Question about Nespresso D150 Espresso Machine
My Nesprsso D150 just quit working
There is power to the unit, the unit is switched on, the power indicator light is off and the unit is dead. :(
  • 518 Answers
The switch is faulty as with power to it,but nothing coming out ,,the contacts are not closing together to power up the unit,
Posted on Jul 09, 2010
R1 indicators
Broken wire in the loom around the head stock is quite common.
Feb 27, 2014 | Motorcycles
Lg flatron L192ws DEAD CAN IT BE FIXED. shows no lights - nothing. Changed power leads but still dead.
A dead monitor indicates a power supply problem. If unit has an external power supply and you have have substituted it with another known working supply and the unit still does not work, then the problem lies within the monitor's circuits. Yes, it can be repaired, but it might just be cheaper to replace it due to high labor costs.
Jan 27, 2014 | Computers & Internet
Asus aspire one d150-1bk dead, no lights, no sounds, nothing hapens. I measured the power of the charger and indicates 19v when is not connected but when I conect it to the laptop only had 0.8v. Witch...
Try removing the battery then connect the power and see if it turn on without the battery. Otherwise I suspect a bad power board inside the computer.... most of the time if the adapter is giving the correct voltage before plugging it in... it could indicate a problem if the voltage is then lower after plugging it in however unlikely... although it would be aworth making sure you have the right power adaptor for your computer
Oct 11, 2013 | Computers & Internet
1987 dodge d150 break lights
get yourself a tester to see if you are getting power to the light socket, have someone push on the brake petal and use the tester to check for power. If no power, you have a broken wire somewhere between the rear lights and dash [fuse panel] check for corrosion in bulb socket. try to find the wire along the frame to the rear lights for any breaks in the insulation. electrical is one of the hardest problems to solve, good luck.
Mar 12, 2013 | 1987 Dodge D150
Indicator light comes on but sweeper doesn't run.
it sounds like the motor is dead. The Light and the motor are wired differently so it is quite possible that the motor is dead and the light still works.
Jun 06, 2012 | Kirby Heritage II Vacuum
Bosch dishwaher Model # SHX46A does not display indicator lights and does not function in any mode. There is power to the on/off switch that works and power to the control panel. Other wise the unit is...
Having same problem, power to outlet, but unit is "dead", no lights, won't turn on. Unit is 6 yrs old and don't want to spend $100 for a repair man to tell me there is no hope....anyone else experience this?
Aug 12, 2010 | Bosch Dishwashers
Model KUDS03FSSS2 Power to unit but unit dead. no light indication on control panel. buttons do not work
I have this problem. Acts like the power is unplugged. No panel lights, no error codes. The problem must be the ....
NON-RESETTABLE BI-METAL [fuse]
or else the door switch. I cannot find either one to measure with my volt-ohm-meter. Any tips on locating these components?
Oct 26, 2009 | KitchenAid Dishwashers
AVR-485 Quit working
I just bought this machine...and had earlier seen your post. I was looking at the "microprocessor re-initialization" part and thought, hey, it may be worth a try for you.
So, consider re-initializing (resetting) the machine. This can be done by:
1) Turn off the unit using the *main* power switch
2) While holding both Speaker A and B button, turn on the machine using the *main* power switch
3) You should see the main display flash at 1 sec intervals. Let go of the speaker buttons to finish.
Hope it helps,
Eddie V.
Dec 02, 2008 | Denon AVR-485 Receiver
Nespresso D150 Espresso Machine Logo
608 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
