Question about Delta Faucet Delta 467-SSSD-DST Palo Diamond Seal Kitchen Pull-Out or Out Faucet Brillia
Our hot and cold water seem to be mixing. we had scalding hot water for a few days,then hot water tank died. put in a new one and now the water is warm for a minute then turns very cold.
  • 349 Answers
When you filled the water heater did you get all the air out of lines and water flowing before you turned power onto heater. It sound's like the bottom element on the heater is not working. That is if it's the same throughout the house hot then get's cold.
Check the power to the lower element and thermostat.
Posted on Jul 13, 2010
Delta kitchen touch faucet not getting hot enough anymore
well since u didn't mention the exact model u have or include a photo so I can positively ident it, id say u need to look around base of faucet for lever , this is the mixing valve control , it controls how much cold water mixes with hot water to prevent a scalding occurrence in use , this lever may have gotten moved and a new position will need to be explored to find a comfortable temp u like it at again
Dec 16, 2016 | Water Water Heaters
Hot water heater has hot in tank but dose not come out of hot water line on tank
most electric hot water systems use a heat transfer process where the element is in one tank and the house water is in another
the house water is what is being drawn off when you turn on a tap
there is a regulator valve at the top of the tank with a small lever that you open up to let water in and air out of the system
another point is that there may be a hot/cold mixer on the hot water outlet which limits the temperature of hot water to prevent scalding injuries in the bath and shower or sink
If you have one fitted they are known to malfunction and cut the hot water temperature down as, they mix too much cold water into the hot water pipe.
have a plumber check it out
Jun 13, 2015 | Water Water Heaters
How would you minimise the riskto the elderly or infants when replacing an exsiting hand basin?
If you are referring to limiting the temperature of the hot water to prevent scalding, then a tempering or mixing valve can be plumbed in between the cold and hot water lines. This type of valve adds cold water to the hot water and it is adjustable.
Mar 18, 2013 | Mountain Plumbing Plumbing
When turning on the hot water on dedicated hot water faucets, the water is almost scalding. However, when turning on the shower and tub that has only one faucet handle (mixes cold and hot) and put the...
Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
Oct 09, 2010 | Delta & Single Handle Shower Faucet
Hello we have Bradford hot water tank model #MI65R6DS13. Our problem, I keep having to press the tanks reset switch for us to get hot water. At the same time after I press the reset switch we have hot...
No the top thermostat is the first place I would start to replace. They run about 14.00 more than likely it isn't controling right. Turn power supply to water heater off and replace thermostat.
If you was getting scalding hot and then turning cold without tripping the thermostat it would be the top element working and the bottom one bad.
Bottom element good it will give you luke warm water for a while then gradually turn cold because it's heating the bottom of the tank.
Hope this will help you out.
Oct 09, 2010 | Fasco Bradford White Hot Water Heater...
Our tankless water heater is about 3 yrs old and when you take a shower the water is so hot it will burn you and when you try to cut more cold on it turns all the way cold we have it turned down as low as...
almost all tankless water heaters have this problem. I would install a small "buffer" tank. for example a small 5 or 10 gallon electric water heater will "mix" the water so that it doesn't come out of your shower cold, or scalding hot.
the instructions that came with your water heater should have a diagram of how to do this. if not let me know, I can send a copy.
the electric water heater acts as a mixing station.
the problem with most tankless heaters is that the water coming in is cold, average 60* and the water coming out is average 120*. sometimes the flame in the unit can't keep up when using large amounts of water, and you will get cold spots. when this happens, the heater will sense this, and then tells the flame it needs more BTU's, so then you will get extremely hot water.
the buffer tank will fix this by mixing the water before it gets to your shower and will give you an even water temperature.
let me know if this helps
Aug 22, 2010 | Bosch Water Heaters
Delta 13022 - Hot water out of the shower is much cooloer than out of the sink faucet. How is the mix of hot & cold controlled?
The Delta shower has a rotational limit stop designed so that when another fixture is activated, such as a toilet or dishwaser, the water does not go to extreme hot or cold. The reason for this is that the Delta shower unit is not pressure balanced or does not contain an anti scald device. The pdf document below will show how to adjust the water tempature if you feel it is too cold. Please use caution as it is probably set the way it is to prevent scalding.
http://www.deltafaucet.com/media/Product_Tech_Docs/Maint_Installation/50001to80000/51975RevH_4.15_15e05.pdf
Aug 03, 2010 | Delta T13420 Chrome Classic Single Handle...
How do i put water for the radiator?
Does your car have a cap or a sealed unit? You don't want a sealed unit. You want to be able to check your water.Push down and Twist the cap off when cold, not hot, fill it up with coolant, 50/50 mix, and fill up the expansion tank. It says coolant on it. The car will balance itself out. Check the water in your battery while you are at it. It dries out too. Then check the brake fluid, power steering fluid, and oil. That should keep you busy next Saturday. Hope this helps.
May 23, 2010 | 2002 Mercury Cougar
How to adjust anti scald valve on american standard shower faucet
Remove the handle,and all the trim rings,and the cartridge cover. take a flat head screwdriver and use it to lift
up the red ring behind everything, this is the hot limit safety stop,
this just stops the handle from turning to full hot.
Once you have the red ring lifted up, notice the numbers and the pointer
on the ring, numbers are on the fixture,
O= hottest 7=cold
See what the ring pointer is set to now, and move it half, before you put this back together, just set the handle on the unit and run the water to see if its to hot or not enough. Once you have found what is the best setting, then replace all covers and trim, handle.
Feb 10, 2010 | American Standard Bath Faucet Ceramix...
Scalding hot water
If your water is too hot, then either the water tank thermostat or the wiring to the indoor unit is defective. When the water reaches the set temperature, then the tank thermostat contacts should open up and shut off the combustion unit. If the combustion unit does not shut off, then check all wiring and relays. A manual is located at http://www.scribd.com/doc/29550374/Amana-HTM-Plus-Manual
Dec 03, 2008 | Water Heaters
Delta Faucet Delta 467-SSSD-DST Palo Diamond Seal Kitchen Pull-Out or Out Faucet Brillia Logo
120 people viewed this question
Top Delta Faucet Plumbing Experts
Steve Wood Plumbing...
Level 1 Expert
joeiaaz
Level 1 Expert
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
