Question about Cascade 1400 Gph Pump
Cascade 1400 model 3313 0000 looking for a filter sponge did see where a place in america were doing it but lost site
Over heating while cleaning
There can be 3 reasons
1. The main dust collection receptacle is full. Empty it
2. The filter in between the receptacle to the machine is clogged. Take it out and wash it. Ensure it is dry before fitting it again as this is the inlet and must not be wet.
3. Look for a clip on attachment from where the air exits. Open this and clean the sponge and filter. I usually take it out and wash it squeeze out the extra water before using again. Since it is the outlet, it doesn't matter if it is damp when refitting.
I would advise that you take a picture before pulling it out so that you place the rubber gasket, sponge and filter in the same sequence as before after cleaning them. Happy Cleaning!!!!
Apr 22, 2014 | Samsung Vacuums
What's a sponge filter?
In sponge filters water is forced through porous foam. Water flowing though the sponge allows the growth of a colony of beneficial bacteria which neutralizes toxic ammonia. Most sponge filters uses two sponges attached to one lift tube which is an advantage that the sponges can be cleaned one at a time, reducing bacterial loss.
Aug 09, 2012 | Fish
I lost my instruction manuel and i dont know how to put oil in the airfilter
pop air filter of.Carefull not to let anything get down into engine. Remove sponge. If theres 2 sponges then you need to coat the inner sponge. pour a little onto sponge and squeeze so it gets into all the holes. give it the sponge a good last squeeze holding over jar to get rid of excess as this will prevent air from entering engine. Fit air filter back on. Good idea to have a few spare so when one is used others can be washed and dryed. Either wash in wasing up liquid and dryed or nitro fuel and dryed.Hope this helps.
Aug 06, 2010 | Tornado 110 Nitro 4wd 2 Spd Off Road S30...
Where is the isuzu crosswind airconditioning sale parts center in manila?
Isuzu Motors America, LLC
1400 S. Douglass Road, Suite 100
Anaheim, CA 92806
(714) 935-9300
Owner Relations Inquiries:
Write Us
Owner Relations
Anaheim, CA 92806
Call Us
(800) 255-6727
Hours: 6:00 a.m. to 5:00 p.m. (PST)
Monday to Friday
Dec 21, 2009 | Heating & Cooling
Lexmark printer lost cd how do I install
Go to the Lexmark site, once you've chosen North America, United States and English, choose your Printer by Model, enter Z515, then choose operating system and download software...
http://downloads.lexmark.com/perl/downloads/downloads.cgi
Aug 11, 2009 | Computers & Internet
How to set up a Hozelock cascade 1500 pond pump
if there are no markings, check each opening for a vacuum with a small piece of paper, the one sucking in is the inlet, the other is the outlet
Jul 25, 2009 | Cascade 1400 Gph Pump
Dyson DC07 shuts down after 5-10 minutes of use and horrible suction!
I have had this problem on two dysons and have solved it by replacing the so called lifetime pre-filter. The problem is not the washable blue sponge but the material gauze filter in the plastic surround.
To see if this is your problem try removing the whole filter (i.e. the filter with the blue sponge inside - you need to remove both bits not just the sponge).
If you do a quick vacuum test for a few minutes then see what effect this has on the suction.
If you need a new part try somewhere like here (you'll need to chose for the right model) : http://www.espares.co.uk/part/dyson/dc07/p/1086/716/6/420625/875479/lifetime-pre-motor-dyson-.html
As I say this has fixed both of mine.
Oct 27, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
HEPA Filter
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618630&thid=730623
HEPA Filter
Posted by jenski66 on Jul 02, 2008
My vacuum came with a sponge over the filter and the directions said I could wash the filter. Do the directions mean to wash the black sponge or the actual filter? Is the sponge part of the filter or is it trash?
Filter F27
Dirt Devil Purpose Cleaner for Pets
Upright Bagless Vacuum
Model #1LY2108-000
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Typically the top filter of which is the sponge is washable but the HEPA filter is not, it can be brushed off and vacuum off with another vacuum, but the best filtration is to replace the HEPA filter and to wash the sponge filter, if the sponge filter get to bad then replace the sponge filter as well. Or, you can check with your local vacuum cleaner dealer in your area or to contact the manufacturer’s website and or phone #. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://royalvacuums.com/ Customer Service 1-800-321-1134
Hours are: 8:00 AM to 7:00 PM (EST)
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 02, 2008 | Dirt Devil 12 Amp HEPA Filter Vacuum...
We have a Kenmore Stylite Retrax vacuum cleaner, brand new. Suction is not working properly.
I actually pulled back my old vac after using this thing. Having said that I have played around with it and one quick cure is the remove or clean the little circle sponge filter at bottom. If you remove the canister and look at the bottom of vac you will see where the air travels down through a small circle. In there is a sponge filter that is probably clogged. Now Being frustrated, I just removed it and the vac sucks like crazy now. There are just way to many filters to worry about. As mentioned you need to clean the top main filiter, then the top sponge filter, and then dont froget there is alson one in the front of the machine (square paper filter) that catches dust leaving vac. These are on top of the little circle one that I removed, so I dont think it will be missed. Try and see what you think.
Apr 21, 2008 | Vacuums
Cascade 1400 Gph Pump Logo
35 people viewed this question
Top Cascade Garden Experts
Dennis Key
Dennis Key
john h
Are you a Cascade Garden Expert? Answer questions, earn points and help others
