Question about Westinghouse SK-26H520S 26 in. LCD HDTV
I moved my new Westinghouse LCD TV from one room to another, but cannot obtain a signal. The connector in the new room is the "cable" connector, although I have a TiVO/DirecTV setup, but it worked with my old TV. (It connected via the composite inputs in the old room, and connected to a DirecTV box.) Do you know what I can try with the TV in the new location to eliminate the problem of "No Signal"? I've tried all the "sources" that the new TV identifies, and on Channel 3 and on Channel 4.
  • Westinghouse Master
  • 6,993 Answers
The no signal is displaying because the TV is not recognizing or detecting any input. This could be as a result of wrong connection.
Use the RCA wire (yellow, white and red). Connect the yellow (video display) and white and red (sound audio) from the Direct TV Box out, to the AV in of your TV. Turn on the Direct TV box and press source on the TV, once, twice or thrice, depending on when there is a display.
Or, you can connect a local antenna to the RF in of the TV, then search for TV stations from your TV menu. Antenna connection does not need source, just select a station and begin the search, You can even select auto search.
Good luck
Posted on Jul 09, 2010
  • stims2 Jul 09, 2010
    Any idea why the connector worked before on my old plasma, but does not work with the new LCD?
  • Walesarumi
    Walesarumi Jul 09, 2010
    if the connector is working on your plasma, then it might be that its not compatible with your LCD or the in-put for the connector on your LCD might be bad or maybe you didn't fix it well. Check fr any bent or broken pin and make sure all connections are intact, then try again.
    Take care.
LD-2240 problem while trying to set up monitor all I get is no signal to any menu
Search Results
    Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240
    www.amazon.com/...1080p...LD2240/.../B007ATHRJ...
    Amazon.com, Inc.
    Rating: 2.9 - ‎21 reviews
    Amazon.com: Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240: Electronics. ...When I set it up I was disappointed with the sound but not surprised, it is a cheap TV... Apparently this is not an unusual problem for Westinghouse. ... Oh well, I tried. ...VideoSecu Articulating Arm TV LCD Monitor Wall Mount, Full Motion Tilt ...
    Amazon.com, Inc.Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240 ... When I first hooked it up to my cable connection, through the coax connector (TV ... When using as a computer screenthere's an auto adjust and full manual control .... have endured compromised sound and picture, but I've never had this problem. .... Oh well, I tried.
Jan 11, 2016 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
How do I connect my Sylvania DVD VCR Player to my Westinghouse LCD TV?
Your Sylvania player probably has three outputs: right audio (red), left audio (white), and video (yellow). Use a corresponding three conductor cable to connect to corresponding inputs on the rear of your Westinghouse TV (if it has them).
Sep 19, 2015 | Sylvania Televison & Video
HMDI 1 and 3 do not work (why) ?
Since you did not mention HDMI 2, I assume you have that connected to something else, and that is working properly. The following procedure is based on that assumption.
First, turn off everything connected to the set, and the TV itself. Disconnect the HDMI cable from whatever is going to HDMI 2 (leave the TV end alone for now) and connect it to the PS3. If the PS3 shows up on the TV, the problem is most likely a bad cable. To verify, turn off the PS3 and the TV, then move the known good HDMI cable to either HDMI 1 or 3. If the PS3 works on those also, the HDMI cable you had originally connected to the PS3 is defective. I know there are some bad ones out there; there is at least one lot with a right-angle connector on one end and a straight connector on the other that has a very high failure rate.
If the PS3 does not work with a known good cable to HDMI 2, then the PS3 has a problem. Try using a component (RGB) or composite (yellow end) connection to narrow down what the issue is.
If HDMI 1 and 3 do not work with a known good cable or any input source (DVR or cable box), then the HDMI switching circuit inside the TV is defective. Since the set is "new" that would be a warranty issue.
Jan 03, 2015 | Westinghouse 55" Class - LED - 1080p -...
No power Westinghouse LD4655BX
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
Apr 04, 2014 | Westinghouse Televison & Video
I just bought an westinghouse 42'' led tv and im trying to hook my surround sound and my xbo 360 to it and i keep getting an no signal message everytime and it worked on my 42'' sanyo lcd...
Sounds to me like you are trying to use a composite hookup or a generic HDMI cable. If you get the official Microsoft HDMI connector it also includes phono audio outputs and an optical audio out for 5.1 surround,
Aug 27, 2011 | Westinghouse Televison & Video
It is a 42" Westinghouse SK32H520S and it worked
It is probably a poor connection through the coax. I would replace the coax and that may resolve the issue.
Mar 24, 2011 | Westinghouse SK-32H540S 32 in. LCD TV
Unable to switch my 15" LCD TV Receiver on
some tv sets dont come on when there is no picture signal in put, try and check your cables from the wall, aspecially connectors
Mar 24, 2009 | Televison & Video
Westinghouse 47"lcd tv
are you using an hdmi cable or the red blue and green cables that came with the xbox? if using the original cables there is a switch on them that sets it to HD or standard. hope that helps
Jun 06, 2008 | Westinghouse TX-47F430S 47 in. LCD TV
Westinghouse ltv 32w4 hdc 32.02 in. hdtv lcd tv / dvd combo
My 42" Westinghouse HDMI inputs just stopped working. I thought it was the TW Explorer 4250HDC issue so I got a new one from TW. Still said no signal from HDMI. So, I shut the TV down and pulled the power cord out of the back. I waited a few seconds and reconnected the pwr cord. The TV "re-booted" so to say and now the HDMI inputs work. I think TVTEK has the right idea that it is firmware/software related. In the mean time, you might want to give that a try.
May 25, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Westinghouse SK-26H520S 26 in. LCD HDTV Logo
67 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
