Question about E-Machines eOne 433 PC Desktop
The screen image is not centered and very faint. I don't have any controls that can be used to center the image within the screen and also would like to see if the brightness can be adjusted to a stronger level.
  • 86 Answers
If you look on the front of the monitor, there are buttons that allow you to enter a menu to adjust those settings. Although, it sounds to me like your monitor is going out. Try testing another screen and see what that does.
Posted on Jul 19, 2010
What does the blue light in the corner of the screen mean
Sorry could not find the exact manual. however you can find it from this one as they ought to be similar
http://www.vivitar.com/files_products/1033/ViviCam_F124_Camera_Manual.pdf
It is called the METERING MENU - three modes (Centre; multi and SPOT). you are set for that spot. you can change that. see page 23
The Metering setting will affect how your camera focuses when capturing an image. Depending on your selection, the camera will be more sensitive to focusing on particular areas in the display and adjust the image color and lighting accordingly.
Center - Averages the light metered from the entire frame, but giving greater weight to the subject in the center
Multi - Used in standard conditions the camera divides and adjusts the settings of the image into several zones for light metering such as complex light conditions, position of subject, brightness, background, direct light and scenes
Spot - Meters the area within the spot point frame at the center of the LCD to set the exposure on the subject in the center of the monitor.
1) Press the M (MENU)/SET button to open the menus for the current mode.
2) Press the LEFT or RIGHT direction control buttons to scroll and select the chosen menu.
3) Press the UP or DOWN direction control buttons to scroll through the menu options.
4) Press the M (MENU)/SET button to select the desired option.
5) A selected option icon will appear on the selected item.
6) Press the LEFT or RIGHT button to select the next menu item. 7) Press the MODE button to exit the menu and return to your previous mode. 23
8) An icon reflecting your selection will display on the LCD screen 9) Remember that this setting will be saved by your camera until you manually change the setting or restore the camera?s default factory settings.
Apr 12, 2016 | Vivitar ViviCam 3188 Digital Camera
HP TSGH-IR02 Remote Control how to install
This document pertains to HP Media Center computers with Windows XP, Media Center Edition.Use this document when the remote control does not work correctly with the Media Center software.Troubleshooting the remote controlUse the following items to troubleshoot when the remote control does not respond or when the remote control does not work properly. For example, when a key is pressed the selection moves all the way to the top or bottom of a list, or moves a selection many different places instead of the item you were trying to select.Before attempting these steps, make sure that PC has been updated with all of the latest Windows updates. Many updates for Media Center, like Update Rollup 1 for eHome Infrared Receiver, can be downloaded easily through the Windows Update software Tool.
Make sure that the batteries for the remote control are installed correctly and charged.Make sure that the front of the remote sensor is unobstructed, within a 45-degree range, and is less than 26 feet (8 meters) away. Disconnect all devices that use a USB connection except to the receiver, keyboard, and mouse. Restart the PC, and then try the remote again.If a pressed button repeats itself (sticks), unplug the IR receiver from its USB connection, wait one minute, and plug in the IR receiver. If the pressed buttons continue to repeat, alter the lighting conditions in the room or move the location of the IR receiver. Other remotes and HP Media Center PCs within range can also cause this issue.Try pressing the Enter key on the remote after changing a channel.If the remote control works when using the media center software, but does not work when changing the television channels, re-configure the Media Center software settings for the cable set-top box or satellite receiver
Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the remote control (most likely the configuration of the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.
Troubleshooting the IR receiverThe IR receiver is the small device that receives the signals sent by the remote control. Use the following steps to test and reset the IR receiver.Disconnect the IR receiver from its USB port on the computer, maximize the Media Center window if it is open, and then reconnect the IR receiver. Test again.Point the remote control towards the IR receiver and press a button. A faint red light should appear on the IR receiver. If the light appears, then the problem is probably in the software that is using the IR receiver (most likely the Media Center software). Close the software, restart the computer, and then re-open the software to solve this issue.Click Start , right-click My Computer , and then select Properties .Click the Hardware tab and then click the Device Manager button.Click the plus sign next to Universal Serial Bus Controllers.If the eHome Infrared Receiver is listed under Universal Serial Bus controllers, Windows is properly detecting the IR receiver. If eHome Infrared Receiver is not in the list, or there is an exclamation mark or a question mark on the device, perform the following until eHome Infrared Receiver appears correct in Device manager:Unplug the end of the USB cable on the IR receiver from the computer and plug it into the same USB port.Plug the end of the USB cable on the IR receiver into the front USB port on the computer.Disconnect all other USB devices, leave the IR receiver plugged in, and then restart the computer. Plug in other USB devices after the IR receiver shows up in device manager.Figure 1: IR receiver listing in Device Manager
Testing the remote controlUse the following steps to check the responsiveness of the remote control:
  1. Open the Media Center software by double-clicking the Media Center icon the desktop or by pressing the green Start button on the remote control.
  2. Click Settings , and then click General .
  3. Click Check Your Remote , and then click Next .
  4. Press the numbers on your remote control. The corresponding numbers on the numbers on the screen should glow when each button is pressed. A faint red light should also glow inside the IR receiver each time a button on the remote pressed.
  5. Click My control is working properly , and then click Next . Do not click I am having problems with my remote control as this will not do anything.
  6. Click Finish after you are done.
Dec 17, 2011 | HP Computers & Internet
At times image is shifted horizontallyatesha
If you turn it on and then get real close and look at the screen from the side. You should see a ghost like tv image. It will be a normal display but just very faint. What has happened is your backlight has failed or the power supply for it. This shouldn't be too expensive to fix as it is a common problem with any lcd tv.
Jun 19, 2011 | Televison & Video
Color dots on tv
u have a bad optical block , this part is very costly , but call sony costumer service , u tv maybe onder recall because of this problem
Apr 15, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Faint lines running through the lcd and out of focus pictures with drawn out images. The camara was working normally. I transferred the photos to my computer using a usb cable. I used it once after that,...
The "CCD IMAGER" of your camera is in state of malfunction, and the good thing is that SONY provide CCD IMAGER free of cost,For more information Clicl Here.
Check the link and contact any SONY SERVICE CENTRE for free replacement of CCD IMAGER.
Thanks for using fixya.
Jul 01, 2009 | Sony Cyber-Shot DSC-T3 Digital Camera
Curved/warped and completely out of convergence Image
Sounds like you need the convergence amplifiers replaced. Cost approx. $300.00 for expert to repair.
Jun 20, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Pillips Plasma - Screen is not centered.
Hi jasonlambert,
You can use the remote control to center the picture on screen. Press to the right of the round pad around the OK button until your image is centered. (I had the same problem once)
-Jordan
Jan 14, 2009 | Philips 42PF9630A 42 in. Plasma Television
Faint diagonal lines on main screen but not PIP mode
Shielded digital board is located in the center looking in the back mounted vertically. Slightly heating center with a blow dryer may cause the picture to clear temporarily. There are three 10uf/16v caps that generally go bad in the center lower area of this board C655, C638 and C714, their ESR will generally be very high when cold. You can either replace these caps or replace the board. Caps are an inexpensive but a difficult repair the board is about $350 plus core part #Bp94-00385a and available at places like Vance Baldwin.
Good Luck!
Bill
William Rayburn, CET
Premium Technologies
PO Box 442
Long Beach, WA. 98631
360-642-4993
premtech@willapabay.org
Nov 28, 2008 | Samsung HLN437W 43" Rear Projection HDTV
Shows half screen only!
if you can't expand your screen size from the pulldown menu or vertically or horizontally center the picture one or two of the centering coils could be partially burned out. the monitor uses electromagnets around the crt neck to center the picture. varying the center controls apply or take away voltage from the coils to center the image. may be time for a new monitor
Jun 08, 2008 | Compaq MV 540 15" CRT Monitor
What is the difference in metering among multi-segment, spot, and center-weighted?
Multi-segment metering uses 256 segments to measure luminance and color. This data is combined with distance information to calculate the camera exposure. This advanced metering system will accurate worry-free exposures in almost all situations including backlight condition. Spot metering uses a small circle area within the middle of image to calculate the exposure. The spot allows precise exposure measurements of a particular object without being influenced by extremely bright or dark areas within the scene. Center weighted measures light values over the entire image area with emphasis given in the central region. In backlight condition or when the subject is not in the center of image, exposure compensation will be required.
Sep 13, 2005 | Konica Minolta DiMAGE Z3 Digital Camera
E-Machines eOne 433 PC Desktop Logo
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
