Question about Home
Show wiring diagram how to wire a external light switch
  • Electric by George Jul 13, 2010
    Explain what you mean by "external" are you talking wall switch?...inline "cord switch"? Lamp fixture switch? The basics on a single pole switch is that the neutral (white) wire connects directly to the fixture/ lamp neutral. The hot (normally black) connects to one terminal or wire of the switch and the "switch leg" connects to the secondary terminal or wire of the switch. Make sure to turn the circuit off before you start working on it, working on a "live" circuit may give you that "TINGLING" sensation and it won't be because the love of your life walked into the room.
  • 827 Answers
Most wireing should be left to an electrician to do
Posted on Nov 24, 2013
MY BRAKE LIGHTS WORK BUT MY TAIL LIGHTS OR DASH LIGHTS WONT. I CHECKED AND REPLACED FUSES
How do you turn those lights on for your vehicle ? Headlamp switch ? I would say what ever controls (turns on) would be the culprit ! Test first ,find a wiring diagram an check B+ voltage to the switch . The wiring diagram will show which color wire it is , then with light switch in the running lamps position only , not headlamps . The diagram will show which wire should have B+ voltage . If there is any the switch is bad . There are videos on youtube for basic automotive electrical testing ! If your not sure take it to a qualified repair shop !
Jul 25, 2016 | 2003 Kia Spectra
Need wiring diagram
Wiring diagram for a 3-way switch, one of the many wiring diagrams showing different methods of wiring a three way switch circuit. This electrical wiring diagram shows power into light switch Box #1 – wire to light from switch box #1, and from switch box #1 to three-way light switch box #2.
Jan 06, 2016 | Holmes Products Heating & Cooling
Wiring diagram for 3 way 2 socket lamp
Where is the switch located? If you buy a replacement switch at Home Depot it usually comes with a diagram that shows you how to wire it. If the switch is built into the light socket just replace the socket the switch is included.
Jul 29, 2014 | Leviton Electrical Supplies
Show diagram
Copy following link for combo switch wiring:
http://waterheatertimer.org/How-to-wire-switches.html#combo
Combo requires neutral wire.
There are white wires that are twisted together, covered with wire nut and pushed to back of box
Nov 04, 2012 | Cooper Industries Cooper Wiring 274V...
How to wire residetial light switch
Open following link for diagrams showing basic single-pole and 3-way wiring diagrams:
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
May 29, 2012 | Electrical Supplies
Wiring diagram for time clock with photocell contacter and bypass switch
Copy following link for possible wiring diagrams showing photo eye and contactor:
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#photo-eye
Dec 15, 2011 | Home
I need a wiring diagram for VGFS15-MSP combination switch/GFCI
Copy following for wiring diagrams showing GFCI combo switch-outlet
http://waterheatertimer.org/How-to-wire-GFCI.html
Dec 04, 2011 | Electrical Supplies
How do I wire the timer in a 3-way switch?
Woods 59013 59017 59018 59720 59028 etc wall timers are not made for 3-way application. They replace a simple on-off switch.
Atube T1032-3W programmable timer shows it can replace 3-way switch.
See manual
Smarthome
Intermatic ST01C & EJ500 programmable times can replace 3-way switch. Look at diagrams carefully. Circuit is limited to 100' distance because of battery.
See wiring diagram
Aplus
Lutron makes several 3-way countdown timers that turn on light for certain length of time and then turn off light
Tip for 3-way switch replacement: Mark wire that connects to dark-colored screw. This is called the 'common' wire.
Depending on location of switch, the 'common' wire either goes to Load (lights) or it comes from breaker box as Hot wire.
Oct 02, 2010 | Woods Hardware & Accessories
How do i wire up a two gang switch, when i do it the outside light stays on all the time or not at all
how do i wire up a 2 gang light switch and can you show me a diagram, from fuse box to switch and then out to 2 lights.
Apr 09, 2009 | Electrical Supplies
Home Logo
165 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
