the paper. If necessary, run 3 (or 6) "head-cleaning" cycles.
Then, try a different tri-colour ink-cartridge.
Dec 14, 2010 | HP Photosmart C7280 Printer
HP Photosmart C7280 color ink running out despite not using it?
  1. Unplug power cable while the printer is ON.
  2. Press and hold the '#' and '3' buttons, and plug the cable back into the printer.
  3. Continue holding the buttons down for 20 seconds, and then release it.
if doesn't initialize successfully repeat
on step 2 press and hold the '#' and '6' button and plug in the power cable.
May 13, 2010 | HP Photosmart C7280 Printer
Error 0xc18a0105 - ink faillure for HP c7280-help
Go to our web site at : www.ccl-la.com/ and click on the printer service section. We have a walk thru that will get you back going. The problem you have is caused by air in the ink feed tubes and the repair guide will show you how to do a feed tube purge.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Sep 23, 2009 | HP Photosmart C7280 Printer
My HP Photosmart C7280 does not recognise refilled cartridge.
Yes that is because when you get a cartridge refilled then what may have happened is when you gave a print command some of the ink may have splattered onto the ink spraying sensors(usually happens with refilled cartridges on any printer).Its because of the heat generated with which the ink nozzles cannot handle as the ink that is sprayed from refilled cartridges is a little more than regular original ink cartridges.Dip a cotton swab in water wipe the copper contacts on the cartridge.Then wipe around the place where the cartridges sit and also wipe the carriage rod which is inside the printer (metal rod)along which ur spraying mechanism(carriage) moves. If this does not resolve your issue call in to hp at 1800-474-6836 and you can purchase original cartridges that are just for 11 dollars each.........or you can purchase a combination pack which will be cheaper
Jun 15, 2009 | HP Photosmart C7280 Laser Printer
Installed new yellow print cartridge for HP printer, prompts to install new cartridge but my ink level says full
I have this same problem and some sites said to uninstall the software then download the software from the HP site and reinstall it. So I am giving that a try tonight
May 29, 2009 | HP Photosmart C5180 All-In-One InkJet...
HP C7280 Printer not priting wirelessly.
Solution Replace the indicated ink cartridge(s), or press OK on the control panel to continue. HP recommends the use of genuine HP ink cartridges. Genuine HP ink cartridges are designed and tested with HP printers to help produce great results, time after time.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage due to the use of non-HP ink will not be covered under warranty. Follow these steps to replace the depleted HP ink cartridge(s). Step one: Replace the indicated cartridge(s)
  1. Make sure the HP All-in-One is turned on.
    NOTE: The Attention light blinks when the product is turned on.
  2. Open the access door by lifting from the front center of the HP All-in-One, until the door locks into place. Figure 1: Opening the access door c01079714.jpg
  3. Squeeze the bottom of the latch below the ink cartridge to replace, and then lift the latch.
    • To replace the black ink cartridge, lift the latch on the far left.
    • To replace one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
    Figure 2: Lifting the latch c01079715.jpg 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
  4. Pull the ink cartridge towards you out of its slot to remove it. Figure 3: Removing the ink cartridge c01079716.jpg
  5. Remove the new ink cartridge from its packaging.
  6. Holding the new ink cartridge by the handle, push the ink cartridge into the empty slot. Match the color and pattern of the ink cartridge to the color and pattern on the print carriage. Figure 4: Inserting the new cartridge c01079717.jpg
  8. Close the access door. Figure 5: Closing the access door c01079719.jpg
Step two: Align the new ink cartridge(s)
  1. Make sure paper is loaded in the input tray, and then press the OK button. The HP All-in-One prints the alignment page, aligns the printhead, and initializes the ink cartridges. This takes approximately 5 minutes. CAUTION: Do not disconnect or turn off the HP All-in-One during this time. You may hear the HP All-in-One making noises.
  2. Check the display for status, and then press the OK button. Recycle or discard the alignment page.
Cause The original HP ink in the indicated ink cartridge(s) has been depleted.
May 24, 2009 | HP Photosmart C7280 Laser Printer
HP C6280 says out of black ink
Something is wrong with your Blach carrier or connections. Use a bit of alcohol and clean the array of gold contacts where the Ink cartridge plugs in. Most of the pins are shutter and piezo control (get the ink on paper) but a few do other stuff like check ink level, # of hours runtime, etc. This is very common problem with inkjet printers. Hope this helps.
Also... rub the contacts on the printhead with a pencil eraser to make them shiny and bright.
Cheers!
Mar 26, 2009 | HP Photosmart C7280 Printer
Hp c7280
dear creepers600
plz check the colour ink cartridge status, then check is the colour printing is enable or not. post your findings
Dec 08, 2008 | HP Photosmart C7280 Printer
White lines in print--looks like pinstripes
I asked the technician at Staples what he thought and he thought it was the ink cartridge. since I was using 3in1 cartridges and it was expensive to buy two; (1) Black with pale magenta and blue plus (2)red blue and yellow,we bought a new printer that uses one colour only cartidges so we can replace one colour at a time and also use a pale blue and pale magenta to get better reproductions. for a little more than double the price we bought an Hp printer Photosmart C7280 on sale with single cartridges. It will pay off, They are a fraction of the cost of 3in1 colours.
May 22, 2008 | HP PSC 1350 All-In-One Thermal Printer
HP Photosmart C7280 Laser Printer Logo
523 people viewed this question
Seeker5211
Seeker5211
