Question about Goldstar WG8000 Air Conditioner
The air is still being cooled but the cooling has been decreasing. the fan and other functions are all working well
  • peter weldon Jul 09, 2010
    yes it was succesful thank you
  • 767 Answers
Hello my name is Heath it will be my pleasure to assist you. What you need to do is turn the unit off, check the filter inside and be sure its clean, Next with a garden hose set to a strong jet blow water through the back side of the outside coil where the warm air is dissipated. What happens is the outside coil gets plugged with dirt and debris and gives off less heat and decreases cooling capacity.
Posted on Jul 09, 2010
My breezair evaporative cooling can not cool.
Maybe you're expecting too much. Evaporative cooling doesn't work really well. It's function depends on evaporating a lot of water into the air. If the air in your room doesn't have a really low humidity (really dry air), then evaporation can slow way down or even stop regardless of how fast the fan is blowing.
Jan 02, 2015 | Heating & Cooling
Top oven fan wont turn off unless I turn the cooker off at the mains
Cooling fan has the function to protect kitchen furniture from excessive temperature. The fan will cool the oven even you turn it off (not unplug from wall socket). This will happen only after the temperature decreasing below 70 degrees. If this does not happen then is faulty thermal cut-out which is located between wiring on the top and has 4 pins.
Dado
Sep 19, 2014 | Zanussi Ovens
Engine cooling fan only works when ac or defrost is on
if engine at long stand still,the engine temperature will rise about 190 degrees the cooling fan suppose to automaticaly turn on when coolant temperature sensor get hot it cause its resistance decrease causing pcm to send power to coolant fan relays and cooling fans, when you turn on AC the cooling fans suppose to turn on to cool down AC CONDENSOR, IF NOT AC WONT WORK COOLING FAN COOLS DOWN REFRIGERANT SO IT CAN RECYCLE THROUGH THE SYSTEM AGAIN.your cooling is suppose to turn on when engine at a sit still if vechicle not moving as coolant temperature rises at a set point the cooling fans will turn on cool down engine.cooling fans dont turn on when you first cold stsrt vechicle unless you have AC SWITCH ON.if cooling fans dont turn on when vechicle at a long stand still or moving along slow traffic.if coolant temperature sensor been replaced and fuses and relays okay have dealership check see if pcm driver circuit working faulty pcm will cause cooling fans not to turn on.
Sep 27, 2012 | 1996 Buick Century
We have bought a house with on old air conditioner and no handbook. What are the symbols on the remote for heat and cool please? ie. How can I tell which is which?
Fan mode- 3 leaves of fan.
* synbol for cool
Symbol of sun refers Heat
< or > temp increase or decrease
on/off button refers for switch on or off.
Hope it's helpful msg?
Dec 21, 2010 | LG Heat cool Window Air Conditioner
Hp slimline cooling fan is always running
there is not really an answer for this question.
your machine has fan o fans running all times to avoid the CPU from over heating and BURNING, you see how compact it is. consider this. how much heat will come from the CPU, hard drive, GPU, RAM sticks and cd/dvd drive, ahve them all working and not cooling system at all your pc will overheat in less than 20 minutes.
Oct 07, 2009 | Computers & Internet
Air conditioning not working 100%
You may want to have the evaporator (the AC part under the dashboard on the passenger side) cleaned. It needs to be taken out and cleaned. Normally this would solve the issue. Have the freon checked if there is a decrease. You may have it filled up and have the system checked for leaks.
Jul 26, 2009 | 2004 Audi A4
Fridge warm not working, freezer working maytag model 1956GEQ
the Freezer Fan needs replacing. This fan supplies air to the freezer and the refrigerator. If it is rotating to slow it will not move enough air to cool refrigerator but will still keep the freezer cold. That is why the diagnostic is so hard to detect, because on average when the DC motor on the fan deteriorates the rpms decrease. Replacing the fan is labor intensive. The fan cost is about $80.00 for the part.
Jul 12, 2009 | Refrigerators
Car runs hot at an idle. turn on the air and the fan comes on and cools off . does the ect control the fan function when the air is off? 1994 camaro 3.4.
The Cooling fan is Wired in in such a way so as to Automaticly Turn on Cooling Fan If the A/C is Switched ON. If "WITHOUT the A/C on" The Cooling Fan Doen NOT come ON Untill Engine. is @ 210-230 Degrees
There IS a Problem with the Engine COOLING SYSTEM, A Faulty Coolant Temp Sensor Will Cause this Problem. The Cooling fan is Also A Candidate For Testing.
Answering your Quwstion YES The Engine Coolant Temperture Sensor Tells the ECM What the TEMP Is and the ECM Grounds the Cooling FAN Relay to Turn ON Cooling FAN. Temp Sensor is the Usual Culpret, BUT Relay Comes in a CLOSE Second. Hope this Helps !!!
Jun 15, 2009 | 1994 Chevrolet Camaro
Cooling fan not working
The fans only run when the engine reaches approxminatly 235 degrees F. on the guage that is near the end of scale just before guage show "HOT" I don't think you have a problem, allot of folks out there don't know about this.
Jul 30, 2008 | 2000 Pontiac Grand Prix
Goldstar WG8000 Air Conditioner Logo
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
