Question about Mitsubishi WS-65809 65" Rear Projection Television
Good diagnostic I have the 1-2 blinking light, bt I still can turn the tv on
    Scholar:
  • 170 Answers
Check your timer in your menu. you should only get code flashed when you you press certain buttons on the front.
if you get flashing durring the time the tv is off or on, then you have a timer set in the menu.
Posted on Apr 21, 2008
TV SHUT OFF, HASPOWER, RED BLINKING LIGHT, WON'T TURN BACK ON, WHATS THE PROBLEM ?
If the red light is blinking, then it either does not have a good power connection or its in a diagnostic mode. The red light should be solid not blinking.
Feb 15, 2016 | Televison & Video
When you turn on power you hear a click and the green light turns on. Three seconds later you hear another click and the green light turns off.
MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ONFOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and"menu" buttons on front of tv for at least 5 seconds and then release bothtogether.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protectthe Convergence IC or IC's is blown---set will detect no voltage to convergenceIC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES ANDTHEN TO GET IT TO REPEAT MORE YOUHAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and twoblinks--this is the most common and easiest to fix.
Let me know what you find and I will assist you.
SD TECH
Aug 31, 2011 | Mitsubishi WS-55807 TV
Our Mitsubishi projection tv went out one day. When we went to turn it back on all it does is blink the green light for a few seconds and then shuts off. What could it be? Where can we look to see where...
PRESS AND HOLD "device"(input) and "menu"buttons on front of tv for at least 5 seconds and then release both together.
SD TECH
Aug 09, 2011 | Mitsubishi WS-65807 65" Rear Projection...
Tv will not turn on, green light comes on and then shut of
MOSTOF THESE SETS HAVE A SELF DIAGNOSTIC:
PRESS AND HOLD "device" and "menu"buttons on front of tv for at least 5 seconds and then release both together.
Jun 09, 2011 | Mitsubishi WS-65315 65" Rear Projection...
Tv won't turn on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
if it is 2,2 I have start to finish instructions for this repair in this model.
SD TECH
May 01, 2010 | Mitsubishi WS-55809 55" Rear Projection...
My model is a WS-55511. I turn on the TV, the
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Turn on the power and the green LED blinks on the front for a second, but tv does not power on
Jul 30, 2009 | Mitsubishi WS-55411 55" Rear Projection...
The power light keeps blinking and it doesnt matter if i unplug the tv and plug it back in when i go to turn it back on it just blinks.
the blinking power light is actually a diagnostic of a faulty part inside the set.
Here is the diagnostic info and which part you need to replace.
1 blink STV 5v sense DG Board
2 blinks 15v SOS D Board
3 blinks 3.3v SOS D Board
4 blinks Power SOS P Board
5 blinks 5v SOS D Board
6 blinks Driver SOS 1 SU / SD / SC Boards
(SC energy recovery circuit)
7 blinks Driver SOS 2 SU / SD / SS Boards
(SC floating voltage area)
8 blinks Driver SOS 3 SS Board
(SS energy recovery circuit)
9 blinks Panel Config. SOS
10 blinks Sub 5v SOS / Main 3v SOS DG Board
DTV 9v SOS / Tuner Power SOS
11 blinks Fan SOS PB Board
12 blinks Sound SOS H Board
13 blinks Communication error DG Board
with IC8001 (Pesks Lite 2)
if this set is still unedr warranty, please use the warranty to replace the part. Else, have a professional install the new part for your safety.
hope this helps.
regards,
voodoo
Jun 09, 2009 | Panasonic Viera TH-50PZ85U Plasma TV
Toshiba 52HM84 DLP TV with new bulb but the lights keep blinking
They exact way the lights blink are telling you what the failure is. If the tv is firing the lamp and the lamp is bad, you will hear a buzz sound for about 1 second. The tv tries 8 times before it gives up and spits out the lamp error. Check the user manual for led diagnostics. If you put in a new lamp but still have issues, you've likely got a bad ballast (most common on this model) or colorwheel (less common). Both are part of the optical block (light engine) and I don't believe they're available as individual components from toshiba.
Nov 28, 2008 | Toshiba 52HM95 52" HDTV Projection...
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Mitsubishi WS-65809 65" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
