Question about RTO Atwood DSI-RV Water Heater-6 Gallon
After camping in the "wild" and having no problems, we hooked up at a campground and have VERY low flow of just the hot water.
  • Mike Butler
    Mike Butler Jul 10, 2010
    I assume wild, (dry camping) means you used your on board pump for water pressure at that time, and pressure at hot was o.k. correct? Is it low flow at all taps? Have you tried putting some water in your potable tank, and disconnecting city water and try pump on board to see if any difference? Sorry about questions, but will help in proper answer. Let me know please. Thanks
  • l_joyce Jul 10, 2010
    We did do that & there was no difference & it was all taps. I read some more stuff on the web and one guy said it's almost always the check valve. We couldn't find it, so I had Fleetwood e-mail the plumbing plans and there it was, in the bedroom beside the hot water tank. That valve was totally blocked with deposits, East Coast hard water? All's good now.
  • RTO Master
  • 6,674 Answers
That's where I was heading. Your city water valve (hose hook-up) is also a check valve, so if all water pressure decreases, that will be a good place to start looking, but when just on hot side, check valve is usually fitted right at back of tank on top (hot) fitting for water line.
Thanks for getting back to me, "Happy RV'ing."
Posted on Jul 10, 2010
Testimonial: "After two weeks of bathing in cold lakes and then dribbles I'm just heading for the hot shower! We HAD it get it done as I've got two weeks paid for at Acadia National Park [$20.00 a night] with no hook-ups! They do have cold showers, LOL. Thanks again for your help."
Low hot water pressure only
turn the heat down or turn to pilot mode. Turn water supply off, hook up hose to drain valve, route hose to safe place to drain, v if this is above grade the don't turn the water supply line off. Open the drain and see how well it flows. There could be calcium deposits in the unit. IF it flows well out of the drain, you could have corrosion build up inside the inlet or outlet from minerals. Remove the inlet and outlet connections. Check for debris, you may have to replace the washer on the unions. Check the anode on the unit.
Nov 23, 2015 | Water Water Heaters
Rheem 22v50f1
Backflow preventer is not part of water heater:
http://waterheatertimer.org/images/Watts-water-heater-parts.jpg
Water heater might have heat trap nipples that get clogged... but other issues have to be eliminated:
http://waterheatertimer.org/Low-hot-water-pressure.html
Gene h
Mar 27, 2014 | Water Heaters
I have a vaillant eco pro 28 combi boiler. no constant hot water unless tap is on really low.
Oh some of these there was a small black heatexchanger just for hot water they some times block up . or it could be a blockage in the water section where it flows in .I know Valliant have a very good tech line and fitters who do house calls .
Mar 02, 2017 | Water Heaters
Low water pressure
Hi Bob,
You can determine if the tank is the problem by connecting a garden hose to the drain that is provided on most water heaters. Before doing this, be sure to shut of the electrical supply to the heater - otherwise you can damage heating elements if an electric type or waste fuel by heating an empty tank if a gas / propane fired type.
If you get a slow flow out of this drain, it means that somewhere in the cold water supply side to / in the tank - there is a problem. Inside the tank, the cold water is delivered by a "dip tube" that distributes the cold water to the bottom in the tank. Dip tubes are used in both electric and gas / propane fueled heaters. Here's a cut away view of a typical tank:
If the tube is clogged, or there is build up, scale or debris in the supply (cold water) side of the heater, flow rates will suffer. Likewise, if there is a problem with the output of the tank, it will directly affect flow as well.
If you get a good flow rate from the drain, then the issue is going to be on the hot water output side of the heater. Again, the same build up, scale, debris issues on the hot water out put pipe will cause problems with flow. Typcial tanks do not have dip tubes for the hot water side of the tank - as taking hot water from the top of the tank is most desireable and is furthest away from the cold water that rushes in to make up the hot hot water going out.
There's nothing really in the tank itself that can cause issues with flow outside of the dip tube, and piping to and from the tank.
Jun 29, 2012 | Water Heaters
My kitchen facet will not activate the hot water buner now and it takes two hot water facets in the bathroom to activate hot water. Is there a maintenance pronlem I need to do? Where are instructions how...
There is a minimum water flow required to operate your Bosch tank-less water heater. It is around .75 gallons a minute. There are three things you can do to help the flow.
1.Turning the temperature down will help increase the flow.
2. Installing higher flow aerators on your faucets.
3. Clean the Bosch tank less water heater.
You are not alone in having this issue. The most common problems are low flow faucet aerators and low flow shower heads.
Aug 31, 2010 | Bosch Water Heaters
It turns on ,starts to get warm.Then turns off
Sounds like you have a problem with water flow. Since your ground water is warmer in the summer, you mix less hot and more cold in order to get the same warm temperature. If your hot water flow gets low enough, your tankless will start to "short cycle" in order to prevent scalding. Use one of these three methods to increase your water flow at the shower:
1) Clean your shower head and descale
2) Widen the hole in the showerhead's flow restrictor
3) Remove your flow restrictor entirely
Aug 02, 2010 | Noritz 6.3 Gallon Residential Tankless...
Water becomes ice cold in the middle of a shower
Jan 24, 2010 | Noritz NORTIZ Outdoor Propane Tankless...
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Alpha 240e boiler wont fire up for hot water, will for heating
most likely the diverter valve.. when hot tap turned on the movement of the water through the valve operates a diaphragm which pushes a pin/button//switch to tell the boiler to fire up
RTO Atwood DSI-RV Water Heater-6 Gallon Logo
171 people viewed this question
Top RTO Water Heaters Experts
Donni Steen
Mike
Are you a RTO Water Heater Expert? Answer questions, earn points and help others
