Question about Canon FAXPHONE L80 Laser
My L80 keeps reading "Change Cartridge" even when a new one! Can anyone help!!!
  • rulucky Apr 19, 2008
    My L80 keeps reading "change cartridge" even when a new one is installed. Thanks for any Help!!!1
  • calaismcd Sep 09, 2008
    my L80 plain paper faxphone keeps telling me to check cartiridge
  • 22 Answers
If you pull the cartridge out and look inside the are to Metal pins to the right hand side make sure niether are stuck. Also if you are using refilled or refurbished cartridge they may not have been filled with the proper type of toner and the magnets in the cartrisge may not be regonizing the toner.
Posted on Apr 22, 2008
Will no print faxes - says to change cartridge. did that and still says to change cartridge. does receive faxes in memory, but will not print.
you may need to get into the menu and then go to service section there you will find the maintenance section look for the print head item it should ask new used head ok the new and it will reset and do a clean and nozzle check too..
Jul 13, 2010 | Canon FAXPHONE L80 Laser
AFTER RELOADING TONER INTO CARTRIDGES, THEN RED LIGHT BLINKING AND IT WILL NOT PRINT. WHAT CAN I DO TO FIX THE PROBLEM?
Did you change the chips in the cartridges after you filled them with toner? Inside the cartridges are chips that the printer keep track of the number of images that are printed. After so many pages, the printer marks the cartridge as empty, even if you fill it with toner. When the cartridge is changed the printer reads the serial number on the cartridge and keeps a log it its memory. If the chip is replaced, then the printer does not recognize it and thinks it is a new cartridge.
Hope this helps.
Apr 30, 2010 | Samsung CLP 300 Laser Printer
Need software download for canon faxphone L80
How do I install a new ink cartridge on a Canon Faxphone L80? Which ink cartridge does it take?
(Lost the manual)
Jan 11, 2010 | Canon Office Equipment & Supplies
Where do you get refill ink for canon fax phoneL80
The Canon Faxphone L80 takes a Canon FX3 cartridge. To get the highest quality refill I would first see if there is a Cartridge World store in your area. Cartridge World stores refill most cartridges in house with American made parts. Then try Office Depot. Office Depot is the only big box store that actually "remanufactures" toner cartridges. I would not recommend cheap refills or refill kits from the internet. Many use very low quality toner that wears on parts leading to print defects or they reuse parts that already generate print defects. DO NOT buy a "compatible" cartridge, these are not refills. They are new cartridge replicas and have no recycled components.
Dec 16, 2009 | Canon FAXPHONE L80 Laser
Fax machine L80 screen view shows put in cartrige, after we put a new cartrige. What we need to do
Open your cartridge and insert again,clean your cartridge,press clean button from panelboard.
Dec 02, 2009 | Canon FAXPHONE L80 Laser
Canon L80
This is most likely to be a problem with the cartridge,Cange the cartridge and test again.
Feb 23, 2009 | Canon FAXPHONE L80 Laser
Vertical White Line printing down the page
Hello sir; I believe you have running out toner , try put a new one see what's happen.
Feb 03, 2009 | Canon FAXPHONE L80 Laser
Cannon Phonefax L80
the cartridge isn't the problem normally when you close the front door there are switchs under the cover that control things like sensing the toner cartridge. most likly one of those switch levers are out of place. to check them your will have to remove the top cover to do this you will have to take the screws out in the back of the machine as well as the ones in the front covers when you have the door open. then the top cover will lift off and the lever and switchs are on the right side facing the front of the machine. with the top cover off you can close the door and see if the switch is being activated or if there is parts floating in the top of the machine. hope this helps.
Nov 15, 2007 | Canon FAXPHONE L80 Laser
Canon FAXPHONE L80 Laser Logo
132 people viewed this question
old marine
old marine
