Question about Canon Office Equipment & Supplies
In my 3530 single side copying is ok but when i am trying for back to back my A3 paper is getting jam with z fold pls guide
  • 1,219 Answers
are you talking about ir 3530 b&w copier?
"Z FOLD" of jamed paper is usual when paper goes from cass. towards registration roller, and registration clutch doesnt operates.
Do you have problems with A4 double sided too?
Where does the jam occures? In wich section?
I had few cases, when the paper stucked above fixing unit in small inner door, wich guides paperout or back in duplex, for second side copying.
The problem was in spring and solenoid wich lifts the paper guide plastic with finger.
It also could be case that you need to replace paper pickup, feed and separation roller in cassete where is A3 paper, and clean other rollers.
Try to put paper in "good" cassete, from wich you do not have problems.Just swap papers, and set correct paper sizes, and if it works then the problem is 70% in rollers.
On the place where the paper stucks, clean the paper rollers, by rotating it and cleaning with alcohol or water and dry it verry well.
Hope that helped.
If you have more questions or want service manual, write on emma.servis@gmail.com
Posted on Jul 09, 2010
Ricoh copier i make some copies but when i turn the papers to print the other side of the sheets the paper gets folded as it enters leaves the tray and creates paper jam
Make sure the ink is dry and the paper is cold before replacing as this can weaken the paper strength and cause it to fold. Also a lot of printers are very picky about paper alignment and don't like you just putting in single sheets. Try having at least 6 sheets in the slot and 'tapping' them on a flat surface to align the bottom surface before feeding them in.
Oct 22, 2013 | Office Equipment & Supplies
Paper jam at the fixing unit for IR 3530
Check the exit sensor actuatir and the the fusing unit upper and lower roller strippels.
Apr 18, 2013 | Canon IMAGERUNNER 3530 Copier
HI MY DESKJET 9800 WILLNOT FEED A3, IT JAMS ON THE LEFTHAND SIDE EVERY TIME, I HAVE LOOKED TO SEE IF ANYTHING IS OBSTRUCTING DUE TO BEING IN STORAGE FOR A WHILE. A4 FEEDS CORRECTLY, BUT CANNOT FIGURE OUT...
If A4 is ok but A3 jams then I would have to say there IS something hitting the paper. Try another A3 sheet and when it jams, pull the paper back out (after the printer is switched off) very slowly. When its out take a look at the leading edge and you will see a kink in the edge of the paper. Now place the paper back in the input tray and look at where the kink is in relation to the machine. That will tell you exactly where the obstruction is.
I hope you understand what i am trying to say.
Jul 10, 2011 | HP DeskJet 9800 InkJet Printer
Cannon ir 3530 all error code and solution
Code Error name/description
E000 fixing overheating
E001 fixing assembly overheating
E002 fixing assembly low temperature
E003 post-standby fixing low temperature
E007 fixing film rotation error
E010 main motor rotation error
E014 fixing motor rotation error
E019 waste toner case full, waste toner case full sensor error
E020 toner clogging between sub hopper and developing assembly
E024 developing assembly connector disconnection
E025 hopper motor, bottle motor error
E032 NE controller counter error
E064 power supply voltage error (high-voltage)
E100 BD interval error
E110 scanner motor error
E191 communication error for high voltage power supply
E202 CIS home position detection error
E225 CIS light intensity error
E227 reader unit power supply error
E248 backup memory error
E261 zero-cross signal error
E315 image data error
E400 feeder communication error
Mar 03, 2011 | Canon ImageRUNNER 3570 Copier/Printer
Xerox XD100 paper jamming every time.
The fuser is the problem. Most likely the fuser will need to be rebuilt or replaced.
Google a business called The Parts Drop. they have either the parts or the unit.
You may just have to take the fuser out and remove a badly jammed piece of paper in that module.
Shut the machine off for a half an hour. Remove the back cover. You will then see on the left side a black plastic bracket with 3 plugs on it. Disconnect those 3 plugs. Then open the right side door and toward the top is the fuser. It has yellow caution HOT labels on it. There are 2 silver phillips screws holding it in. Remove the screws and then remove the fuser unit and see if there is a paper in there. There are 2 screws that you can remove and the fuser will kind of fold open to inspect for bent fingers or one out of place.
Mar 30, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
Problem to feed photo paper
pls... change the a3 photo paper to 230 gsm because the sensor can not load because of the thickness of your photo paper. change it to small gsm.
Sep 29, 2009 | Office Equipment & Supplies
Double sided copying
http://www.brother-usa.com/ModelDocuments/Consumer/Software%20Users%20Manual/SUM_DCP_7030_7040_MFC_7340_7345N_7440N_7840W_EN_1650.PDF
here is the manual p4 and p16 discuss the topic:
Duplex printing 1
The supplied printer driver supports duplex printing.
Guidelines for printing on both sides of the paper 1
�� If the paper is thin, it may wrinkle.
�� If paper is curled, turn over the stack, straighten it and then put it back in the paper tray or the Manual Feed
Slot.
�� If the paper is not feeding properly, it may be curled. Remove the paper, straighten it and turn over the
stack.
�� When you use the manual duplex function, it is possible that there may be paper jams or poor print quality.
If there is a paper jam, see Paper jams in the User’s Guide. If you have a print quality problem, see
Improving the print quality in the User’s Guide.
Manual duplex printing 1
The machine prints all the even-numbered pages on one side of the paper first. Then, the Windows® driver
instructs you (with a pop-up message) to reinsert the paper. Before reinserting the paper, straighten it well,
or you may get a paper jam. Very thin or thick paper is not recommended.
Simultaneous scanning, printing and faxing 1
Your machine can print from your computer while sending or receiving a fax in memory, or while scanning a
document into the computer. Fax sending will not be stopped during PC printing. However, when the machine
is copying or receiving a fax on paper, it pauses the PC printing operation, and then continues printing when
copying or fax receiving has finished.
�� Manual Duplex
Check Manual Duplex. In this mode, the machine prints all the even numbered pages first. Then the
printer driver stops and shows the instructions required to re-install the paper. When you click OK the odd
numbered pages are printed. There are six types of manual duplex binding directions available for each
orientation.
�� Booklet Printing
When you want to print a booklet, use this function. To make the booklet, fold the printed pages down the
middle.
�� Binding Offset
If you check the Binding Offset option, you can also specify the offset for binding in inches or millimeters
May 14, 2009 | Brother MFC-7440N Laser Printer
Copy/Printing machine jams
This tells me your DUPLEXER is the one causing the jam, Ok like when you open the duplexer do you see the paper in their
second does your copier indicae that the duplexer is in stalled ?m print the config page to verify. if it worked ok until this incident then your paper feed tires in your Duplexer is worn and needs to be replaced, do not do this yourself call a Service tech or A dealer to do so, uf your in CT we can help.
Mar 06, 2009 | Panasonic Workio DP-3530 Copier
Lexmark 5400 series paper jam
As several previous posts said there was a pieces of paper folded up inside. Per a previous post remove the sheet feeder rack. At this point I removed the two outside screws (of the three) on the backe. After this the whole top lifts about 3/4 inch (19mm) to give your fingers more room to clear it. Looks like she will print another day.
Thanks for the tips on here.
Ken Bowd
Nov 07, 2007 | Brother Multi-Function Center MFC-240C...
88 people viewed this question
old marine
old marine
