Question about Alpine CDA-9833 CD Player
No sound output
Can only get sound to the car speakers from external amp connected to the head unit with rca's and speaker wires from it ran to the speakers. will the head unit speaker wires work if the rca's are unpluged? i want to run the car speakers with the head unit and the subs with the amp and rca's??? why wont this unit do that? Is the internal head unit amp bad?
  • steve73601 Jul 09, 2010
    the amp in the head unit is faulty , right? we bought this problem with the car. i don't know if the head unit worked with out a extra amp or not.
    thanks!
  • Alpine Master
  • 6,993 Answers
before it started working only via external amp, was your amp working? If your amp was working, then it means it is faulty for real. A fuse or something might have gone bad inside the amp.
The head unit speaker won't work if the RCA's are unplugged. But it will work if its connected to the external amp.
You can go ahead with your connections to the external amp. Your amp is faulty.
Good luck.
Posted on Jul 09, 2010
    the amp in the head unit is faulty? all works fine with an external amp. but i want to run the car speakers with the head unit onley and the subs with the amp.
  • Walesarumi
    Walesarumi Jul 09, 2010
    Hello
    The head unit should work without the an extra amp. The amp is just there to boost the sound.
    Yes, the amp unit for your car is faulty.
    Take care.
How do I wire external amplifier
In order for this to work correctly you need:
  1. Power wire (with fuse) from battery to amp (+)
  2. Ground wire from amp to car chassis. (-)
  3. remote-on lead from a 12V power source that turns on and off with the ignition if the head unit does not supply a wire. (switch)
  4. RCA connection from head unit to the amp. (sound in)
  5. Speaker wire connection from amp to speakers. (sound out)
It is easiest to start with deciding on the amp mounting location, and then running all the wires. Add an extra foot or so to each wire. You may discover in the process that you have to move things around due to unforeseen obstacles. This extra foot will help in that case. Always attach the ground wire to the chassis first and then to the amp first. Once you have the fused power wire from the battery installed; remove the fuse before trying to attach it to the amp. ONLY re-install the fuse once all connections to the amp are made, secure, have been checked twice and you're ready to test it.. This includes speakers. DO NOT for ANY reason have the amp powered up before attaching ALL speaker connections.
Feb 23, 2015 | Panasonic CQ-C1100U CD Player
Another conundrum
To check for yourself, get an Ohmmeter and see if the outers of the amplifiers RCAs are connected to the ground or each other. If so then it cannot take speaker signals directly.
I suspect the 'High Level' the manual speaks of are the 4volt auxilliary audio signals that can be found on some newer head units, not speaker signals.
Speaker level signals from a bridge amp CAN be used on grounded RCA inputs if the signal is first passed through a simple decoupler and attenuator.
Diagram to explain....
Nov 22, 2007 | Infinity 475A Car Audio Amplifier
How hook amp up to a oem integration SNI-15 line output convertor
The amp needs an RCA input to communicate with the head unit. SOLDER the wires that come out of the head unit for the front speakers to the SNI-15, making sure that the polarity and right/left is correct. Do this for the front and rear speakers if you have a 4 channel amp. Cut the wires if you add new speakers and run the new wire from the speakers or sub box directly to the amp, or skin back the wire insulation and tap on if you use the factory speakers :( then plug your RCA cable from the SNI-15 to the input side of the amp. Don't forget that most new cars have their own amp so you might have to locate it and bypass the speakers wires around it. Don't make a mess in case you have to put everything back to factory for resale. You can avoid all this by installing a new/modern head unit with built in RCA outputs for front, rear, and sub woofer. I hope this helps. Ray
Apr 23, 2014 | Car Audio & Video
I have a jl audio e1200, and everything's been connected correctly. it says that there's power (as indicated by the green LED) but there's no output. what do i do?
Hello codyr25,
First of all, you need to isolate what is causing the problem. No output (sound from the sub) could be a defect in the 1) Wiring, 2) Head unit, 3) Speaker(s), or 4) The amp itself.
Start to systematically eliminate the possible causes. Connect your subs to a known good system. If they work, it's got to be something else. Check the RCA cables from your head unit to the amp. Check the speaker wiring. Check the amp on-board fuses.
Make sure that you have output from the head unit. With multiple RCA jacks, it's possible to plug your cables into an input rather than an output (in the dark, behind the dash). If you have more than 1 set of preamp outs, try another set.
Hope this helps.
May 15, 2009 | Car Audio & Video
LED lights up but! ???
Sounds like there is a problem with the amp. Try switching the inputs around for that output on the amp. If that does not help, Yes I would have to say that there is a problem with the amp output circuit.
Nov 06, 2007 | Infinity BASSLINK Car Subwoofer
Have one wire for audio sub out, but two input ports to amp
This one Wire should be for the +. Try connecting the + to the Head Unit and - to a Common Ground. At the Worst, You will Blow the Amp Fuse if not Correct. The Lead from the Head Unit is Only an Off and On from the Ignition. Please Rate My Response! Thanks!
Jan 31, 2009 | Power Acoustik PTID-8960 Car Video Player
Power on green light is on but no sound when speakers are hooked up
Light is on so suggests power, earth and remote turn on cable all ok. Now you just need to test the RCA signal and the AMP output. I take it you have used low level RCA as the input from the head unit? (two cables usually red n white although can somtimes be other colours) best way is with substitute amp n speakers etc although can be done with osciliscope or headphones. Once it is established the RCA signal is fine then you can check the speakers from the amp. disconnect them at the amp and put each of the two wires briefly to a battery, any battery will do e.g. 9v PP9 or 1.5v AA etc you should hear a pop from each speaker as you do it. that proves the speakers and wiring to them.
If there was no signal from the RCA the cables may be bad - requires testing from head unit to amp
failing that the RCA output may be reduced or turned off via a menu in the head unit
Or the RCA output from the unit may be knackered.
Sorry its a bit long hope it helps
Luda
Jul 04, 2008 | Jl Audio Car Audio & Video
No audio to speakers from deck, just to amp
It's possible (probable) that the head unit has a blown internal amplifier IC. Measure the DC voltage on each of the 8 speaker wires on the head unit. Place the black lead on the chassis of the head unit. Probe each wire with the red lead. All should read approximately 1/2 of the voltage on the yellow wire. If you get some that are significantly higher or lower, disconnect all speaker wires from the harness and measure again. If the voltage is still not ~1/2 of the voltage on the yellow wire, the IC is almost certainly defective.
For the external amp, you need to check the shield ground for the head unit. The following page shows you how.
Test RCA shield ground
Apr 21, 2008 | Pioneer GM-X372 Car Audio Amplifier
Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Dec 11, 2007 | Pioneer DEH-P6900UB CD Player
Alpine CDA-9833 CD Player Logo
60 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
