Question about Timex 27191 Wristwatch
How do I put the back on a timex watch after I replaced the battery?
  • 831 Answers
Depends on what type of back it is. Is it a pop on? If you cant pop back on, may need to go to a jeweler. They have a watch press that allows you to get the back back on.
Posted on Jul 21, 2010
How do you take the back off a watch?
The easiest way it to take your Timex watch to a jeweler who will demonstrate how to remove the back and may be persuaded to install a replacement battery - all for a reasonable sum.
Feb 20, 2018 | Timex Watches
What's wrong with my watch?
New batterys can go bad, that is why they have a warranty. Replace the battery
May 16, 2014 | Timex Expedition Watches
Hello, I just bought a Timex Acqua with Indiglo
Depending on when you bought your Timex, you shouldn"t need a battery just yet, your Timex came with a good battery. Look under the stem (winder) for a small piece of plastic that is not allowing the stem to go all the way down, remove that piece of plastic and push the stem down and your Timex will start. Or if your Timex has buttons, look for a tab of plastic on the back cover, this tab of plastic is keeping the battery from (ground) a complete circuit remove this tab of plastic to start your Timex. Changeing the battery while fairly easy, you"d need jewelers screwdrivers and of course the new battery, Best Bet, look for a small watch repair shop in your area for the battery change.
Aug 18, 2010 | Timex 2J611 Watch
My timex watch back wont close, it fell and popped open, I put battery back in place but now wont close, jeweler tried closing it with machine thing, it wont close.. it has gray leather band with...
If the jewelers equipment will not close it, you have only one option, you must send it back to the maker (see the Timex web site for your nearest service center).
They should be able to fix it. It could be that the watch IS dented (it wouldn't take much to ruin the fit).
Discuss your problem with the service center before sending it to them.
If the maker can't fix it, then you could always use impact adhesive but you would not be able to replace the battery when it dies. No watch later might be better than no watch now!
Jun 15, 2010 | Timex Expedition47761 Wristwatch
Putting back on timex watch
There is a press to put this back on.
RECOMENDATION:
Seek professional help.
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
Mar 11, 2010 | Bulova Watch
My watch needs battery evry 15days
Your problem may be that the back MUST be replaced in exactly the same orientation as it was removed. On mine the lettering on the back must oriented so as to read with the top at 12 O'clock. In other words, if you look at the watch face with 12 at the top (normal) then rotate to the back and place the back on so the words can be read. I hope this makes sense. Top of the words on the back must be exactly at 12 O'clock
Apr 17, 2009 | Timex Expedition 84601 Wristwatch
Timex Men's Digital Expedition Chrono Alarm Timer Watch battery
hi
please follow the steps to change the battery
  1. Step 1 Make sure the little arrow on the back is aimed to the right. Then, insert a small flat head screwdriver into the notch on the edge, and lever the back open. Place the back to one side.
  2. Step 2 Unscrew the clip holding the battery (if your model has a clip), and remove the battery.
  3. Step 3 Use plastic tweezers to put in a new battery. Do not directly touch the new battery. Screw the clip (if it has one) back on.
  4. Step 4 Replace the gasket that seals the watch. Then lightly coat the gasket with a silicone-based grease.
  5. Step 5 Align the back with the little arrow aimed to the right again, then carefully press the watch between two pieces of wood that are being held by a small vise, until the back seats itself.
thank you....
Apr 08, 2009 | Timex T41091 Expedition Watch
Timex expedition compass battery replacement?
hi
i am not an expert in this particular case but i followed theses below steps . here are they.....
Unscrew the case back with a case back tool (aka Jaxa wrench) which engages
the notches in the case back. I'm assuming the watch has a screw back - if
it has notches it does. Pop out the old battery.
In some watches you have to
unscrew a clip but in most the battery pops right out. Examine movement for
evidence of battery leakage or other damage. Carefully clear away any crud
at the edge of the case - the tiniest metal shaving will short out the coil.
Install new battery of same type. Handle new battery with non-metal tweezers
or rubber gloves, never bare fingers. Inspect case back gasket or preferably
just replace it with new o-ring of same size. Gasket should be lubricated
with silicone grease. Reinstall case back using wrench. If you are
concerned with water resistance the watch needs to be tested in a pressure
test machine. I'm sure the pros have more tips but this should suffice for a
Timex where it would not be a big loss to damage or break the watch.
i hope you can successfully replace the battery
thank you
Sep 06, 2008 | Timex Digital Expedition watch
Have timex watch had battery replaced and watch quit working, she had to use clamp device to instal battery
If you had the battery replaced, I'm guessing that the watch wasn't working when you brought it in for a new battery. It may not have needed a new battery. You might need a new watch. I've never heard of anyone needing a clamp for a Timex digital watch. In my experience, they use phillips screws to hold the back to the case. I have a case press for snap-on backs, but that's still unusual for a Timex unless it has a BIG case. I think your watch was shot before you replaced the battery.
Apr 26, 2008 | Casio Atomic-Solar Watch GW300
Timex 27191 Wristwatch Logo
181 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
Vladimir Frolov
Are you a Timex Watch Expert? Answer questions, earn points and help others
