Back to:
Tags:
Galaxy DX- 88HL Base CB Radio
Galaxy DX 88 HL jumping frequency
posted by Shawn711 on Apr 19, 2008
As the title says, I have a DX 88 HL that I just picked up that the frequency counter constantly jumps around on. It has no recieve, but I haven't tried transmit since it doesn't appear to be stable. There does appear to be a black block looking component that is located on the pcb underneath and slightly behind the frequency counter box that appears to be slightly burnt and there's a ground strap running from the frequency counter box to a pod on the board that is broken. I'm sure the ground strap needs resoldered, but I'm not sure what the black box compenent is.. I can't say I'm a master technician by any means, but with a little guidance, I'm competent enough to replace some parts if I know what I'm replacing. Any ideas what this component could be?
Comment by Shawn711, posted on May 10, 2008
Ok, I got this sorted out. It apparently takes a little longer than normal to stabilize during warm up. Typical Galaxy in that aspect. Radio works fine.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 27, 2008
Thanks for Trying (70)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
sounds to me like a bad PLL chip. but then again, I'm no Master tech myself.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Galaxy DX 88 HL jumping frequency:
I don't want to Accept this solution
Can you Help with these CB Radios problems?
i have two galaxy 88's one works perfect but the other...
CB Radios
trying to solder up a sadelta ech master mic to a uniden...
CB Radios
i had changed my car battery yesterday and car radio is...
this radio transmits 4 watts of carrier but no mod Im...
Thank you for the speedy reply,but I don't know where the...
Loading problems.
Repair Service
Find CB Radio Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
