Question about Westinghouse Microwave Ovens
Ayaw uminit ung microwave nmin pg my nirreheat ako
Hamilton Beach microwave, model PG 100 n. Where can I obtain a user manual?
you can search Google for a manual or check with the company to see if they have one to download
Nov 20, 2015 | Microwave Ovens
Why doesn't it turn on?
The internal fuse may have opened.
Sep 25, 2015 | Microwave Ovens
Replace fuse mz 3000 pg microwave
There are many great microwaves out there at affordable prices. Just be sure to do your research before any purchase. Sites like Best Microwave Review can be helpful because they review the units on many different criteria, so that you can choose what is best for you. My best advice would be to do your proper research and never rush into any microwave purchase before reading up on the unit.
Dec 31, 2012 | Microwave Ovens
My yaskawa f7 inverter has PG open problem
Replace either the inverter if bad or the microwave itself.
Jun 14, 2012 | Microwave Ovens
HOW TO SOLVE PG OPEN on f7 yaskawa inverter
replace the part or the unit itself.
I want to bake a salmon loaf in a glass loaf pan in my Jen Air mincrowave/convection oven. The 4 pg. instruction manual does not give me sufficient info. In fact, there's onloy a half page relating...
I have a Panasonic Convection Micro. Yes, If you are using convection you can use metal pans. Microwave energy cannot pass through metal pans so that is why it is not good to cook in them. It could also cause arcing or reflect the microwave energy bak to the mag and over heat it. So, when possible use corning ware or Pyrex when using the microwave
Aug 17, 2017 | Jenn-Air JMV8166B 950 Watts Convection /...
I live in Switzerland and have a new Electrolux EB SL6 built in oven. How can I get a user's manual in English?
Unfortunately, you can't as your model has never been intended for English-speaking countries. As far as I recall, it's only available in French, Italian, German and some Eastern European languages.
You will either need to ask someone locally to translate the key sections into English for you, or if you use the FireFox web browser you can add the excellent FoxLingo plug-in which provides translations from a number of sources. All of the software and the translations are free.
Aug 15, 2010 | Microwave Ovens
How do you turn the carousel on/off on a Kenmore Microwave Oven model: 5658932580
Look at the owner's manual of similar Kenmore models there does not seem to be a setting that allows you to turn off the turntable. However if your microwave (sorry but I couldn't find your exact model number online) has the time of carousel that has a lift out glass plate with a notch (hub) in the center of the bottom side then you effectively turn of the carousel my removing this glass plate. (see pg 4 of the manual - above link) You can place a normal microwave safe plate in the microwave in it's place. Make sure to leave the rollers in place...just remove the turntable.
Nov 08, 2009 | Microwave Ovens
My new (less than 7 months old) JVM1540 microwave just quit. It was working multipLe times earlier today. The main breaker does not show as being 'tripped' and appears to be working. Help..??
Take the microwave back to where you got it, whatever is going on it should still be covered under warranty. it may just be a fuse but a warranty is a warranty. Make sure to take your manual with you just in case they give you any ****. Warranty is located on pg. 15?
Jul 17, 2009 | GE JVM1540DM Microwave Oven
Microwave Ovens Logo
27 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
