Question about Dell Latitude D600 Notebook
It is freezing up at various times from startup to when it is being used
  • 61 Answers
There are a few different problems that can cause this. The most common is that the cpu is overheating. Try blowing air through the exhaust vent and see if your up time increases. The best way is to disassemble the unit and remove all dust blocking the heat sink.
Posted on Jul 09, 2010
  • 41 Answers
I agree, check your vents. heat is a killer. Blow it out and try again.
Posted on Jul 13, 2010
How to reset my computer
Start - > Programs - > Accessories - > System Tools - > System
Restore
There will be two option:-
- Restore my computer to an earlier time.
- Create a restore point.
Now what do you want? No.1 or No.2
Just click on it >Next and follow instruction, that's it.
But in this procedure you will loose your data or you have to take backup of your all data. So I would suggest you to download RegInOut its provides various features that make your PC maintenance job easier. It automates the difficult tasks and scanning through it is safe and tested on hundreds of thousands of PCs all over the world.
Following are the main benefits of using RegInOut:-
- Repair and clean registry errors crashes and freezes in applications and programs.
- Optimize and speed up internet through the internet optimizer feature.
- Clean up the backyard.
- System Cleanup Registry Cleaner
- Internet Optimizer feature Services Optimizer
- Defragmenter Startup Manager
Thanks
Nov 07, 2013 | Computers & Internet
Hi, I need help, my pc freezes and I cant move the mouse or do anything else, I have to restart it. Please Help me.
Start/Run... Run msconfig. On General tab, select Diagnostic Startup. Reboot. Use the computer in this state for as long as the freeze usually appears.
If no freeze, return to msconfig General tab. Selective startup, uncheck Startup.
Repeat reboot and trial usage. If no freeze, check normal startup. On startup tab uncheck everything that looks non-essential. Reboot and retest. When the computer seems "fixed" recheck one startup item at a time. Repeat your timed test until the issue reappears. When it does, the latest startup item you enabled is the cause.
Oct 16, 2012 | ASUS P5VD2-X Motherboard
Imac g4 freeze restart
This is a sign of memory issues with your Mac. Replacing the memory should not be very expensive.
Oct 10, 2012 | Apple iMac G4 Desktop
Compaq nc6220 freezes during POST
Start in Safe Mode by pressing F8 during boot. Then...
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but when you initiate.
Oct 04, 2012 | HP Compaq nc6220 Notebook
Hello, the EBI computer I came into contact with has been freezing. What happens is this: The monitor flickers and turns black for a fraction of a second whenever a program is run. Following this,...
You have a driver conflick? go to troubleshooting mode at run type in msconfig and press inter, config
will come up, select diagnostic start up, click ok, reboot computer, when at desktop type msconfig in run again, and select startup in start up check one box at a time and click ok and reboot the computer
until you find the one that is bad! I hope this helps!
Jun 02, 2011 | Computers & Internet
Toshiba Laptop - Startup freeze 40% of the time.
its a common thing for a vista based system to freeze after some updates , and my good advice to you is you better dont place too many applications on the startup , and avoid unwanted updating , ie8 is one such thing . if u have an option better switch to windows 7 , its really fast on notebook computers . install only defender updates from windows.
Jul 04, 2010 | Toshiba Satellite Laptop with AMD Athlon...
Every time I boot the computer, a windoow comes it says you are t
there is a program you have deleted trying to startup in the background.
An easy fix is to START>RUN> type msconfig
Click on the STARTUP tab.... and UN-Check everything except Antivirus software.
Click OK, and re-boot PC.
Thanks for using FixYa - a FixYa rating is appreciated!
Feb 24, 2009 | Computers & Internet
SONY VAIO notebook freezes on xp splash screen every 2-4 mos.
first, ensure your system restore is turned on and make a restore point right now!...assuming you have run a thorough disk check and de-frag. then, trust the system restore. I have used it with success 100% of the 20 or so times I have used it. Next, start using the "Hibernate" power down mode. I have found this to work wonders with third-party driver problems. It seems that once a good startup happens, then freeze it (and continue to get a good startup) with hibernate from then on. Last, check about every month for the quantity of restore points that have taken place automatically by Windows. Sometimes, depending on the size of the hard drive, too many points can begin to encroach on your free space that you want for virtual memory or data. So for example, I see 15 restore points in the last month, I will dlete them all by cancelling system restore. Then I use "clean disk" scandisk and defrag. Then I turn restore back on.
Jun 12, 2007 | Sony VAIO VGN-FE790GN Notebook
Dell Latitude D600 Notebook Logo
61 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
