Question about Hotpoint Freezers
High temperature light keeps coming on - Hotpoint Freezers
  • 382 Answers
Dear sir/madam please make sure your freezer,s door all is close and watch if its light coming again then there is one componennt temretuture sensor its needle need to reset or change.
hope problem will be solve.
thank you
Posted on Jul 09, 2010
Red light showing high tempature
cooling temperature of freezing is damaged and also damaged heater machine which keep in deep freeze but controller point keep in normal side,you must be repair that problem as soon as possible otherwise full freezing system get damaged.
Mar 22, 2013 | Frigidaire Freezers
Hotpoint freezer FZA84 does not freeze ,high temperature light is on. when switched on the temperature comes down to about -12 C . does not come any lower but i hear a irregular hissing sound probably
You need to cut it off. You may be doing a lot of damage there. If this freezer is 8-10 years old, you may want to go ahead and replace it. At least it will not give you any more problems.
Jan 25, 2013 | Hotpoint Freezers
Does the green light come on after freezer is turned back on?
if you turn the freezer off for some time then on again the red light has to come on as an indicator for high temperature it goes off by itself when the freezer attains the required temperature according to the thermostat settings ,that is the lower the settings the faster the red light goes off. the orange light indicates super cooling and the green light indicates power supply.if you turn the two lights off and the freezer still works without the green light on that means that the bulb for the green light is faulty and you don,t need to worry
Jan 23, 2013 | Freezers
My Electrolux upright freezer Model GLFU1467FWO Serial No WB61740462 ..the temperature warning light kept going off, so kept resetting it, now there is no temperature light at all, the freezer is stil
Check the condenser grille is clear and clean, and all fans are working. Get a cheap thermometer to keep in the freezer and check it from time to time.
Jul 21, 2012 | Electrolux Freezers
Proline chest freezer - the alarm light has come on. What does this mean and what needs to be done to get things back to normal. Thanks
hi this normally means the temperature got too high, could have a cooling problem or somebody had the door open too long.
Sean
Mar 26, 2011 | Freezers
High Temperature Light
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 11, 2010 | Hotpoint 3.6 cu. ft. / 102 liter Upright...
Freezer high temperature light won't come out so my freezer is not working
Going to guess you have a thermostat issue, not a faulty light issue.
Oct 24, 2009 | Freezers
Case lights and fan do not come on, ''H'' appears on digit readout
This sounds like a refrigeration problem. On most freezers there are temperature switches that control the interior fan and light. The fan and light will not come on until the temp switch senses that the evaporator coil is at freezing or below. The "h" is a "high temp warning I would gues. :)
Sep 13, 2009 | Freezers
WHIRLPOOL UNDER WORKTOP FREEZER APPROX 11 YEARS OLD BEEPING
the temperature control is bad. when you push the fast freeze it bypasses the thermostat for 12-24 hours depending on which model you have. I am not able to find any parts information with the model number provided but you should be able to find a temperature control at any local appliance parts house or online thru any reputable supplier. Thnaks Peyton
Feb 24, 2009 | Whirlpool Freezers
Freezers Logo
148 people viewed this question
Top Hotpoint Freezers Experts
AJMAL KHAN
Victor Nwachukwu
Victor Nwachukwu
christian nielsen
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
