Question about Porter CableCable PC218C2 18Volt Cordless 2Tool Combo Kit
I just bought the pc218c-2 porter cable 2 piece combo kit. i didnt get instructions on how to put the 6 1/2 circular saw blade on. can you help?
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: missing set of instructions for the porter cable template guide
Not having any luck with manual. All they say is you have to contact the service center for that. If you cant find anything let me know, I am in contact with a center at least once a week.
Posted on Jan 14, 2009
  • 6 Answers
SOURCE: instructions on how to install the overhaul kit
http://www.toolmarts.com/pc_60075.html
Posted on Apr 25, 2009
How to fix depth adjustment knob that won't turn on PC186CS Circular Saw
Try to work the rubber cover loose and squirt in a couple drops of gorilla glue and reinstall. If that doesn't hold, try contact cement on both pieces and let dry and reinstall. That will really grab each other in a rather permanent way.
Jun 17, 2014 | Porter Cable Portercable Pc186cs 18v...
How do u put on a saw blade for a cordless circular saw.???
First remove the battery, next make sure of the blade rotation and remove the hex bolt and OUTER flange lift the guard and put the blade on the spindle. Reinstall the outer flange and tighten the hex bolt, generally newer saws have a spindle lock to hold spindle to tighten the blade. If this is a Porter Cable like in the header you can go to dewaltservicenet.com and with your model and type number find an operators manual. Let me know if you need more assistance.
Mar 11, 2012 | Porter Cable Saws
Blade is slipping, whole spindle is slipping, could barely get blade off slips when i try to saw
From the description it sounds to me like the bolt holding the blade in place isn't tight enough, obviously. If there isn't a button on the saw that stops the blade from rotating when you're changing out the blade. Try this--when tightening down the blade, put it on the saw, then open the guard and rest the blade on a piece of scrap wood to stop if from moving. Then fully tighten down the bolt that holds the blade in place and you should be fine.
Jul 30, 2011 | Porter Cable 12821 7 1/4" 40 Tooth 5/8"...
I have a Porter Circular Saw, 18v, Cordless, 6 and a half inch blade. I'm a novice, so I unhooked the wire latchet that held the lower guard on. I figured out how to put the saw blade on, yet I have the...
Remove the battery, take the blade back off and you will see the holes for the torsion spring. what you will have to do is start putting lower guard on but pretenstion the spring so it will fit back into the proper holes, it might be a benefit to remove the small bumper so that you can move the guard more. when installing the blade you don't remove the lower guard just retract it and slide the blade in place. Usually there is a retaining ring to hold the guard in place but I looked at a breakdown and didn't see one. Let me know if you need more assistance before voting please. Thank you
Feb 02, 2011 | Porter Cable Portercable Pc186cs 18v...
Change the blade on my porter cable 347
Here is the owners manual for your saw. It details the procedure for removing and installing a blade.
Please rate this positive if it helps!
http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Porter-Cable/En900003.pdf
Jul 03, 2009 | Porter Cable Cable 7 1/4" Quik - Change...
Older Porter cable circular saw blade removal
Clamp a pair of vise-grips onto the blade to act as a blade-lock to stop rotation of the blade.
Oct 21, 2008 | Porter Cable Saws
Porter CableCable PC218C2 18Volt Cordless 2Tool Combo Kit Logo
14 people viewed this question
Top Porter Electrical Supplies Experts
Steve
Gene Haynes
Are you a Porter Electrical Supply Expert? Answer questions, earn points and help others
