Question about Husqvarna Garden
I need to know how to attach starter rope on a chainsaw
I need to know how to install starter rope nott on husqvarna 154se 1984.
there is a special way of attaching rope, but can't find any diagrams showing how.
    Brigadier General:
  • 4,088 Answers
The end-of cord knots are simple overhand knots, but you need to melt the cord ends back a little so that the knots won't pull out (do the outer end after threading the cord through the handle). You have to wind up the spring so that it has good 'pullback', but not so far that the spring binds-up when trying to start the engine. Wedge the spool so that it doesn't unwind, then run the cord into the spool, heat the cord end, and tie the knot. Fish the cord around the spool in a CCW direction until the spool is nearly filled. Thread the cord out through the port on the outside, then slide on the handle, heat the cord end, and tie another knot. Hope this helps!
Posted on Jul 09, 2010
I replaced the starter cord on a Husqvarna 55 rancher chainsaw and when I reassemble the starter won't turn. Any ideas?
Is it possible that the crank shaft seized first and caused the pull rope to break?
Nov 21, 2015 | Husqvarna Garden
Starter rope only pulls out about an inch, then is locked
Better take the cutting blade off and see if u can turn the motor over by hand. It may be seized. Or take the pull starter off to see if the rope is fouled.
Nov 03, 2015 | Husqvarna Garden
How do I put a new pull rope on my 5hp MTD Chipper?
pull the starter cover pull rope out to length lock the housing the rope is in, in place with a tool pull out rope. reinsert new rope into retaining hoe tie a not and cut off excess rope. put ropr through handle hole reattach handle and remove tool you used to hold the rope housing. This is if your spring and starter assembly are ok. Or you could stop being a cheap and let a shop do it for 5 minutes labor.
Jun 29, 2014 | Husqvarna Chain Saw 20" Bar
Pawls don't catch on rancher 455
The starter pawls are held on with small springs. If the springs are broken or installed incorrectly, this can happen. I would suggest replacing the springs and maybe the pawls. Check the recoil assembly to make sure the issue is not with the recoil assembly.
Feb 08, 2014 | Husqvarna , No.455 Rancher, 20" Gas -...
Starter rope grabs at times. why?
try using the de-compression button when starting, will do the same as removing the spark plug but without removing the spark plug.
Failing that, remove the starter cover and check starter cord for daage or signs of snagging.
Feb 03, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a Husqvarna 338. I'm having difficulty re-installing the pull rope. Is there a trick to it or a special tool.
There are no special tools required,with the pulley still connected its just a matter off threading the knotted rope through the starter pulley hole, hold the rope on the side of the pulley and turn the pulley to wind up the spring, allow the pulley to unwind pulling the rope in, with the rope fully extended make sure you still have at least half a turn left on the pulley, this will stop the spring coil binding.
Dec 23, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How to replace pull rope in Husqvarna 136 chainsaw.
Use this as a guide and it is pretty simple
R² Starter Rope by SmallEng.com
http://www.youtube.com/watch?v=eRyy3MlsjVo
HTH
Lou
Dec 21, 2009 | Husqvarna Garden
I have removed the flywheel side of a 371xp husq, how does the clutch side come off? Puller ?
A YouTube video shows the procedure using a Husqvarna 350 here:
http://www.youtube.com/watch?v=cdqkIuVNUQc
1. Look at the IPL it may require special tools.
2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and be cut when the piston rises.
3. It is probably a left handed thread (tighten it to loosen it).
Let us know how it worked for you. GL
Lou
Sep 11, 2009 | Husqvarna Garden
HUSQVARNA model 435 Difficult starting
the problem is in the ignition coil.it needs to be replaced.it is under warranty.its warranty is life time.call husqvarna and they will either send you a new one or send you to a husqvarna dealer to fix the problem.that is at no cost to you..............let me know if this helped.................
Jun 06, 2009 | Husqvarna Forest & Garden No.967012396 345...
Husqvarna 357xp rim sprocket problem
there is a special tool to remove the clutch properly with out damage to the clutch or springs.it is so much easier to take it in some where and have the proper tool used.the tool is $45.00 to $65.00 to buy one.most dealer will only charge you a couple of bucks to remove it and install one for you,it only take a second to do.I,myself have made a couple of differant ones because chainsaw differ so much.let me know and maybe i can get you a picture of the one you need
Feb 07, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
182 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
