Question about Saeco Coffee Makers & Espresso Machines
GRINDER MOTOR FROM MY SAECO ODEA GO,DO NOT START
TIPE OF GRINDER MOTOR TRIAC FOR SAECO ODEA GO
  • 1089 Answers
SOURCE: Saeco Italia Sup021 YR flashing red malfunction light
HI
If you don't hear the grinder motor, I would say you have a disconnected grinder wire. These motors are DC so make sure that you connect it correctly or your grinder will run backwards.
Posted on May 30, 2009
EsWorld
  • 1618 Answers
SOURCE: Hi i have a grinder problem with my Saeco Odea Go
Try this remove all the beans using a vac cleaner, then turn to lowest-finest number, then remove screws on grinder lift chamber and turn knob to coarsest setting and reassemble and try machine, remember to adjust grind when machine is grinding.
Posted on Sep 17, 2009
EsWorld
  • 1618 Answers
SOURCE: Saeco Odea Go - slow to brew coffee, comes out of steam valve
The steam valve needs to be replaced, because the pins have been damaged from high pressure buildup, could have been caused from a very fine grind. You can also check the screen in the brew unit that might be blocked and causing the high pressure backup.
Posted on Nov 15, 2009
  • 81 Answers
SOURCE: New Saeco Odea Giro machine not working
That is the machine is saying to empty the drip tray, pull out the tray on the side and wait until the red light start flashing then put back the tray.
Posted on Jan 21, 2010
  • 81 Answers
SOURCE: I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
Posted on Mar 28, 2010
Saeco odea giro plus not grinding. motor stops.
first try to clean the grinder,if you can to disas?emble the top cover of the machine. Or you have to buy new motor for the grinder.
Oct 24, 2017 | Saeco Coffee Makers & Espresso Machines
My Saeco Odea Go coffee machine grinder screw rotates with on beans but does not rotate when beans are added. Motor sounds like its working.
There are different possibilities for your problem. First the motor might be damaged and is more weak than before that is why is stop when it need to grind beans. In this case only with replacement motor can solve the problem.
Second probably due to long use of oily coffee or low quality coffee beans or other reason there are coffee grounded in the grinder that become like rubber and does not leave the new coffee to pass through grinding burrs. For this either you have to dismantle the whole grinder and its burrs and clean them with brush or you can use a new magic product that you can fin in eBay it can clean automatically the grinder in 30 second see it at the link
http://www.ebay.com/itm/PULY-GRIND-COFFEE-GRINDER-CLEANER-CRYSTALS-20-GRAMS-PACK-OF-3-PACKETS-/131031511160?ssPageName=STRK:MESE:IT
You can try the above fist and you may solve the problem in minutes if not then you can proceed with the replacement of the ginder burrs or motor.
Jan 10, 2015 | Saeco Odea Go
Saeco odea grinder turns but no grounds
The exit from the grinter to the grup it is blocked.There is a plastic tupe that it is probably broken.To clean that tube and exit you must unscrew the machine and remove the top side of the grinter.
Apr 02, 2014 | Saeco Odea Go
Saeco grinder
Maybe the piece that direct cofee to brew group it is missing, so all cofee fall down.
Oct 04, 2013 | Coffee Makers & Espresso Machines
Hi i have a Saeco Odea Giro Plus, that was broken ceramic baked klay. after replace new it have a problem with my Saeco Odea Giro. The problem is that the bean grinder doesnt grind (I only hear sound of...
you need to change this part ,which is under the ceramic knife. You will have to open the coffee grinder and take out the knives and change the holder to the lower knife. That's your problem. This is the product code 149198350
Apr 22, 2017 | Saeco Odea-Giro Espresso Machine
Grinder problem
try to check the brew group
Jun 18, 2012 | Saeco Odea Giro Plus Coffee Maker
Mar 23, 2010 | Saeco Odea Go
Sep 10, 2009 | Saeco Odea-Giro Espresso Machine
Saeco odea go
Try to use another brand and more dry coffee.
Apr 10, 2008 | Saeco Odea Go
Coffee Makers & Espresso Machines Logo
101 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
