Question about Canon iP100 Portable Printer
COMPUTER SAYS PRINTER IS OFF LINE HAVE TRIED MULTIPLE CABLES
COMPUTER SAYS PRINTER IS OFF LINE HAVE TRIED SEVERAL CABLES AND THE COMPUTER STILL DOES NOT SEE THE PRINTER
    Novelist:
  • 113 Answers
did you try uninstalling the printer drivers and re-installing?
Drivers are here:
http://support-au.canon.com.au/P/search?model=PIXMA%20iP100&filter=0&menu=Download
Assuming you are running WinXP go here:
http://support-au.canon.com.au/P/search?model=PIXMA+iP100&menu=download&filter=0&tagname=g_os&g_os=Windows%20XP
If you are using something else like Vista or Windows 7, change the selection at the right hand side of the web page, then select the driver software. Do not select x64 unless you are running a 64 bit operating system. It is highly likely you are running a 32 bit version of XP, Vista or Win7.
Does the printer get recognized on another laptop or computer? If it gets recognized then there is nothing wrong with the printer and cable. In that case, on your computer it's the driver or perhaps you have a dodgy USB port. Can you try another USB port on your computer?
Cheers,
Steve
Posted on Jul 11, 2010
My cannon ip3000 will not turn on, no light appear, I have tried changing the cord and different wall sockets
If you have tried multiple cables in multiple working outlets then you need to contact the manufacturer for warranty or return it to the store.
Aug 21, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
One of the optical ports on my Denon AVR 1705-685 only works intermittently. I have tried several different cables and connected it to several different components. Is it just dirty? Can I clean it with...
Compressed air may help. Also make sure your cable routing doesn't involve any tight bends in the cable.
If you have a coxial option, I'd advise using it as it won't have the bend or length limitation; and the cables for coaxial are dirt cheap and can be extended and shared between multiple units simultaneously as long as only one is turned on and 'talking'.
Feb 17, 2010 | Audio Players & Recorders
Printer USB Cable un recognized DCP150C
You need to isolate the problem. You tried using multiple cables and reinstalled the printer driver several times, but you never mentioned that you tried connecting the printer into another computer. What if the problem is the USB port of the computer and not the printer cable?
Try connecting and installing the problem printer into different computer for testing purpose only. If it work, then the problem is the USB port of the computer. To fix this, try updating the USB driver of your computer.
If same problem occurs using another computer, then you need to contact the manufacturer of your printer. I've heard this problem before and I don't have an update if there's a fix with it.
Have a great day!
Oct 01, 2009 | Brother Office Equipment & Supplies
I keep getting a Printhead missing, not installed correctly or has come loose error. I have tried reinstalling the print head, several times and powering off several times but neither help. Any...
HTML clipboardHi
Here are a few possibilities...
1. Try cleaning the contacts on the print head and where they make contact inside the printer. (use cotton wool and Alchol) if that does not work...
2. Pull out power cable from printer wait 1 MINUTE then insert cable and switch back on again. (some printers reset to factory settings)
3. Remove printer cable from computer... Uninstall Printer driver from computer... Switch off both printer and computer. Wait 1 minute... Reconnect cables and switch on printer and computer... Allow computer to find printer... reinstall driver.
Good Luck!
Tinteiros Magic Inkjet Flush Kits (Ebay)
Sep 12, 2009 | Kodak ESP 5 Printer
Insignia 42" black screen and line problem
Insignia and Geek squad has no other solution exvcept 1080i
Dec 26, 2008 | Insignia 42" LCD Flat-Panel HDTV
Wireless printer doesn't print (HP LaserJet 1320 NW)
GO TO PRINTER MENU AND CHECK THE JOB IN QUE AND CHANGE FROM OFFLINE IT TURNS TO READY
Nov 25, 2008 | HP LaserJet 1320 Printer
Dell 966 not being recognized by computers
It sounds like you were just using the printer as a copier after the damage to the connected computer. If i'm understanding you correctly, you are saying that you have sense then connected it to other computers and with several different cables. Does it power up? If it does it might be worth repairing. Does the computer acknowledge that new hardware was found? If so it just needs a driver. That printer is around $100 bucks. If it powers up and is just the usb port that is out it can be fixed for less than the cost of a new one.
Nov 19, 2008 | Dell 966 All-In-One InkJet Printer
Printer will not communicate with computers
Whenever I have seen this problem it has usually turned out to be one of the solder points on the USB connection in the printer. Of course it could be a logic board problem as well. Well done for testing your problem so thoroughly (eg trying different cables and machines) but I think it needs a repair agent now unless it is under warranty (or you can solder well). Mind you it's probably cheaper to purchase a new one then to pay to have it repaired.
Feb 05, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
Canon iP100 Portable Printer  Logo
215 people viewed this question
old marine
old marine
