Question about Tally T2250 Matrix Printer
Check ribbon when i am switch on the printer. i t's giving message "check ribbon " on display panel.
  • 590 Answers
Remove the ribbon along with its fitting from the printer and fix it back. Replace the ribbon, if in case worn out or used excessively or stuck within.
I hope this fixes your problem.
Posted on Jul 09, 2010
Bought a DTC520 and replaced Printer ribbon and now message reads " No Printer Ribbon Installed" Used Part # 86031 DTC500-YMCKO I powered down machine and started again, still NO Ribbon...
You have to check which ribbons are loaded.
Depending on that you have to select the appropriate mode in the driver else it'll keep giving this message.
Y = yellow
M = magenta
C = cyan
K = black
O = overlay
May be you don't have overlay loaded
Aug 15, 2011 | Fargo DTC515 Thermal Printer
My printer show the error 99 Ribbon Break/Jam but the ribbon is ok is not broken and i can not see some jam. Can you help me
Pls do the following:-
Ribbon Break/Jam
(PC Error Message No. 99, 108 and 109)
The Ribbon is not able to find the next panel correctly. Check for jams/breaks.
If jammed, clear the jam. If broken, repair by taping the Ribbon back on to the take-up core.
Press Resume to continue or Cancel to abort.
Thank You...........
Jul 26, 2011 | Fargo HDP5000 Thermal Printer
Good morning. my printer will not calibrate. Could you please help me out?
Perform a Manual Calibration:
Perform a media and ribbon sensor calibration to reset the sensitivity of the sensors so the
media and ribbon are detected more accurately. If you change the type of ribbon or media,
your printer may operate better if you perform this calibration.
Calibrate Media and Ribbon Sensors
Use this procedure to adjust the sensitivity of the printer's sensors. In a
printer that has the Thermal Transfer option installed, both media and
ribbon sensors are adjusted. In a Direct Thermal printer (no Thermal
Transfer option installed), only media sensors are adjusted, and the LCD
displays for ribbon do not appear in this procedure.
Important • This procedure must be followed exactly as presented.
All of the steps must be performed even if only one of the sensors
requires adjustment. You may press the left arrow at any step in this
procedure to cancel the procedure.
How to select this parameter:
1. Press ENTER to start the calibration procedure.
The LOAD BACKING/REMOVE RIBBON prompt displays.
2. Open the printhead.
3. Remove approximately 8 in. (203 mm) of labels from the backing,
and pull the media into the printer so that only the backing is between
the media sensors.
4. Remove the ribbon (if used).
5. Close the printhead.
6. Press ENTER.
The message CALIBRATING PLEASE WAIT displays.
The printer adjusts the scale (gain) of the signals that it receives from
the media and ribbon sensors. On the sensor profile, this essentially
corresponds to moving the peak of the graph up or down to optimize
the readings for your application.
RELOAD ALL displays.
7. Open the printhead and pull the media forward until a label is
positioned under the media sensor.
8. Reload the media and ribbon (if used).
9. Close the printhead.
10. Press ENTER.
The printer does a calibration; during this process, the printer
determines the label length. To see the new readings on the new scale,
print a sensor profile.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 25, 2011 | Zebra Z4Mplus Label Printer
How do I clear a paper Jam
Try either of the following methods to clear the paper jam. The operator panel displays the Ready message when the jam is cleared.Method A:
  1. Press Paper Rewind until the Paper Empty message appears.
  2. Press Paper Advance to re-load the paper into the printer.
    The printer advances the paper, then cuts and discharges about 24 in. (61 cm) of blank paper. This reduces the possibility of fingerprints or other damage to the prints.
Method B:
  1. Turn off the printer and open the upper cover.
  2. Remove the ribbon from the printer.
    Caution: Prevent damage to the printer. Do not pull abruptly on the paper.
  3. Slowly and carefully pull the jammed paper out of the printer.
  4. Cut off any damaged or printed areas of the paper. Do not damage or mark any of the rollers.
  5. Close the upper cover and turn on the printer.
  6. Press Paper Rewind to rewind the paper into the printer.
    Note: If the Paper Jam message still appears on the operator panel, press Paper Rewind again.
  7. Open the upper cover and reload the ribbon.
  8. Close the cover.
  9. Reload the paper.
Note: If the Paper Jam message still displays on the operator panel, and you are at the end of a paper roll, it is possible that a segment of paper is too short to automatically exit the printer. Remove the front cleaning roller and remove the segment of paper.
Jan 03, 2011 | Kodak ESP 7250 All-in-One InkJet Printer
ERROR 59.06M
This error appears after the message Conditioning Drum is displayed and then after one page is printed. Conditioning Drum occurs approx every 100 pages printed. The 59 errors can appear either after the first message was posted to the front panel or after seven messages were displayed. Power cycling the printer can clear this error in the short term.
but at the end the printer will need service, here are the parts needed to fix the issue,Process cartridge drive assembly and the Ribbon cable between DC Controller and Print Driver
Aug 13, 2010 | HP LaserJet 9500n Printer
Tally 6218 give skip ribbon weld error
Skip Ribbon Weld
Explanation: This is an advisory message. The message appears when
the welded part of the ribbon is moving across the Hammer Bank.
Corrective Action: None. Wait for the ribbon to finish moving, and the message will disappear.
Apr 21, 2010 | Tally T6218 Matrix Printer
15 Volt CTL fail
Hi Serap,
If a fault condition occurs in the printer, the status indicator on the control panel flashes on and off, and the message display indicates the specific fault.
For the operator-correctable faults, After correcting the displayed fault, press the CLEAR key to clear the error message and status indicator and resume printing. If the fault message reappears, contact your authorized service representative.
If a fault is not correctable by the operator, you may try two steps to clear the fault before calling your authorized service representative:
1. Set the printer power switch to O (Off), wait 15 seconds, then turn the printer on again. Run your print job again. If the message does not appear, it was a false indication and no further attention is required.
2. If the message reappears, press the CLEAR key. If the message disappears, it was a false indication and no further attention is required. If the message reappears, call your authorized service representative at 1-800-243-3338.
Message Explanation Action 15V CTL FAIL* Controller voltage failure. Contact authorized service representative.
Call 1-800-243-3338
As far as software for the flash file is concerned , I have checked with their officaial sites , but they donot have any firmware updates.
Thanks
Mar 27, 2009 | Printronix Line Matrix P5010 Printer
Broken ribbon message for my zebra card printer
It could mean that the ribbon sensor on the printer is broken. Sounds like you need to send back to zebra for repair. This is free if printer is still under warranty. check out zebra's website for info on how to return printers for service.
Sep 11, 2008 | Zebra Eltron P330i Card Printer
Tally 2250 Matrix printer
tally printer give hardware alarm on every problem gear aliment is very important in tally cheak for function sensor
Jul 21, 2008 | Tally T2250 Matrix Printer
Tally T2250 Matrix Printer Logo
103 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
