Question about Maytag Washing Machines
Door on maytag front loader washer won't line up
    President:
  • 1,554 Answers
Proper advice cannot be given without the exact model number of the washer, please indicate it. You don't have to accept or reject and rate this post to add information or post comments and follow-up questions. Accepting a solution does not stop you from posting comments or follow-up questions. You can continue communicating with an expert as long as you need assistance regarding the issue stated herein.
Posted on Jul 09, 2010
I have a Maytag 3000 front loader. It looks the wash is done but I cannot open the door
Unplug the power. Wait 2 minutes, then reconnect the power. You should be able to open the door.
Alternatively, you can UNPLUG the washer and remove the bottom front service panel. Carefully reach up along the inside of that front panel and pull down on the manual release tab that is on the bottom of the door latch assembly. You should then be able to open the washer door. If this doesn't work, you will need to call Maytag for assistance.
Apr 19, 2017 | Maytag Washing Machines
How do I find the door release card for maytag Neptune front loader
you need to feel under front lip of soap door and pull green line to unlock
Sep 10, 2014 | Maytag Neptune FAV6800AW Top Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
My maytag washer stoped during the cycle with 8
You may have blown the internal fuse located in the lid switch. Could be you over loaded the washer and blew the fuse.
Unplug the washer and remove the four screws holding the control panel front in place. Two screws on top and two screws under control panel.
Remove the control panel and tilt forward.
Locate the lid switch assemble and remove glass fuse and inspect.
Door switch assembly should be replaced. When you order the proper fuse it should come with the door switch assembly.
Replace assembly. Reinstall the front control panel and four screws.
Plug machine in and test.
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
No power; washer full of clothes; door locked.
check your power cord...you may need to replace it...or just tighten the screws that hold it in place. It is very easy to do, if I can do, so can you!! You can order a part on line or from a local repair shop.
Jul 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
Mar 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Washer Door Locked
INSIDE THE SOAP LOADER THERE IS A LIME COLOR STRING PULL IT WILL UNLOCK LATCH
Apr 18, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
16 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
