Maytag MAF 1260 will not spin since new motherboard(Motherboard been replaced twice). Did spin with old motherboard but was overfilling.
5 Suggested Answers
  • 1073 Answers
SOURCE: washing machine overfilled twice (maytag)
three things can cause this deffective water inlet valve, deffective water pressure switch and a pressure hose that connects to the pressure switch to the tub, has to be one of the theree things
gl
Posted on Apr 10, 2008
Bubbabear64
  • 2794 Answers
SOURCE: a new motherboard for a old compaq presario 5240
You will need a new case and a new power supply. I would replace the memory as well.
Compaq had a tendency to make cases to only fit their boards back then. Youre better off building a new unit and starting over again.
Posted on Jun 14, 2008
map9966
  • 2351 Answers
SOURCE: Replacing Asus CUV4x Motherboard with Asus p5vd2-vm-se motherboard
Hi eibral2345, sorry but there is no chance the motherboard, Asus P5VD2-VM-SE will run the Samsung memory. It’s the old style 3.3V PC133/100 SDRAM. The new Asus motherboard,
P5VD2-VM-SE uses Single-Channel DDR2 - 667MNz or 533MHz memory. Here is a link to the specs of the Asus CUV4X: http://www.pcstats.com/articleview.cfm?articleid=314&page=3
Here are the specs for the Asus P5VD2-VM-SE MB: http://www.asus.com/products.aspx?modelmenu=2&model=1787&l1=3&l2=11&l3=369&l4=0
Will the new Asus board fit in your case? It should!
The larger measurement is the height of the board.
The Height + Width of the new board is smaller than the older board.
Have more questions?
Good luck eibral2345!
Mike
Posted on Sep 26, 2008
TheMobilian
  • 8205 Answers
SOURCE: maytag washer overfilling
Easy fix. Do this: Remove the rubber tube coming from the bottom of the tub up to the water level switch right there at the switch itself. Blow through it to remove the sediment in the bottom of the tub so that air pressure from tub to switch will be kosher. Put the hose back on the water level switch tight and pump out any water in the machine.
Retry
Posted on Dec 19, 2008
  • 97 Answers
SOURCE: Gateway GT5228 Motherboard Replacement
http://www.fic.com.tw/product/motherboard/AMD/KTBC51G.aspx Seems to be the most consistent answer that I find. Hope it helps.
Posted on Jul 27, 2009
Maytag MAF 1260 AAW - hums and does not expel water or spin
I think the pump is bad, jammed up with something, or just stuck. You said it was humming. It seems to be trying to work. You will have to go in there and see. GOOD LUCK FRIEND.
Nov 17, 2014 | Washing Machines
Commercial maytag front loader starts high spin when money is put in
It's A You Drain Pump is bad. What a guy! He did not know that!? Replace the drain Pump and it will a Happy washer again!
Jan 19, 2014 | Maytag Washing Machines
Need instructions for replacing and wiring Motherboard
Luckily that is pretty easy with modern motherboards.
1. Remove power and unplug all devices hooked to computer.
2. Open case.
3. Write down the location and orientation of all wires connecting to old motherboard.
4. Disconnect all wires from the case that are plugged into old motherboard.
5. Uncrew the screws holding the motherboard in the case.
6. Carefully remove old motherboard.
7. Install new motherboard and secure it to the case (probably using the same screws as the old MB)
8. Refer to diagram you made earlier to plug in all the wires to the proper places in the new motherboard.
9. Check and make sure the new motherboard works before closing the case.
10. If everything is working correctly, close up the case and you are done.
Nov 10, 2013 | Computers & Internet
My Cisnet PC has a new motherboard (only been used 5 months) and has froze up on me twice the last week...it won't turn on again unless I let it sit overnight...this last time, though, nothing com
Could be a possible hardware problem. When you say new motherboard, was there an issue with your old one? Were you given the exact same model?
Also, maybe an issue with your power supply.
Oct 19, 2012 | ZT Group Cisnet PC Desktop
MAYTAG MAF 1260 washing machine is too noisy
galas
  • membawa
  • kaitan
  • ')" onmouseout="ht(this)">bearing
    in emparan
  • pemusing
  • ')" onmouseout="ht(this)">centrifuge
    tong
  • gendang
  • dram
  • ')" onmouseout="ht(this)">drum
    telah berpatah
  • sudah memecahbelahkan
  • ')" onmouseout="ht(this)">already break
    jatuh
  • rendah
  • ke bawah
  • ')" onmouseout="ht(this)">down
    or galas
  • membawa
  • kaitan
    dalam motor')" onmouseout="ht(this)">in motor
    Nov 20, 2010 | Maytag Washing Machines
    I have a dell xps 1210 the cooling fan stopped working I replaced it with a new one and it still won't work
    The motherboard may have several 3-pin connectors, for installing fans in different places. Connect the cooling-fan to one of those "alternate" connectors, and start-up your computer, to see if the fan spins.
    Try a different power-supply.
    Try both the "old" and "new" cooling-fans in a different motherboard, to see if they spin at all.
    Oct 23, 2010 | Dell (6F858) Cooling Fan
    System will not start up. Cpu fan spins once, then nothing.
    It is more than likely that when your old power supply died a death, it damaged some components on the motherboard. Replace the Motherboard and chip, and you should be back in business. You can pick up some good value bundles to save money on buying the parts seperately. The power supply working again after turning off and on, is because there is a little trip in the power supply that triggers when it detects a fault. Powering down resets that trip allowing it to try and work again.
    Mar 05, 2009 | MSI K7N2 DELTA2-FSR NVIDIA nFORCE2 ULTRA...
    I have a 20 year old Maytag washer. It is in EXCELLENT condition. We have never had a problem with it! A few weeks ago, the spin cycle began to have a growling noise resembling a bearing. It sounds like a...
    Your old Maytag is a much better machine than the new Maytag's, but replacing the drum bearing and seal is a somewhat expensive and rather difficult job, requiring a couple special tools. Not usually a do it yourself job. Unless you really love that machine, it's time for a new one. The average life of a washer is about 9 years. Look into the front load models which use much less water and spin out over twice as fast as your old top load machine. LG is the top rated by consumer reports, but you don't have to buy the top of the line models to get the the direct drive motor with 7 year part warranty. Other companies make a pretty good product also.
    Don't bother rating this "solution" as anything but a FixYa lowers my rating.
    Dec 01, 2008 | Washing Machines
    Maytag jetclean EQ plus dishwasher
    I had the exact same problem. When the service tech came to look, my husband watched him. There was a disconnected wire to the motherboard which my husband asked can't the tech just reconnect it. The tech stated no, we needed a new motherboard. My husband reconnected the wire using tape for now & the dishwasher is working perfect. My husband is going to get somekind of calk/glue that will work permanently. This should save us from replacing the motherboard for a while. The dishwasher is only about 5 years old! My previous dishwasher was over 20 years old with no repair problems the over 10 years that I owned & used it.
    I am looking for the self check test, does anyone know where I can find the instructions how to do it myself? Thank you
    Sep 20, 2007 | Dishwashers
    Washing Machines Logo
    83 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
