Question about GE 17.9 Cu. Ft. Top-Mount Refrigerator with Internal Water Dispenser - Stainless-Steel
Found water on the bottom of the refrigerator
Refrigerator Model TBX21 KM BRAD had collected water on the bottom to the extend that it spilled on the floor. Where did the water come from and what do I do about it?
dididsaythat
  • 291 Answers
SOURCE: Water problem
Sounds like the  drain for the defrost system is plugged....
Posted on Oct 11, 2007
  • 212 Answers
SOURCE: How do you unclog the condensation drain on a GE
usually the drain hole underneath the evaporator in the freezer section can restrict with anything from ice to bugs. take a wire hanger and try to run it all the way down into the drain pan. if you have ice then try to poor cool water over it to defrost ice. then use hanger
Posted on Jun 22, 2009
Sea Breeze
  • 4654 Answers
SOURCE: My GE refrigerator collects water under the
This is a common problem when the defrost condensate drain becomes blocked. Below is a link that tell more about what is happening. Sea Breeze
- This is when it leaks into the fresh food section.
http://appliancejunk.com/forums/index.php?topic=22.0 - And this link is when it's cause in the freezer section.
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
Posted on Jul 25, 2009
aasc
  • 1606 Answers
SOURCE: GE REFRIGERATOR SPILLS OUT WATER COLLECTED BELOW
Remove the food from the freezer . Remove the rear freezer panel , inside the freezer . At the base in the rear , use a hair dryer and defrost (you'll see a drain hole possibly in the middle of the drain ) . Defrost drain hole until hot water can be poured and go thru the hole . I use a small hose to blow thru the drain hole to remove any debris which could have accumulated inside the drain line .
Posted on Aug 02, 2009
MNTECH
  • 1543 Answers
SOURCE: I have a GE refrigerator
This is a rather unique refrigerator in that there is a seperate evaportator (cooling coil) for the refrigerator section and the freezer section, where as almost all other refrigerators only have coils in the freezer section and use a fan to blow some of the cold air into the refrigerator section. This design will prevent cross contamination of odors between fresh foods and freezer sections, and allow lower humidity freezer at the same time as higher humidity fresh foods. All good things.
That said,..... you need to take the cover off the back wall from inside the fresh foods section and thaw out the defrost drain locted at the bottom of those cooling coils. If I remember correctly, there are a couple hidden screws, and the back panel needs to be pryed off using a putty knife, I think you will find 4 small arrows / pointers for the spots to pry at. With cover removed, use a turkey baster with warm water until the water flows out the drain.
Posted on Apr 03, 2011
RF261BEAESP
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
Apr 15, 2014 | Samsung RF261BEAESP 25.5 cu. ft. French...
Water collecting on floor under the refrigerator
The evaporator pan in the bottom of you refrigerator may be out of place, damaged or missing. there also may be a problem with the drain tube being bent and not dripping into the pan. It is also possible that the drain tube could be clogged and water could be collecting in the bottom of the refrigerator and spilling out too.
Jan 10, 2014 | Refrigerators
Water leak at the bottom of the refrigerator
Jan 10, 2014 | Samsung RF265AA Bottom Freezer French Door...
I have a frigidare 20.6 frig. approxiamately 10...11 yrs old im find water puddles on top glass shelf and bigger puddles at the bottom I cleaned as much as I could the fan is working help model...
Hello Donna, I am happy to assist you. I understand that water is collecting in your refrigerator. Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
I certainly hope this troubleshooting tip resolves your concern. If you have any additional questions, please feel free to respond.
Aug 03, 2013 | Frigidaire Refrigerators
Water collects on the bottom of the refrigerator
Jul 11, 2009 | Refrigerators
Water is collecting in veggie bins in
I can solve your problem for you.
Self-defrosting refrigerators dispose of the water generated during the defrost cycle, usually via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
Water problem
Oct 10, 2007 | GE J Series 20.6 cu. ft. Top Freezer...
Water in Freezer bottom
drain line is blocked check bottom tray if is collecting water if not drain line blocked
May 10, 2007 | Maytag MSD2754G Side by Side Refrigerator
GE 17.9 Cu. Ft. Top-Mount Refrigerator with Internal Water Dispenser - Stainless-Steel Logo
67 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
