Question about Amana 24 in. ADW862EAS Dishwasher
My amana ADB1500AWW3 control panel has no power
The control panel appears to have no power to it and therefore I cannot start the dishwasher.
4 Suggested Answers
SOURCE: amana adb1500aww3 dishwasher will not turn on
amana dishwasher keypad has power BUT lights are dim and will not work. tried doing a rest and nothing.
Posted on May 11, 2011
  • 3 Answers
SOURCE: amana ADB1500AWW3 dishwasher wont turn
is it plugged in?
Posted on Jun 09, 2011
GodBlessU
  • 3513 Answers
SOURCE: I have a Amana dishwasher
Hi
More likely the problem is a bad control panel. The chance for the control board to be bad is relatively small. Also the most common cause of a unit having no apparent power and not starting is a door switch not closing or the contacts in a door switch not closing.
Please check this link to get a detailed idea related to your issue:-
http://www.repairclinic.com/Dishwasher-Troubleshooting?red=Dishwasher-Repair-Help#itdoesntworkatall
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Posted on Aug 01, 2011
Reset figidaire dishwasher. Control panel not working.
hi david.
not sure if this link will help you out but have a look.
how to Reset figidaire dishwasher Google Search
Nov 01, 2017 | Dishwashers
Managemylife com sears
New problem or old problem? Has it ever worked? First check the main control component and make sure all wires are plugged in.
Sep 05, 2014 | Amana ADB2500AWQ Full Console Dishwasher -...
Amana dishwaser adb1100aww won't start is there a fuse in dishwasher
If you are able to set the wash program on the panel but the start does not produce any action, then the door latch is causing a problem. There is a switch behind the latch that detects if door is shut. If this switch is not closing then dishwasher will not start.
Check items 4, 6 and 9 in this diagram. Make sure the mains power is disconnected as high voltages come to the door panel.
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Dishwasher-Parts/Model-ADB1100AWW0/1268/0130000/W1302287/00002?blt=06&prst=&shdMod=
Apr 19, 2014 | Dishwashers
My new bosch axxis washer was20160uc does not start
Open the dishwasher door if the desired cycle does not perform as selected on the control panel. Press the main power switch "Off" and then "On" again. Select a cycle, press the appropriate button, press "Start" and close the door. Make sure the door is closed completely.
Check the circuit breaker and water supply if the dishwasher does not start after selecting the appropriate cycle on the control panel and shutting the door.
Turn "Off" the dishwasher and disconnect the dishwasher from the power supply if an error code between "E01" and "E30" appears on the digital display. Reconnect and turn the dishwasher "On." This should reset the control panel.
Terminate a program on the control panel by holding the "A" button and pressing "Start" at the same time. The display will read "0:01". Close the door to start the program sequence. The display will read "0:00" when finished.
Oct 15, 2010 | Dishwashers
Amana adb1500aww3 dishwasher will not turn on
Feb 27, 2010 | Amana 24 in. ADB1500AW Built-in Dishwasher
Hi, I have a amana sofsound1 dishwasher. For some
Try turning the power off at the fuse or breaker box. Wait 5 minuites and turn back on. Observe to see if the timer circuite and the door opens.
I hope this helps.
Jan 05, 2010 | Dishwashers
I am gettting a message on my dishwasher that says 1h
I think that the delayed use is engaged.  Wait an hour, and it will probably start up on its own.
Jan 10, 2009 | GE 24 in. Profile PDW7800 Built-in...
Open Questions:
Amana 24 in. ADW862EAS Dishwasher Logo
147 people viewed this question
Top Amana Dishwashers Experts
Cleverer2
Charles T Nevin
Charles T Nevin
Mike
Are you an Amana Dishwasher Expert? Answer questions, earn points and help others
