Question about Proscan 19LA20Q LCD TV
Cannot program digital remote for Cogeco
We recently had to upgrade our cable service to digital with Cogeco. They provided a new remote that works with their adapter box. It came with codes to program the remote to work with your tv. The codes provided for the Procan tv's did not work nor could I find a code by searching the remote's database for over 20 minutes. I even tried the RCA codes just to see if one of them would work. All the other tv's in our house work fine with the Cogeco remote. Is there another code that can be used. The Cogeco technicians could not help. Here are the codes for Proscan tv's that came with the new remote 10047, 10466, 01747, 11922
Your assistance would be greatly appreciated
5 Suggested Answers
  • 12 Answers
SOURCE: proscan manual
This should help you
Proscan 19LA25Q 19" LCD HDTV at Crutchfield.com Proscan 19LA25Q 19' LCD HDTV: Detailed Info, Features and Specs, and Photos. ... Instruction Manual; Product Registration Card; Limited Warranty Card ...
www.crutchfield.com/ISEO-rgbtcspd/App/Product/Item/Main.aspx?i=68319LA25Q - 46k
Posted on Apr 04, 2008
SOURCE: lcd 32" proscan need code for universal remote
Wow it took me a couple hours but hey i found the code ever1 needs and its a 5 digit code for comcast remotes with the red ok button the codes r 10090 or 10030 hope ive helped u out good luck
Posted on Mar 17, 2009
SOURCE: need a remote control code
hi,i had the same problem and found out that the samsung remote codes worked,try that.
Posted on May 30, 2009
SOURCE: Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Posted on Apr 28, 2010
Emerson TV. Why does sound fluctuate between 100 and 0?
hello there I wasn't able to decipher a question out of the things that you said how ever I imagine that you just would like the volume to stop fluctuating without you initiating it. well needless to say in any event your television set is malfunctioning, the problems that it is experiencing is not really something thats user serviceable. If you feel like this is something that you can service then more than likely will need a board replacement, in a lot of television sets there are only two to three boards in the first place.
are you using cable television or over the air programming? if you are using over the air programming there may not be much you can do in this situation besides get the unit repaired or get a new TV, on the contrary if you utilize digital cable television or some other digital form of television that requires the signal to be decoded first and then sent to your television then you're in luck, that's because most digital cable service providers or digital television service providers will provide you with a box that decodes their signals, this box also has inputs and outputs.
my advice is to purchase an external speaker or sound device and plug it into your digital service box and disconnect the audio cables from the television, then the sound should only be coming from your sound bar/device and not the television.
Good luck and thanks
Questions? Just ask!
Nov 27, 2015 | Televison & Video
Cogeco code s0900
The receiver was unable to tune to the selected station for some reason.
From the Cogeco website...
If you see a "One Moment Please" error on some channels that provides a reference code starting with S, it means the receiver was unable to tune to the particular channel(s). If you are also experiencing poor service on your analog channels, this could be related to a signal issue.
You should:
  1. Check the connection to the digital receiver and make sure it is firmly secure.
  2. Bypass any splitters or other equipment between the wall outlet and our TV.
  3. Check if the cable line has been damaged.
You can also try resetting your receiver by unplugging the power for 30 seconds (keep in mind that the menu/guide will need to be downloaded again).
If the "One Moment Please" errors continue, please contact us, as a service call may be required.
Hope this helps!
Oct 30, 2013 | Televison & Video
I recently purchased a 24" Proscan LEDTV, I currently have Optimum cable company as my Cable provider. In order for me to use one remote control to turn on the cable box as well as the new TV, I need to...
here is want I have found so far, hope they work for us. 10030 10090 10029 10030 10019 10093 11523 11178 10178, this is the same problem I am having Don't know if they will work for. if you have any you have found please posed them on this sight.
Sep 12, 2013 | Proscan Televison & Video
I recently got a Zenith H2522DT tv from a hotel that was upgrading all of the tvs to flat screen digital units.. There was no remote control with the tv. When I got the set home, I plugged it in and...
Possible that you got a bad unit. Is there any indicator light that flashes when you turn on the tv, feel free to send feed back good day and best regards.
Aug 14, 2011 | Televison & Video
I'm having a problem with my modem, obviously. I just got a standard internet service from Cogeco, about 14mbps. Had it for two days, and worked great untill tonight when I was playing an online game,...
While I am no expert it sounds to me like you got a faulty modem. A lot of cable componys will reuse old modems, that where given back after the service was terminated. Sometimes they try and reuse one that was given back because, it was faulty. You can request a new one through your cable provider
Aug 13, 2011 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I have a cogeco remote and i need to program it to get my sylvanna tv on video
Hello
Setup codes with One for all URC 3021.
For Sylvania dvd player is:
0675
For Sylvania TV are:
0054, 0030, 0171
OK.
Jul 25, 2011 | One For All URC-3021 Remote Control
Dynex flat screen- cogeco box- guide works then goes blank
Not the remote.It the Cogeco box.The box data's it out of dated,some time this happen.Unplug the Cogeco box about an hour,replug the box.Let it update it software.Goto the tv setup goto CH. rescan it again,all the tv channel should be back.
Jul 09, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Can't download files and upgrade using my wireless
If you connect the computer to the modem, you are able to download the files.
But if you connect it through the router, it is not working.
the problem is with the router. Cogeco is a cable ISP.
you can reduce the MTU settings on the router. If MTU on the router is 1500 then Make it 1300.
Under security settings, disable the firewall on the router and disable the Block internet request.
If it doesn't work then try to upgrade the Firmware of the router.
For more info about networking Click Here
Oct 06, 2009 | Belkin (F5D5231-4) Router
Need code to sync my remote for tv
Is it Sony, or is it Panasonic? It can't be both unless there's been a merger I don't know about. . .
Nov 09, 2017 | Panasonic Televison & Video
Universal Remote
Try going to urcsupport.com. This is the site for universal electronics who manufacture the Atlas remote. You can search here for extra codes.
Oct 24, 2008 | Televison & Video
Proscan 19LA20Q LCD TV Logo
246 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
