Question about Whirlpool Dryers
Unable to set Control On. Have checked power. Power is sufficient, but I am not able to get any lights to come on, except to lock or unlock system.
  • 36 Answers
Hold the key lock button in for 5 seconds.
Posted on Jul 09, 2010
The code cl keeps coming up and the washer will not shut off
CL is child lock. Press and hold the child lock button(maybe a key icon) for three seconds to unlock
Mar 23, 2015 | LG WM2455 Front Load Washer
Tip
The front light lit on my Whirlpool dryer is showing control locked
Hi.
If the front light lit is control locked, that means that your Whirlpool electric dryer had been set in control lock mode.
Control lock is a special mode that will prevent user from changing settings or using control until the dryer gets unlocked again.
The machine is set to control lock mode by holding down the CONTROL LOCK/UNLOCK button for several seconds. In the same way you can stop the control lock mode when the machine is already set to Control Lock.
When the dryer is running and Control Locked is on, the dryer can still be stopped by pressing the Pause/Cancel button, but cannot be restarted until the control is unlocked.
If the front light lit is control locked but the dryer door opens and it does not turn off, then you are probably in this situation. In that case, the door will be opening , but the machine still stays locked.
Disconnecting the machine from power, either unplugging power cord or tripping circuit breaker, won't help. The control lock system is designed to stay on in case of power failure.
If the machine is control locked, try unlocking it with the following procedure.
To unlock: Press and hold the CONTROL LOCK/UNLOCK button for 3 to 5 seconds to turn the control lock feature off.
If that does not work, try disconnecting power for five minutes to reset the machine, and eventually do unlock again. As said, cutting power alone will not cause the machine to unlock.
If the machine is still not responding, the lights stay on all the time, the dryer panel does not respond to control unlock procedure, and the door does not lock anymore, then it may be a defective control board.
If you are in this situation, before replacing the control board more parts, including the door lock must be tested. In that case the best option may be contacting the Whirlpool support number listed on the Dryer use and care manual, usually in the last pages.
In this case try resetting control lock as explained above, as told the dryer is more likely control locked and then stopped.
Regards.
Ginko.
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
Similar electrical issues with driver's side door controls. Power locks, power window, and power mirror on driver's side are not functioning. I can manually unlock the door, but the buttons on...
CHECK FUSES FOR POWER WINDOW,CHECK FUSE FOR POWER MIRROR AND CHECK FUSE FOR POWER DOOR LOCK.IF FUSE OKAY DOOR CONTROL MODULE FAULTY ITSELF.
Sep 11, 2011 | 2004 Saab 9-3
My 37" LG LCD TV will not turn on and it has a flashing red light on the front at the bottom. I cannot get onto LG's website and there is nothing in the manual that addresses this problem. Any...
Two possibilities: the better one is that some joker put the set in demo mode (which includes a flashing power light), then turned on the Key Lock feature and turned off the set.
To check for this (quoted from page 118 of the manual):
Oct 24, 2010 | LG 37LG30 37 in. LCD HDTV
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
Control lock light is on.
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. This can usually be reset and does not require a technician.
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, leaning against the control panel, or pressing and holding the wrong button. This is usually not an indication of a malfunction.
If this is a Whirlpool manufactured front loader, the following link explains how to lock/unlock this feature:
http://www.fixya.com/support/r3608801-control_panel_lock
These instructions are also printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control button issue (such as an operator console problem or main control board issue). Please post back and let me know if you need further assistance. I hope you find this information helpful.
Apr 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Contol Lock
With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, or by leaning against the control panel and is usually not an indication of a washer malfunction.
If this is a Whirlpool Duet series, the following link explains how to lock/unlock this feature:
These instructions are printed on the front panel of the appliance and in the owner's manual.
If this does not correct your problem, then you may have a more serious problem than a simple operator control issue (such as an operator console problem or main control board issue). If you need further assistance, please post back and let me know. I hope this corrects the problem for you.
Mar 29, 2010 | Whirlpool GEW9250 Electric Dryer
Control is locked , unable to start the dryer, the light of the control is on, and it says control locked
The Control Lock is actually a safety feature that enables the consumer to lock the control panel to prevent small children from manipulating the controls and accidentally starting the appliance. With the lock on, the control panel is disabled and you cannot use any of the controls, except the button to unlock it. It can inadvertently be set following a power outage, or by leaning against the control panel and is usually not an indication of a washer malfunction.
Mar 25, 2010 | Whirlpool Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
