Question about Dell Latitude D620 Laptop (Latitude-C620) PC Notebook
Hi I am trying to reset the bios password on a HALOO LA-2791P motherboard.
    President:
  • 2,571 Answers
If you dont know the password you will need to remove the cmos battery for a few minutes or set the jumper on the motherboard if it has them.
Posted on Jul 09, 2010
  • Roy
    Roy Jul 10, 2010
    Two thumbs is a little harsh....
    If you have a bios password and are locked out, unless you have tried password as the password and been lucky, you will need to clear the bios password, and to do that you will need to remove the cmos batery
    here is your laptops support page, the manual and instructions for changing the cmos batery are on the left http://support.euro.dell.com/support/dow... D620&catid=-1&impid=-1
La contraseña del password de
Para restablecer la contrase?a del BIOS, lea la informaci?n desde este enlace
reset BIOS.
Jan 09, 2011 | HP Compaq nx6310 Notebook
Quitar Password de Bios de Pc Dell Optiplex GX100, no tiene jamper y retirando la pila no funciona. Tengo un Pc Dell que se daño el sistema operativo windows xp, estoy intentando restablecer el...
Hope you can read this. if not, GOOGLE...TRANSLATE.
Removing the PSWD jumper is the correct method of clearing the BIOS password. Removing the battery resets the CMOS.
Remove the power from your computer. Remove the battery. Remove the PSWD jumper. Wait!!!!
Keep power off the computer for at least 30 minutes, overnight is better.
Replace the battery. Plug the computer in. Do Not Reconnect the PSWD jumper.
Now reinstall your operating system and drivers. When finished, restart your system. If everything works and you want to redo the BIOS password, shut the computer down. Unplug the power. Remove the battery. WAIT.
Replace the PSWD jumper. Replace the battery. Plug in the power. Restart the computer, hitting "F2" as it starts....to open the BIOS setup page. Reset your password here. Esc to continue, Yes to save.
Good luck
Jan 22, 2010 | Dell Optiplex GX110 (2909T) Motherboard
LA-2791p Motherboard
Dell uses serval manufactures including Asus.
Sep 25, 2009 | Dell Latitude D620 Notebook
Como le quito el password al bios
para sacar la password de la bios de la maquina solo tienes que abrir la maquina, al lado de la pila en la placa madre hay un jumper(un plastiquito que sirve de conexion)lo tenés que cambiar al 2-3, esta gralmente en el 1-2, osea lo sacas, lo pones en el 2-3, prendes la maquina unos segundos, la apagas, vuelves a cambiar el jumper a la posicion 1-2 y listo tu bios queda borrada, ahora solo tienes que entrar a la bios y configurar tu disco duro, la hora, etc,etc , si no hubiera tal jumper, entonces directamente sacas la pila por unos segundos, la vuelves a poner y listo,
Jul 15, 2009 | Toshiba Satellite L25-S119 Notebook
How to Reset BIOS Password Toshiba Satellite A135
Hi! In order to reset the BIOS password for your toshiba laptop, you need to bring the NB to the nearest Authorized Service Provider for Toshiba since only a certified Toshiba Technician can reset the BIOS Password. The technician will remove the jumper inside the laptop which is integrated on the motherboard and the BIOS Password will be reset. All issues regarding the BIOS Password are directly handled by Toshiba Authorized Service Provider.
Hope this helps!!!
Thanks
Sep 23, 2008 | Toshiba Satellite A135-S2276 Notebook
Bios
If you have lost your bios password, only way out of this is accessing the motherboard and resetting the cmos.
If you access the mothernboard you can reset the bios removing the little coin battery from motherboard for one minute.
There is also a 3 pins bridged contact, near to bios chip, if you move the contact on the other two pins it will do same as removing battery.
Aug 28, 2008 | Intel Motherboard
Bios password ibm thinkpad g40
Sounds like you tried this, but it's worth a shot again. Remove the CMOS battery on the motherboard and let the laptop sit for an hour, then replace the battery with a new one.
If the only real issue is changing the time and date, you can do this in Windows and it will reset the BIOS clock, too, of course.
If the problem is that the time and date keep reseting, you either have a low CMOS battery or a short on the motherboard that is resetting it.
If all else fails, you might need to flash the BIOS from a floppy disk with the latest BIOS version for your machine to reset it and go from there.
PS: BIOS reset problems on laptops are sometimes due to power problems caused by battery packs going bad; check your battery pack, too, and see if it is working okay.
Good luck...
Oct 23, 2007 | IBM ThinkPad G40 Notebook
Toshiba m105 s3004 bios password
i have a Toshiba satellite M105-S322 and all i had to do is open the ram compartment and pull up the plastic sticker or whatever you want to call it between the motherboard and the ram. There is a jumper called "CMOS_CLR1" use a screwdriver to short out the pins and it clears the CMOS.
Aug 24, 2007 | Fujitsu Siemens AMILO D-7830 Notebook
Computers & Internet Logo
302 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
